OS in this case is Window 10 Pro.
The specs on this card runs DirectX12.
The Recommended Requirements for Revit 2017 calls for DirectX11.
However, Window 10 Pro is by definition DirectX12 (as I understand it)
So, will I be ok with this card for Revit 2017, Navisworks 2017 and for AutoCAD MEP 2017...
... and beyond?
Solved by natasha.l. Go to Solution.
Hello @mdhutchinson,
It is not a problem.
The DirectX 12 continues to support capability from DirectX 11, it provides the option for lower-level access to hardware if it needs to optimize the software.
Thank you for posting.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Please let me know if you have any other questions. I am happy to help, if I answered your question.
Natasha
Helpful Links:
