Announcements
Not able to install AutoCAD LT 2016 - Allied prducts missing
Installed AutoCAD LT 2016 yesterday and the product would not activiate. Someone at Autodesk informed us to uninstall product and install and it should work this time. I uninstalled through control panel. First said product was already installed. I then used uninstall tool in Start menu. Now when installing it gets to 2 of 9 and gives the message "Allied product is not found." Select OK, then get "Installation complete. Some products failed to install" which is AutoCAD LT. I have attached screen shots.
Otto
Hello eleach and welcome to the Autodesk community!
It looks like you're seeing the "Some Products Failed to Install" error. This error can be caused if prerequisites have already been installed on the target machine. Incompatible versions, or even the same version, can cause this problem. The following article(s) should help you resolve the problem:
Error: "Install complete. Some Products Failed to Install"
After uninstalling the necessary files, please fully shut down your computer and reboot it for the changes to take effect.
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
This did not work I still get Allied products not found at 2 of 12 installation point.
[cid:image001.png@01D19A16.9F9C8C90]
[cid:image002.jpg@01D19A16.9F9C8C90]
Eva Leach
Systems Administrator
1270 Highway 3057
Somerset, KY 42501
Office (606) 678-7804
Mobile (606) 260-0100
Fax (606) 678-7879
eleach@ugn.com
**Please note that UGN email addresses have changed. Please update your records accordingly.
[cid:image003.jpg@01D19A16.9F9C8C90] Please consider the environment before printing this email.
Mark.Lancaster
eleach
The auto-reponse tries to help  Smiley Wink
Anyhow welcome to the community and hopefully my (or someone else) reply will be beneficially to you.
As a reminder, this is a world wide (public) user forum where users are assisting others. In addition do not post, attach screen shots, or share any personal information (such as your serial #) here.
You have Autodesk stuff still lingering around..   Please review this article and follow its steps.  If you have Windows 10 use the WIndows Cleanup utility instead of Microsoft Fixit.  Its link can be found in my signature.
Next review the verbiage below the line/above my signature and follow those steps to download and install your application.
Mark Lancaster
Darin.Green
I agree with @Mark.Lancaster the solution within the article should work... If not, post the installation log file from your C:\users\<username>\temp\ folder location.
If this information was helpful, please consider using the Accept Solution
