I have been trying to generate a license file but keep getting the error as per screen shot attached. I clicked on the contact 'Customer service' but then thee I put in the information and keeps saying 'start over' I did that more than 10 times since yesterday. Hope there is some help.
Ashok
This is a public forum, please refrain from posting serial numbers or personal information
Edited by
Discussion_Admin
Solved by dgladfelter. Go to Solution.
I'm not sure if it will produce different results, but have you tried creating your license file from the RegisterOnce site?
http://registeronce.autodesk.com
The username and password for that site will be the same as what you use for the Autodesk Account site.
Please go through the article
goo.gl/0vCHkd
Thanks & Best Regards
Cheers,
Vinay Vijayakumaran
The perpetual and subscription combination shouldn't be an issue. That said, you may want to try generating the license files individually, and then combining into a single license file using Notepad.
Combining License Files for Multiple Autodesk Products: http://autode.sk/2mAMOoZ
Thanks Donnie,
Is there a way to generate license file for 2013? One user is still using that version. I did not find 2013 while generating the file.
Ashok
Please stop sharing all of your personal information such as your serial # on a world wide user forum. I will have the moderator remove it to protect your information. Also I strongly suggest that you don't reply using your email system. Your personal information such as number and email address is also being share here. Meaning do you really want that on a public forum.. I certainly wouldn't want it..
Now a couple of things..
First you can't generate a license file for products that are retired/unsupported and out of the scope of your subscription/maintenance plan. In addition you are technically violating your end user license agreement by continuing the use of 2013. But there are exceptions to this..
Unless the above is true, you are in a non-complaint state and you can be fined by Autodesk for that. Even if you had a perpetual license of 2013 on a maintenance plan and elected not to continue with it. You are only entitled to use the version that was released at the time when you canceled your maintenance plan. So before red flags are raised at the Autodesk end you need to get your organization compliant in order to avoid an Audit. Remember Autodesk does monitor these forums..
Next thing.. Generating a license file from Autodesk Register once will generate multiple license. You will need to combine them in the end. Finally I will provide all the ways to generate a license file.
To generate a license file (pick one)
1. The contract manager or software coordinator for you subscription can log into their Autodesk Account and select Generate License file link (Granted this didn't work for you)
2. Go to the Autodesk Register Once Web site and follow the prompts. With Register Once you have to repeat the process for each network serial # that you have and then combine the license file at the end.
3. Contact your reseller and they will do it for you.
4. Contact Autodesk here and they will do it as well.
In all cases you will need the name and MAC address of the machine that is hosting the license file. One final thing, you must update your license manager to version 11.13.1.2 (https://knowledge.autodesk.com/customer-service/network-license-administration/get-ready-network-lic...)
Mark Lancaster
& Autodesk Services MarketPlace Provider
Mark,
While your point for contact info/phone numbers etc is well taken, but I don't know how you came to determine our perpetual licenses are not in maintenance. We had this cleared up with the vendor and further corroborated by Autodesk sales, that as long as we stay on maintenance we should be able to use older version. I have to take this up again, based upon your input.
Thanks for your time.
One of the benefits of subscribing to Autodesk software (either perpetual or the new business model) is the ability to use previous versions. This benefit (under either model) allows you to use the current version plus the last three versions provided you maintain your subscription. Currently that benefit allows current subscribers to use 2014-2017.
Some things to note about perpetual licenses is you are only entitled to run previous versions for as long as you have an active subscription. Should you let your subscription lapse, you're only permitted to run the last version you purchased (aka whatever the current version was when your subscription expired).
Without getting authorization from Autodesk, the only way to get a license file for 2013 would be if that's the last version you purchased. Since it seems you have 2017, that doesn't seem to be the case. Based on that, the only way to legally run 2013 at this point is with an authorization acquired from Autodesk. If that's something you need, your reseller can help you navigate the process of getting that.
"but I don't know how you came to determine our perpetual licenses are not in maintenance. We had this cleared up with the vendor and further corroborated by Autodesk sales, that as long as we stay on maintenance we should be able to use older version"
I never said you were or were not on maintenance. I was just passing along info to you..
"long as we stay on maintenance we should be able to use older version" Although this is true. But a perpetual license on a maintenance plan or a term based license is only good for current release and 3 legacy version. With 2017 out, you are only entitled to use 2014 to 2017. 2013 falls off the radar and in the coming months 2014 will drop off too. So you are not entitled to use any legacy version past the 3 legacy mark.
In the end I just don't want you to get audited and be fined.. Its not pretty..
Mark Lancaster
Thanks again. Well I did try but somehow getting a few hiccups here and there. I did get all the possible files then combined them and when creating the service getting error "Service has been created but failed to update the DACL settings for FlexNet........." After a KBs on line I used just one single file but still the same error. What am I doing wrong?
Hi Donnie,
Actually I did talk to the user, and tried to articulate the issues with still using 2013. He has agreed to upgrade to a newer version. Thanks for sharing your thoughts.
Ashok
Ignore the message. Save the service again and start the license service.
Mark Lancaster
Thanks for all the options provided. I still have to get a new license file with all the sr #s and versions, but I did learn a lot from your posts as well as others.
I am doing another post for an error getting installing a client but not finding the license server.
Thanks to all.
Ashok
