Installation & Licensing
New Installation of EAGLE won't start
1 REPLY 1
technicalE6PBM
382 Views, 1 Reply
I am new to EAGLE and I just installed it yesterday.
But it won't make it past the splash screen and won't give me any information on WHY its crashing.
I am running Windows 7 Pro SP1 64-bit on a bootcamped Mac Pro 4,1 (late 2009).
This machine has an 8-core Intel Xeon 2.67GHz CPU and 8GB RAM.
MacOSX 10.11.6 and Windows 7 are on separate SSDs and there is a third common files drive, which is a 1TB rotational.
The graphics card is an ATI Radeon HD 5700 series.
I tried restarting my machine several times after the install, no luck.
I tried running Windows Updates to make sure everything, including optional updates are current, no luck.
I tried uninstalling and reinstalling EAGLE, no luck.
I browsed through these forums and found another post with a similar issue, solved by a graphics card driver update, no luck.
Running out of ideas and I need to get up and running sometime on Monday to review a PCB design from a supplier.
Thoughts?
Thanks in advance
--Josh Karpoff
Electronics and Systems Engineer
Technical Services Department
Sound Associates, Inc.
1 REPLY 1
I also checked that EAGLE is installed in the C:\ drive, not in C:\Program Files.
Below is the event from the logs:
<quote>
Faulting application name: eagle.exe, version: 0.0.0.0, time stamp: 0x59f74cbe
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x0000000000000000
Faulting process id: 0x580
Faulting application start time: 0x01d35ff4dbcad3ba
Faulting application path: C:\EAGLE 8.4.1\eagle.exe
Faulting module path: unknown
Report Id: 1b644ec3-cbe8-11e7-8a7a-64b9e8ede2c4
</quote>
Administrator Productivity
