Network License Manager for Windows 11
peter_mackenzieUN9A2
Message 1 of 10
I'm running Windows 11 and can't install the Network License Manager (which means that CAD doesn't work). I've followed the instructions below and it appears that the NLM doesn't support Windows 11.  Is there a workaround? What am I doing wrong?
https://knowledge.autodesk.com/search-result/caas/downloads/content/autodesk-network-license-manager...
Replies (9)
Message 2 of 10
DarrenP
What does can’t install mean?
The license manager is only for multi-user licensing is this the license type your using?
DarrenP
Message 3 of 10
The .msi file doesn't open the installer.  I'm using a student license and CFD Ultimate.  The specific error message Im getting when running CFD Solve is below:
Message 4 of 10
DarrenP
You may have a license manager already running
Go through this: https://knowledge.autodesk.com/support/cfd/learn-explore/caas/sfdcarticles/sfdcarticles/The-motion-S...
DarrenP
Message 5 of 10
Thanks, the issue's still there but it looks like we're honing in on the problem: It won't let me generate a license file.
Message 6 of 10
In CFD 2023 the About tab has no license information.
Message 7 of 10
DarrenP
Is this a student license?
If it is than you won’t be able to generate a license
DarrenP
Message 8 of 10
Darren, yes it's a student license - does that explain why CFD shows the motion solver license error?  Is motion solver excluded from the student license or is there something else going on?
Message 9 of 10
DarrenP
yes the student license does not get a network license
you can try this: https://forums.autodesk.com/t5/cfd-forum/unable-to-solve-in-cfd-2023-student-due-to-error-message-qu...
otherwise i will ping @LeoWarrenADSK to see how this works with student licenses
DarrenP
Message 10 of 10
That's sorted it - thanks!!
