Network License Manager and Remote Office
paltomare
Message 1 of 10
paltomare
Having an issue with my remote office which I will attempt to explain.
My main office is in Long Beach, CA where I have my Primary Domain Controller with NLM installed serving 14 BDSP licenses.
I recently opened a Chicago office and had my staff there connected to the Long Beach server via a VPN.
This worked well for NLM but opening files has been dreadfully slow.
I am in the process of implementing Panzura which should resolve these issues. One of the first steps is to install a local Domain Controller in Chicago and have users there authenticate to that server.
Here is where I ran into trouble. Now that Chicago users are authenticating to the Chicago server they are no longer getting the licenses from NLM on the LB server. They are still connected via the VPN and have access to files on the LB server, they are just not getting the license.
I'm sure there is a solution to this if someone could help.
Paul
Replies (9)
Message 2 of 10
DarrenP
is there an error message?
DarrenP
Message 3 of 10
paltomare
They get the attached messages.
Message 4 of 10
DarrenP
can you ping the license server machine by name from those computers?
DarrenP
Message 5 of 10
paltomare
Yes, I can
However if I put the same name in the FlexNet License Finder dialog box, it returns an error.
Message 6 of 10
DarrenP
can you put in the IP address of the license server in that box and see if it works
DarrenP
Message 7 of 10
paltomare
I tried the IP but no luck. I can ping the IP however.
Sent from my Verizon Wireless 4G LTE smartphone
Message 8 of 10
DarrenP
it could be possibly timing out: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
DarrenP
Message 9 of 10
paltomare
Could be.
Latency between offices typically averages 75ms but today I'm seeing an average of 212ms.
This all started though when we switched the authentication to the Chicago server.
I'm going to temporarily change it back to LB and see if they can get to NLM.
Message 10 of 10
paltomare
Changing authentication back to LB didn't help, but following these set of instructions did work.
  1. Right-click My Computer. Click Properties.
  2. In the System Properties dialog box, click the Advanced tab.
  3. On the Advanced tab, click Environment Variables.
  4. In the Environment Variables dialog box, under System Variables, click New.
  5. In the New User Variable dialog box, enter FLEXLM_TIMEOUT for the name and 1000000 for the value.
  6. Click OK to close each dialog box.
  7. Launch the Autodesk application.
So it seems to be a latency issue after all that just coincided with the server switch we made.
Thank you for your help!
