Hello @ballnr,
Welcome to the community.
I assume you are referring to Vault, Vault requires some more steps so please review Vault Server Installation.
A license file first needs to be generated or requested here:
1. Generate a Network License File in Autodesk Account or Requesting a Network License File
Note: If you are installing Autodesk Vault Basic, you do not need to install the Network License Manager or license file.
Note: In the case where you have combined the license with an existing license file (make sure to check for copy/paste errors)
*If you need help Finding Your Host Name and Physical Address
Then, the NLM needs to be installed and setup:
2. Make sure you meet the NLM requirements to Install & Configure it
3. Then, on each Client computer at launch, specify a License Server "2080@ServerName"
Thank you for posting.
Please "Accept As Solution" if a reply has helped resolve the issue or answered your question, to help others in the community.
