I try to install AutoCAD Civil 3D on Windows 8 Pro activated and i have problem with frame work language 4.0 probelem
Please i need to help
Windows 8 is not a supported OS. Futhermore, the OS has .NET preinstalled already so for you to be able to install your program, you will have to modify your setup.ini to remove the check for .NET.
http://forums.autodesk.com/t5/CAD-Managers/Anyone-try-Windows-8-Developer-preview/m-p/3352895#M84974
