My autocad doesn't open
I try to open my autocad, and it opens in the loading window and then closes, it doesn't give me any error message. I try what autodesk recommended and also a clean uninstall and it remains the same ... not sure what else to do. I have another Autodesk product and it works perfectly, but AutoCAD does not. help
Alfred.NESWADBA
Can you describe what that way, otherwise we don't know exactly what you might have missed and it's worth to suggest this or not ...
I would start with
  • install updates
  • reset profile
  • start without hardware acceleration (startparameter /SAFEMODE)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
beyoungjr
AutoCAD version?
Windows version?
PC specs?
Any crash report?
Not enough info for us to diagnose.
Blaine
Blaine Young
Senior Engineering Technician, US Army
oh yes i mean
i try a clean uninstall
i try rename the cascainfo.cas file
i check the FLEXnet
i navegate to the adskflex_tsf.data
and it still the same
autocad 2021 i also try download the 2020 and still doesn't open
windows 10
procesator Intel(R) Core(TM) i7-8565U CPU @ 1.80GHz 1.99 GHz
RAM 16.0 GB (15.8 GB usable)
it uses 64 bits
- i had the 2020 version before and it runned good, i stop using it for a while and then this month i wanted to use it and it doesn' t open-
it doesn't show me any error message it just closes
beyoungjr
When you tried the clean uninstall did you also attempt to clean up leftover junk with CCLEANER or similar?
I also would look at your graphics processor!  You may need a compatible driver and that might come from an update or a roll-back to previous driver?
Keep me posted,
Blaine
Blaine Young
beyoungjr
Also follow Dean's instruction at this post for uninstalling...
https://forums.autodesk.com/t5/autocad-forum/unable-to-install-custom-oem-setup/m-p/10167926#M104723...
Blaine
Blaine Young
