Hi
I'm trying to install a trial of Mudbox on MacOS Sierra. I have been on your page, downloaded the installer and run appropriately.
However, after going through the whole install process, the install fails at the last hurdle saying "Installation failed on exit."
I have a late 2014 27" retina iMac and the latest MacOS.
I've also tried installing as root user with the same result. I need this software installed very very soon!
Solved by natasha.l. Go to Solution.
Solved by Mark.Lancaster. Go to Solution.
@ajcgi wrote:
Hi
Its not our page.. It belongs to Autodesk.. This is a peer to peer network where users are helping users like yourself.
Next the 2017 version doesn't support Sierra.
Finally its just probably failing due to the method you using.. However that's the only option you have to install from..
Mark Lancaster
& Autodesk Services MarketPlace Provider
@Mark.Lancaster wrote:
@ajcgi wrote:Hi
Ah apologies. I'm gonna blame AD there for making their site layout as clear as Mud...box. 😉
Thanks ever so much for your reply Mark. I was trying lots of different things.
Not a day goes by working in VFX when I question the logic of Autodesk. If it doesn't support Sierra it surely supports Windows 7 so I'll just use it in Bootcamp I guess. Daft question but did the 2016 version support Sierra?
Yeah the install method is straight forward. I've tried using Alt-click to see if opens extra menus or whatever. Ultimately it's kind of a next, next, next, accept, install kind of deal.
Hello @ajcgi,
Please review the system requirements below.
System requirements for Autodesk Mudbox 2017
Operating System |
Thank you.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Thanks very much Natasha. Are there plans for Mudbox to support Sierra in the future? I heard rumours that Mudbox will be discontinued by Autodesk soon.
Hello @ajcgi,
I can not speak to that as there is no formal announcement regarding either one of these issues. When Autodesk makes a formal announcement regarding issues like these I will update the I&L board.
Thank you.
Natasha
Helpful Links:
