Hello
I Have A Problem with AutoCAD While Moving Or Copying An Object My mouse Start Jerking And Jumping
I Have RTX 2080 TI Graphic Card & Windows 10 Operation System
If There Is a Solution For The Issue
Thanks, A lot
Saher Joubran
SAFA Architects Company
Hi @Anonymous,
Have you tried to update your mouse/GPU drivers?
Have a look at this article to see if it fixes your issue: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Cursor-is-slow-or-jerky-in-AutoCAD.html
Hi @Anonymous,
A GPU not being certified doesn't really matter - it's a long story for another post why Geforce cards aren't certified.
Just googling has lead me to this post: https://forums.autodesk.com/t5/autocad-forum/jerky-cursor-in-autocad-2018/m-p/7174278#M885775
From looking about it could be many things so I would suggest trying a variety of suggestions especially if they are marked as solved.
hello
yes, I tried to update my mouse/GPU drivers? and it doesn't help
but I install the old version of AutoCAD 2014 it's going smoothly !!!!! ??? but I have the AutoCAD 2021 installed on Other Computer (Dell Workstation ) and everything works fine ??
HI @Anonymous
Roll back the driver to be one of the other Nvidia compatible drivers from
https://knowledge.autodesk.com/certified-graphics-hardware?id=18844534&siteID=123112
I would review this as well:
also:
¿No encontraste lo que buscabas? Pregúntale a la comunidad o comparte tus conocimientos.
