Every time I try to install Autodesk Inventor 2017, it fails and the installation log files say:
Microsoft Visual C++ 2013 Redistributable (x64) Failed Installation aborted, Result=1619 Microsoft Visual C++ 2013 Redistributable (x86) Failed Installation aborted, Result=1619
Now I searched through the internet, and the solutions I have been seeing are to uninstall all the Microsoft Visual C++ Redistributables that are causing the problem. The only issue with the fix is that I use another Microsoft coding program known as Microsoft Visual Studio Express 2013, which I'm guessing requires the 2013 Redistributables. So if I delete the 2013 Redistributables, there would be problems with Microsoft Visual Studio Express 2013, which I don't want.
Welcome to the community...
Please provide the entire installation log file. Meaning the failure could've existed before that. Posting info: Sometimes installation log files contain personal information such as your serial #. Prior to posting your log file please make sure to remove such info.
Mark Lancaster
& Autodesk Services MarketPlace Provider
To resolve the issue you're having, uninstall all Microsoft Visual C++ version newer than 2011. Once they're uninstalled, download the software (All Parts) from the Autodesk Virtual Agent. When the download is complete, double-click part 1 (this will also extract all other parts as well) to begin the installation process. The other MS Visual C++ apps will get installed along with the Autodesk application.
If you need assistance downloading from the virtual agent, here's a video:
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
