Installation & Licensing
cancelar
Mostrando los resultados de
Quiere decir:
Meshmixer taking a long time to generate
2 RESPUESTAS 2
RESUELTAS
Responder
Mensaje 1 de 3
2382 Vistas, 2 Respuestas
Hi all,
I need some help. I have recently taking up 3D printing as a hobby. I am having problems with the computer I am using.
The equipment I am using is:
POP Scanner
Lenovo RYAN 5 laptop 8GB Ram
I scan my image, load it into mesh mixer but my laptop is taking a very long time to generate the scan and when I remesh it, it too takes a very long time.
Before I go out and buy a computer which could experience the same issue I was hoping someone could help me on why this is happening. Is my ram too low for the scanner?
Etiquetas (1)
Etiquetas (1)
2 RESPUESTAS 2
Mensaje 2 de 3
leowarren34
en respuesta a: Anonymous
Hi @Anonymous,
What CPU do you have?
You can check your RAM utilisation in Task Manager, if you're regularly creeping in 7+GB in use then you may need more RAM but this can be done yourself.
Also, look on the performance tab of Task Manager and see if anything is under high loads.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Mensaje 3 de 3
hfcandrew
Try remeshing a very small selection first. How long does that take? Also how many triangles is your model.
Also wrong forum. Use the MM forum: https://forums.autodesk.com/t5/meshmixer/bd-p/6013
¿No encontraste lo que buscabas? Pregúntale a la comunidad o comparte tus conocimientos.
Publicar en los foros
Administrator Productivity
