Mesh Mixer will not install
billbarschdorf
Message 1 of 12
billbarschdorf
 Dose AD still support it MM?
Cant seam to get MM installed?????  I have treid to install the software many times over the last couple of years but after installation it seems to not have been installed.  This has happened ever time Ive tried to installed it. I dont get a icon on desktop, I cant find it via windows serch, its not in the programs/apps list ,not on my desktop, it dose not auoto launch, I dont get it. Can somone help me get this resolved. I need to use it for STL repair I have some really bad meshes I need to fix for printing.
Replies (11)
Message 2 of 12
rushabhthakkar_910
@billbarschdorf, try downloading it from here..!!
(https://meshmixer.com/download.html)
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 3 of 12
billbarschdorf
I’m almost positive that was the site I originally downloaded from. I’m. Give it a try when I’m back in office on Monday.  I’ll repost back if I still have the same results.
Message 4 of 12
DarrenP
does Autodesk still support MM?
if you noticed they haven’t updated MM since 2018
there is a forum that is still active: https://forums.autodesk.com/t5/meshmixer/bd-p/6013
DarrenP
Message 5 of 12
mdavis22569
Also share what version of Software you're on .. What Windows OS  and if you're getting an error
Use:
https://meshmixer.com/downloads/Autodesk_Meshmixer_v3p5_Win64.exe
Mike Davis
Message 6 of 12
billbarschdorf
Hi guys,  Got this resolved. I downloaded it from the supplied link and reinstalled MM. Good to go now, strange thing is the versions are the same.
Message 7 of 12
fullgrownmidget
Community Visitor
Community Visitor
having same problem... what do you mean by installed "MM"???
Message 8 of 12
DarrenP
Mm is mesh mixer
DarrenP
Message 9 of 12
fullgrownmidget
Community Visitor
Community Visitor
I did the same but I don't get the icon and only find the download installer nothing else
Message 10 of 12
DarrenP
this is not supported anymore anyway
try using Fusion 360
DarrenP
Message 11 of 12
b_ruijter
You cannot compare meshmixer with Fusion.
Message 12 of 12
taylorhill5VTU4
Community Visitor
Community Visitor
I recently had this exact issue - I installed Meshmixer and could not seem to find it anywhere afterward - no desktop shortcut, not showing up in Start menu, apps list, or search, etc. However, when I navigated to C:\Program Files, there was an Autodesk folder and meshmixer.exe could be found there and runs with no issue. I had to manually pin this to the Start menu for easy access - it had been properly installed but just not shown anywhere. So if you are having this issue, be sure to check your install location!
