Hello everyone,
I have yet again ran into an issue with Maya 2015. I am using Maya 2015 SP 3 Student License and today I have tried to install the Mental Ray renderer for maya but no success so far.
- I have downloaded and installed both, Standalone and Sattelite versions because I didn´t know which one was the correct one.
- Then I downloaded mental_ray_for_Autodesk_Maya_2015_SP3_Win.msp from the Autodesk Maya 2015 Service Pack 3 page.
- I installed it and after opening Maya and checking "Always Loaded" in the plug-ins for Mental Ray. I kept getting some kind of a saving error every time I opened Maya which would eventually cause maya to crash.
- So I uninstalled both the Satellite and Standalone versions as well as the file from the service pack 3 page.
- I tried to reinstall both the satellite and standalone versions BUT, every time I try to run the mental_ray_for_Autodesk_Maya_2015_SP3_Win.msp file I get this message:
"The upgrade patch cannot be installed by the Windows Installer service because
the program to be upgraded may be missing, or the upgrade patch may update a
different version of the program. Verify that the program to be upgraded exists on
your computer and that you have the correct upgrade patch."
Am I doing somethng wrong or is the Mental Ray plug-in not available for Student versions?
Just to chime in, I was having the same problem and after following the instructions followed by Elcono I was able to run the installer for Mental Ray SP3 for Maya 2015. There were a few differences in the process though:
// Error: line 1: Unable to dynamically load : C:/Program Files/Autodesk/mentalrayForMaya2015/plug-ins/Mayatomr.mll
The specified procedure could not be found.
// Error: line 1: The specified procedure could not be found.
(Mayatomr) //
So I've managed to reinstall Mental Ray for Maya, but I still can't use it as the plugin refuses to load.
I had the same issue and tried to manually install the latest service pack for Maya 2015.
"The Specified procedure could not be found. (mayatomr)" etc
Now it works just fine. 🙂
I have the same error:
// Error: line 1: Unable to dynamically load : C:/Program Files/Autodesk/mentalrayForMaya2015/plug-ins/Mayatomr.mll The specified procedure could not be found. // // Error: line 1: The specified procedure could not be found. (Mayatomr) //
I have installed SP, no luck, nothing works.
