MAYA Installation Problem
After downloading the software and opening it, I followed the steps and press the install button.
However, there is no section for me to chose. The button instal is blocked so that I can't press it, and I also can't change the place where I wan't to setup Maya cuase the button is also blocked.
Really wanna know how to solve these problems, looking forward to your help, thanks.
jeffrey.sin
Hi @Anonymous,
Welcome to the Community.
Could you try using the Microsoft Fixit Tool to remove any residual keys in your system before attempting to reinstall? You can refer to the links below for more information and instructions:
Program lists as already installed
Program cannot be installed because the installer indicates that it is already loaded.
Autodesk 3DS Max 2015 & Maya 2015 installer says it is installed
Kindly let us know how it goes.
Thank you,
Jeffrey Sin
Autodesk Customer Support
