Hi guys,
Excited about the 2020 release. But I keep getting 1603 error during installation.
Please find attached the installation log.
Thanks!
shawn
Solved by mdavis22569. Go to Solution.
Have you reviewed the following AKN article?
Try moving your installer from the F:Drive to you C:Drive
Make sure you have the Admin rights / Anti-Virus off ...
Hi@ shawnwangvfx,
Thanks for your feedback.
i would like to know more about the issue. could you please send me the log files?
Here is the log files location.
%appdata%\Autodesk\ODIS
Srinivas.
I am trying to install Maya 2020 on Windows 7 and keep returning this error. I have followed suggestions on the internet, yet still no solution. I am attaching the installation log file to find generous help of the work around.
Manually uninstall the AdskLicensingService.exe and reinstall most updated AdskLicensingService.exe still not giving solution.
Regards, _taktik
Hello.. I am downloading Autodesk Maya 2020 on windows 10 but on 50% it says error 1603. Please help me fix this issue.
Without your installation log file we can only speculate what the issue is at this point. So attach your installation file here so we can review it.
Posting info: Sometimes the installation log file contains the serial # that was assigned to you. Open your log file using Windows Notepad and perform a search on "/SN". Depending on the number of installation attempts, your serial # may be located throughout the log file. If present, remove or "X" out your serial # prior to posting.
Mark Lancaster
& Autodesk Services MarketPlace Provider
I am having the same problem re-installing Maya 2020. This happened after I uninstalled maya 2018 & 2019 and for some reason 2020 became unusable.
I'll attach my log files.
Thanks in advance for any help.
In your case its related to the new licensing mechanism.
Is this service there and started?
Mark Lancaster
In my reply I linked an article where your Autodesk installation log files are located...
In addition you come back to this forum posting, reply and attach the log file.
Mark Lancaster
Mark,
I do have that service running.
I have tried shutting down the service and installing. Same error in that case.
hi @mdavis22569 ,
I got error 1603 while installing Maya 2020. I used to use maya in the same device, but after i formatted my device i am getting this error. I have installed Visual C++ 2015-19,2013,2012,2010 and 2008.
Please help me through this issue.
Please find install log attached.
thanks
Prezados amigos,
Esotu com dificuldades de instalar o ROBOT 2021, Senso que eu ja tenho no meu pc a versão 2019. Mas, para aocmpanhar o trabalho dos meus alunos preciso a versao utlima do ROBOT ... Esta dando sempre ERRO 1603
Estou vendo que o antivirus pode ocacionar o erro 1603? Seria melhor realizar a instalação com antivirus desativado.
Estou anexando o arquivo *.log
Can't install Maya. Every time has this error. Try clean unistall, Antivirus is off. Don't know what to do.
So I had the same issue of the Error 1603. I was able to successfully install Maya 2020. Follow the steps in this article:
Hope it helps
Copy/Past solution for me:
This is one of the first posts to pop up on google for me so ill just post what worked for me here.
Go to C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing.
Run the uninstall.exe as administrator (right-click > Run as administrator).
Wait until all the files and folders disappear.
Navigate back to C:\Program Files (x86)\Common Files\Autodesk Shared\ folder and if AdskLicensing exists delete it.
Navigate to C:\ProgramData\Autodesk\ and delete the folder AdskLicensingService
Important: Disable any antivirus and/or firewall temporarily.
Download and Install the latest Autodesk Licensing Service from the Autodesk Account: https://manage.autodesk.com/cep/#products-services/updates
Repeat the install.
I know its an old post, but I just got this error, I deleted a bunch of Autodesk entries in the registry and it worked for me. I found this company not to give two hoots about this, so I take matters into my own hands. The article for the solution is just nonsense.
