Maya 2018 does not start
Message 1 of 28
Hello Support,
since the beginning of this week I can not open Maya 2018 anymore.
I would really appreciate suggestions and help - thank you very much in advance!
My Setup is the following
HP Z440 Workstation
Nividia Quadro K2200
Windows 10 Pro 1607
Maya 2018 (annual subscription till June 2019)
What exactly happens
When I start Maya the Login-Window comes on.
After entering the Data a blank Output-Window opens.
Maya.exe is run in the background (can only be seen in the Taskmanager).
On the Windows-Screen nothing happens.
What I did to solve the issue
Updating GPU Driver
Doing a clean Uninstall and Reinstall
Repairing existing Installations
Repairing Autodesk Licensing Service
Clear Flexnet files
Setting Flexnet to start automatically
What I can not do (due company regulations)
Setting up another Windows-User-Account
Reinstalling Windows
Replies (27)
Message 2 of 28
natasha.l
Hello @Anonymous,
Thank you for posting to the community.
You can try the steps below to reset & regenerate the LGS file, it seems to be what you are describing.
  1. Close & reboot the computer
  2. Locate the following folder:
    C:\User\username\AppData\Roaming\Autodesk\ADUT
  3. Rename this folder to: ADUT2
  4. Delete the three (3) files prefixed with Adskflex  from the following folder:
    C:\ProgramData\FLEXnet\
    *Note: The above files are Hidden files. You may need to enable "Show Hidden Files" in Folder options.
  5. Delete, create & save a LGS.data file following these steps:
  • Create a LGS.data file & delete the original: Open Notepad  Type at the very top    _USER
  • Change the file extension to .data
  • Save it to the Desktop & place it in the folder  C:\ProgramData\Autodesk\CLM\LGS\<product key>_<product version>
     8. When you launch your Autodesk software, you will be prompted to sign in
If the above did not resolve the problem, also try:
Temporarily disable security settings like Antivirus, Firewall & UAC on your system
Subscription Licensing Issues
Update your product with the latest service pack or Hotfixes by visiting the Autodesk website or account
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 3 of 28
leowarren34
Can you run as admin/elevated permissions,
Update windows?
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 4 of 28
Hello Natasha,
thank you for your quick reply. I followed the steps described by you but it did not change/ solve the problem.
Message 5 of 28
Hello Leo,
I am running windows as an admin and can try to do certain updates myself. Any suggestions?
Windows tells me my system is up to date.
Message 6 of 28
leowarren34
Do you have .NET 4.5 and all other components and other software installed?
Leo Warren
Message 7 of 28
Hello Leo,
Registration tells me that the following .NET Versions are installed:
v.2.0.50727
v.3.0.30729.4926
v3.5.30729.4926
v4.6.01586
v4.7.02053
What other components might be missing? The thing is that maya stopped working from one day to the other, so I think it has something to do with an updated software in connection with Maya. No new software was installed, neither were updates (knowingly).
Message 8 of 28
natasha.l
Hello @Anonymous,
Please share the error window you receive with us in a screenshot. You can try to apply the application update.
If you at least have Maya 2018.3 or later installed you can apply the latest update, which is Maya 2018.5:
  • Windows operating systems
       This update will change the existing version of Maya that is already installed
  • Mac and Linux operating systems
        To apply this update please uninstall your existing Maya 2018 software before installing this update
Maya 2018 Updates
Message 9 of 28
natasha.l
Hello @Anonymous,
Just checking in with you, hope you were able to resolve this.
Message 10 of 28
Hello Natasha,
sadly I am out of office today but will try to update Maya tomorrow and then come back to you again.
Instead of an error message the following happens everytime I try to start Maya:
Message 11 of 28
Hello Natasha,
sadly the latest update does also not work - the issue remains the same.
Message 12 of 28
natasha.l
Hello @Anonymous,
Ok, lets try the other common solutions associated with start up issues. Try launching/starting Maya, then use
 >Event Viewer<  to locate the system error associated with it.
 One of the common solutions may need to be conducted:
  1. Sign in as Administrator or Create a New User Account (Full Control user permissions)
  2. Make sure you have an updated graphics card driver by checking the manufacturer's website then (Assign the correct Graphics Card) or try using DirectX instead of OpenGL viewports(Windows> Preferences) & set the display type to  DirectX.
  3. Temporarily disable your Antivirus software & Firewall
  4. Temporarily disable UAC on  Windows 7 or Windows 10
  5.  How to reset Maya to defaults
Keep us posted.
Message 13 of 28
Hello Natasha,
thank you for the help.
1) The event viewer does not show anyt Maya-related errors, warnings or anomalies
2) Maya does not start at all, so I can not change any viewport settings.
3) The Nvidia Quadro K2200 runs with the latest drivers (not Maya certified) - the Maya-certified drivers are not compatible with Windows 10
4) Disabling Antivirus Protection does not help.
Message 14 of 28
mortild
Autodesk Support
Autodesk Support
Hi @Anonymous
I see you are running Windows 10 Pro 1607. I would try to update Windows 10 to the latest version (1809), then try again.
If the issue persists, try the steps highlighted in this article and let us know how it goes.
Davide Mortillaro
Senior Technical Support Specialist
Installation and Licensing YouTube Channel | Up&Ready Webinars
Message 15 of 28
Hello Davide,
thank you for the hint. After creating the variable the output screen does not come up anymore, but beside that the problem remains.
I also tried resetting Windows to a prior state which failed. Now I consider a complete new Windows setup.
Message 16 of 28
mortild
Autodesk Support
Autodesk Support
Hi @Anonymous
Have you already tried to update Windows 10 to the latest build? Running older builds could lead to scenarios like the one you are seeing. I'd give Windows Update a try before re-imaging the system.
Davide Mortillaro
Message 17 of 28
Hello Davide,
I will try to update windows and then come back to you.
Message 18 of 28
This is a screenshot of what the task manager shows as background processes. The windows screen does not show anything.autodesk.JPGmaya.JPG
Message 19 of 28
I had my system being setup completely new.
The windows build now is 1803
I installed MAYA 2019 and it still has the same issue.
This is how it loos in the taskmanager, when Maya is started, but nothing actually happens.
If this problem cant be fixed soon I will definitely cancel all my subscriptions because this is a waste of money and time.
Message 20 of 28
mortild
Autodesk Support
Autodesk Support
@Anonymous since you have an active subscription, you are entitled to direct support.
From our systems, it seems that you already logged a support case. At any point in time you can ask for a remote session through the email that you received, and that will be sent to the support team taking care of that.
A remote session would be helpful for us to have a closer look.
Davide Mortillaro
