@Anonymous
Something must've happened with your related license files. You shouldn't have to request it again since your 3 yr license wouldn't have been expired yet.
Before requesting, reset your license by following these steps:
Please note, folders of C:\Programdata and C:\Users\[Username]\Appdata (listed below) are hidden folders and you may need to adjust your viewing settings.
First make sure you're signed out of the desktop app and A360 (both are located in your Windows system tray
On your computer, navigate to
2017 Version: C:\ProgramData\Autodesk\CLM\LGS\<Product_Key>_2017.0.0.F [<Product Key> is the product key of the application you have]
2018 Version: C:\ProgramData\Autodesk\CLM\LGS\<Product_Key>_2018.0.0.F [<Product Key> is the product key of the application you have]
Delete the LGS.data file.
Navigate to C:\Users\[username]\AppData\Roaming\Autodesk\ folder
Delete the ADUT folder and it's contents
When you start the application, it will prompt you to choose one (that matches your license) of the following:
Login - 30 day trial or CLIC (Cloud Based) licenses
Serial Number - Students, Standalone and Single-User Term Based activation
Network - Network License server for obtaining licenses from a machine on your network
Good luck and report back on your progress
Mark Lancaster
& Autodesk Services MarketPlace Provider
