Every time I try and install the software, I'm told that the installation has failed. The "Installation Log File" gives me this, but I don't know what to make of it:
2016/8/25:00:00:44 Briant WINDOWS-UAHHD1B === Setup started on WINDOWS-UAHHD1B by Briant ===
2016/8/25:00:00:44 Briant WINDOWS-UAHHD1B Path_Length: 141
2016/8/25:00:00:44 Briant WINDOWS-UAHHD1B Current Directory C:\Autodesk\Autodesk_Maya_2017_wi_en-US
2016/8/25:00:00:44 Briant WINDOWS-UAHHD1B Launch
2016/8/25:00:00:44 Briant WINDOWS-UAHHD1B CommandLine /PK 657I1 /SN 900-52180052 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/Autodesk_Maya_2017_wi_en-US_Setup.exe?dummy=0"
2016/8/25:00:00:44 Briant WINDOWS-UAHHD1B Current Directory C:\Users\Briant\AppData\Local\Temp\_AIC884.tmp
2016/8/25:00:01:30 Briant WINDOWS-UAHHD1B === Setup ended ===
2016/8/25:00:00:46 Briant WINDOWS-UAHHD1B === Setup started on WINDOWS-UAHHD1B by Briant ===
2016/8/25:00:00:46 Briant WINDOWS-UAHHD1B Path_Length: 141
2016/8/25:00:00:46 Briant WINDOWS-UAHHD1B Current Directory C:\Users\Briant\AppData\Local\Temp\_AIC884.tmp
2016/8/25:00:00:46 Briant WINDOWS-UAHHD1B Launch
2016/8/25:00:00:49 Briant WINDOWS-UAHHD1B Download Play SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUPMAR...
2016/8/25:00:00:50 Briant WINDOWS-UAHHD1B Download Complete SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUPMAR...
2016/8/25:00:00:51 Briant WINDOWS-UAHHD1B Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUP_x6...
2016/8/25:00:01:29 Briant WINDOWS-UAHHD1B Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUP_x6...
2016/8/25:00:01:31 Briant WINDOWS-UAHHD1B PageOpen LaunchDialog
2016/8/25:00:04:07 Briant WINDOWS-UAHHD1B PageOpen LicenseDialog
2016/8/25:00:04:07 Briant WINDOWS-UAHHD1B PageOpen ProductInfoDialog
2016/8/25:00:04:07 Briant WINDOWS-UAHHD1B PageOpen ProductSelectionDialog2
2016/8/25:00:06:52 Briant WINDOWS-UAHHD1B PageOpen FullProgressDialog
2016/8/25:00:06:53 Briant WINDOWS-UAHHD1B Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/STARTMAR...
2016/8/25:00:06:53 Briant WINDOWS-UAHHD1B Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/STARTMAR...
2016/8/25:00:06:53 Briant WINDOWS-UAHHD1B Download Play VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/8/25:00:06:57 Briant WINDOWS-UAHHD1B Download Complete VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/8/25:00:06:57 Briant WINDOWS-UAHHD1B Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2017\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/8/25:00:07:29 Briant WINDOWS-UAHHD1B Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/8/25:00:07:29 Briant WINDOWS-UAHHD1B Download Play VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/8/25:00:07:34 Briant WINDOWS-UAHHD1B Download Complete VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/8/25:00:07:34 Briant WINDOWS-UAHHD1B Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2017\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/8/25:00:07:35 Briant WINDOWS-UAHHD1B Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/8/25:00:07:35 Briant WINDOWS-UAHHD1B Installing Autodesk Licensing Manager: TRANSFORMS="C:\Users\Briant\AppData\Local\Temp\_AIC884.tmp\x64\CLIC\CLIC_x64_Release-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Maya 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/8/25:00:08:08 Briant WINDOWS-UAHHD1B Install Autodesk Licensing Manager Succeeded
2016/8/25:00:08:08 Briant WINDOWS-UAHHD1B Download Play MAYA http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/MAYA_en-...
2016/8/25:00:12:44 Briant WINDOWS-UAHHD1B Download Aborted MAYA http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/MAYA_en-...
2016/8/25:00:12:44 Briant WINDOWS-UAHHD1B Install Autodesk® Maya® 2017 Failed Download Failed, Installation aborted, Result=1603
2016/8/25:00:13:00 Briant WINDOWS-UAHHD1B Rollback Autodesk Licensing Manager Succeeded
2016/8/25:00:13:00 Briant WINDOWS-UAHHD1B Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2016/8/25:00:13:00 Briant WINDOWS-UAHHD1B Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/8/25:00:13:00 Briant WINDOWS-UAHHD1B PageOpen InstallCompleteDialog
2016/8/25:00:15:07 Briant WINDOWS-UAHHD1B === Setup ended ===
2016/8/25:00:15:44 Briant WINDOWS-UAHHD1B === Setup started on WINDOWS-UAHHD1B by Briant ===
If anyone has any sort of clue on how to help me, it would be really appreciated.
Solved by natasha.l. Go to Solution.
Hello Briant918,
I know it's been awhile since you posted, but I would like to reply to help anyone that may stumble upon this thread in the future.
You seem to be having an issue with the install of Maya 2017.
Thank you for the install log it seems C++ is the issue, I would uninstall the Microsoft C++ on the machine in this case, 2010, 12, 13 and 15.
Then, install Maya 2017 and it will replace the C++ and hopefully install.
I hope this answered your question or resolved the issue, if so please click Kudos or the "thumbs-up!" Did my response help resolve the issue? Please "Accept As Solution" to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Hey I had the same problem as the other guy. However, you suggestion didn't work for me. Here is the code that it shows me.
Instillation log:
2016/10/22:19:02:22 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:19:02:22 King PAPASMURF Path_Length: 141
2016/10/22:19:02:22 King PAPASMURF Current Directory C:\Autodesk\Autodesk_Maya_2017_wi_en-US
2016/10/22:19:02:22 King PAPASMURF Launch
2016/10/22:19:02:22 King PAPASMURF CommandLine /PK 657I1 /SN 900-71267896 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/Autodesk_Maya_2017_wi_en-US_Setup.exe?dummy=0"
2016/10/22:19:02:22 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AIEEA0.tmp
2016/10/22:19:03:12 King PAPASMURF === Setup ended ===
2016/10/22:19:02:23 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:19:02:23 King PAPASMURF Path_Length: 141
2016/10/22:19:02:23 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AIEEA0.tmp
2016/10/22:19:02:23 King PAPASMURF Launch
2016/10/22:19:02:27 King PAPASMURF Download Play SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUPMAR...
2016/10/22:19:02:27 King PAPASMURF Download Complete SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUPMAR...
2016/10/22:19:02:28 King PAPASMURF Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUP_x6...
2016/10/22:19:03:11 King PAPASMURF Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUP_x6...
2016/10/22:19:03:13 King PAPASMURF PageOpen LaunchDialog
2016/10/22:19:03:49 King PAPASMURF PageOpen LicenseDialog
2016/10/22:19:03:49 King PAPASMURF PageOpen ProductInfoDialog
2016/10/22:19:03:49 King PAPASMURF PageOpen ProductSelectionDialog2
2016/10/22:19:03:55 King PAPASMURF PageOpen FullProgressDialog
2016/10/22:19:03:55 King PAPASMURF Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/STARTMAR...
2016/10/22:19:03:55 King PAPASMURF Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/STARTMAR...
2016/10/22:19:03:56 King PAPASMURF Download Play VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/10/22:19:03:59 King PAPASMURF Download Complete VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/10/22:19:03:59 King PAPASMURF Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2017\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/10/22:19:05:29 King PAPASMURF Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/10/22:19:05:30 King PAPASMURF Download Play VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/10/22:19:05:34 King PAPASMURF Download Complete VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/10/22:19:05:34 King PAPASMURF Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2017\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/10/22:19:06:13 King PAPASMURF Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/10/22:19:06:14 King PAPASMURF Installing Autodesk Licensing Manager: TRANSFORMS="C:\Users\King\AppData\Local\Temp\_AIEEA0.tmp\x64\CLIC\CLIC_x64_Release-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Maya 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/10/22:19:06:17 King PAPASMURF Install Autodesk Licensing Manager Failed Installation aborted, Result=1618
2016/10/22:19:06:20 King PAPASMURF Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1618
2016/10/22:19:06:23 King PAPASMURF Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1618
2016/10/22:19:06:24 King PAPASMURF PageOpen InstallCompleteDialog
2016/10/22:19:06:53 King PAPASMURF === Setup ended ===
2016/10/22:19:07:50 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:19:07:50 King PAPASMURF Path_Length: 141
2016/10/22:19:07:50 King PAPASMURF Current Directory C:\Autodesk\Autodesk_Maya_2017_wi_en-US
2016/10/22:19:07:50 King PAPASMURF Launch
2016/10/22:19:07:50 King PAPASMURF CommandLine /PK 657I1 /SN 900-71267896 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/Autodesk_Maya_2017_wi_en-US_Setup.exe?dummy=0"
2016/10/22:19:07:50 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AIF61A.tmp
2016/10/22:19:07:54 King PAPASMURF === Setup ended ===
2016/10/22:19:07:53 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:19:07:53 King PAPASMURF Path_Length: 141
2016/10/22:19:07:53 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AIF61A.tmp
2016/10/22:19:07:53 King PAPASMURF Launch
2016/10/22:19:07:54 King PAPASMURF Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUPMAR...
2016/10/22:19:07:54 King PAPASMURF Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUP_x6...
2016/10/22:19:07:55 King PAPASMURF PageOpen LaunchDialog
2016/10/22:19:08:09 King PAPASMURF PageOpen LicenseDialog
2016/10/22:19:08:09 King PAPASMURF PageOpen ProductSelectionDialog2
2016/10/22:19:09:30 King PAPASMURF PageOpen LicenseDialog
2016/10/22:19:09:30 King PAPASMURF PageOpen LaunchDialog
2016/10/22:19:09:34 King PAPASMURF === Setup ended ===
2016/10/22:19:43:19 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:19:43:19 King PAPASMURF Path_Length: 141
2016/10/22:19:43:19 King PAPASMURF Current Directory C:\Autodesk\Autodesk_Maya_2017_wi_en-US
2016/10/22:19:43:19 King PAPASMURF Launch
2016/10/22:19:43:19 King PAPASMURF CommandLine
2016/10/22:19:43:19 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AIAE4E.tmp
2016/10/22:19:43:44 King PAPASMURF === Setup ended ===
2016/10/22:19:43:22 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:19:43:22 King PAPASMURF Path_Length: 141
2016/10/22:19:43:22 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AIAE4E.tmp
2016/10/22:19:43:22 King PAPASMURF Launch
2016/10/22:19:43:45 King PAPASMURF === Setup ended ===
2016/10/22:19:44:39 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:19:44:39 King PAPASMURF Path_Length: 141
2016/10/22:19:44:39 King PAPASMURF Current Directory C:\Autodesk\Autodesk_Maya_2017_wi_en-US
2016/10/22:19:44:39 King PAPASMURF Launch
2016/10/22:19:44:39 King PAPASMURF CommandLine
2016/10/22:19:44:39 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AIE71C.tmp
2016/10/22:19:44:45 King PAPASMURF === Setup ended ===
2016/10/22:19:44:42 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:19:44:42 King PAPASMURF Path_Length: 141
2016/10/22:19:44:42 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AIE71C.tmp
2016/10/22:19:44:42 King PAPASMURF Launch
2016/10/22:19:44:46 King PAPASMURF === Setup ended ===
2016/10/22:19:46:18 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:19:46:18 King PAPASMURF Path_Length: 141
2016/10/22:19:46:18 King PAPASMURF Current Directory C:\Autodesk\Autodesk_Maya_2017_wi_en-US
2016/10/22:19:46:18 King PAPASMURF Launch
2016/10/22:19:46:18 King PAPASMURF CommandLine
2016/10/22:19:46:18 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AI6996.tmp
2016/10/22:19:46:29 King PAPASMURF === Setup ended ===
2016/10/22:19:46:20 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:19:46:20 King PAPASMURF Path_Length: 141
2016/10/22:19:46:20 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AI6996.tmp
2016/10/22:19:46:20 King PAPASMURF Launch
2016/10/22:19:46:30 King PAPASMURF === Setup ended ===
2016/10/22:19:46:51 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:19:46:51 King PAPASMURF Path_Length: 141
2016/10/22:19:46:51 King PAPASMURF Current Directory C:\Autodesk\Autodesk_Maya_2017_wi_en-US
2016/10/22:19:46:51 King PAPASMURF Launch
2016/10/22:19:46:51 King PAPASMURF CommandLine /PK 657I1 /SN 900-71267896 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/Autodesk_Maya_2017_wi_en-US_Setup.exe?dummy=0"
2016/10/22:19:46:51 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AIEA8D.tmp
2016/10/22:19:46:54 King PAPASMURF === Setup ended ===
2016/10/22:19:46:53 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:19:46:53 King PAPASMURF Path_Length: 141
2016/10/22:19:46:53 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AIEA8D.tmp
2016/10/22:19:46:53 King PAPASMURF Launch
2016/10/22:19:46:53 King PAPASMURF Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUPMAR...
2016/10/22:19:46:53 King PAPASMURF Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUP_x6...
2016/10/22:19:46:54 King PAPASMURF PageOpen LaunchDialog
2016/10/22:19:47:01 King PAPASMURF PageOpen LicenseDialog
2016/10/22:19:47:01 King PAPASMURF PageOpen ProductInfoDialog
2016/10/22:19:47:01 King PAPASMURF PageOpen ProductSelectionDialog2
2016/10/22:19:47:05 King PAPASMURF PageOpen FullProgressDialog
2016/10/22:19:47:05 King PAPASMURF Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/STARTMAR...
2016/10/22:19:47:05 King PAPASMURF Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/STARTMAR...
2016/10/22:19:47:06 King PAPASMURF Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/10/22:19:47:06 King PAPASMURF Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2017\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/10/22:19:47:07 King PAPASMURF Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/10/22:19:47:07 King PAPASMURF Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/10/22:19:47:07 King PAPASMURF Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2017\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/10/22:19:47:08 King PAPASMURF Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/10/22:19:47:08 King PAPASMURF Installing Autodesk Licensing Manager: TRANSFORMS="C:\Users\King\AppData\Local\Temp\_AIEA8D.tmp\x64\CLIC\CLIC_x64_Release-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Maya 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/10/22:19:47:40 King PAPASMURF Install Autodesk Licensing Manager Succeeded
2016/10/22:19:47:40 King PAPASMURF Download Play MAYA http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/MAYA_en-...
2016/10/22:19:53:42 King PAPASMURF Download Aborted MAYA http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/MAYA_en-...
2016/10/22:19:53:42 King PAPASMURF Install Autodesk® Maya® 2017 Failed Download Failed, Installation aborted, Result=1603
2016/10/22:19:54:03 King PAPASMURF Rollback Autodesk Licensing Manager Succeeded
2016/10/22:19:54:04 King PAPASMURF Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2016/10/22:19:54:04 King PAPASMURF Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/10/22:19:54:06 King PAPASMURF PageOpen InstallCompleteDialog
2016/10/22:19:55:13 King PAPASMURF === Setup ended ===
2016/10/22:19:56:02 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:19:56:02 King PAPASMURF Path_Length: 141
2016/10/22:19:56:02 King PAPASMURF Current Directory C:\Autodesk\Autodesk_Maya_2017_wi_en-US
2016/10/22:19:56:02 King PAPASMURF Launch
2016/10/22:19:56:02 King PAPASMURF CommandLine
2016/10/22:19:56:02 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AI53EF.tmp
2016/10/22:19:56:08 King PAPASMURF === Setup ended ===
2016/10/22:19:56:06 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:19:56:06 King PAPASMURF Path_Length: 141
2016/10/22:19:56:06 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AI53EF.tmp
2016/10/22:19:56:06 King PAPASMURF Launch
2016/10/22:19:56:09 King PAPASMURF === Setup ended ===
2016/10/22:20:03:18 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:20:03:18 King PAPASMURF Path_Length: 141
2016/10/22:20:03:18 King PAPASMURF Current Directory C:\Autodesk\Autodesk_Maya_2017_wi_en-US
2016/10/22:20:03:18 King PAPASMURF Launch
2016/10/22:20:03:18 King PAPASMURF CommandLine
2016/10/22:20:03:18 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AIF979.tmp
2016/10/22:20:03:21 King PAPASMURF === Setup ended ===
2016/10/22:20:03:19 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:20:03:19 King PAPASMURF Path_Length: 141
2016/10/22:20:03:19 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AIF979.tmp
2016/10/22:20:03:19 King PAPASMURF Launch
2016/10/22:20:03:22 King PAPASMURF === Setup ended ===
2016/10/22:20:04:16 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:20:04:16 King PAPASMURF Path_Length: 141
2016/10/22:20:04:16 King PAPASMURF Current Directory C:\Autodesk\Autodesk_Maya_2017_wi_en-US
2016/10/22:20:04:16 King PAPASMURF Launch
2016/10/22:20:04:16 King PAPASMURF CommandLine /PK 657I1 /SN 900-71267896 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/Autodesk_Maya_2017_wi_en-US_Setup.exe?dummy=0"
2016/10/22:20:04:16 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AIDCF3.tmp
2016/10/22:20:04:19 King PAPASMURF === Setup ended ===
2016/10/22:20:04:17 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:20:04:17 King PAPASMURF Path_Length: 141
2016/10/22:20:04:17 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AIDCF3.tmp
2016/10/22:20:04:17 King PAPASMURF Launch
2016/10/22:20:04:17 King PAPASMURF Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUPMAR...
2016/10/22:20:04:18 King PAPASMURF Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUP_x6...
2016/10/22:20:04:19 King PAPASMURF PageOpen LaunchDialog
2016/10/22:20:04:23 King PAPASMURF PageOpen LicenseDialog
2016/10/22:20:04:23 King PAPASMURF PageOpen ProductSelectionDialog2
2016/10/22:20:04:26 King PAPASMURF PageOpen FullProgressDialog
2016/10/22:20:04:26 King PAPASMURF Installing Network License Manager: INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Maya 2017" SETUP_PACKAGECODE={2E884651-81E9-412F-8B85-AC874EB7821F} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={7FEA4127-8815-424C-98BB-39D4113F5F62} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Maya 2017" INSTALLDIR="C:\Program Files\Autodesk Network License Manager\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/10/22:20:04:28 King PAPASMURF Install Network License Manager Succeeded
2016/10/22:20:04:28 King PAPASMURF Download Play SUCCESSMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SUCCESSM...
2016/10/22:20:04:28 King PAPASMURF Download Complete SUCCESSMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SUCCESSM...
2016/10/22:20:04:28 King PAPASMURF PageOpen InstallCompleteDialog
2016/10/22:20:04:32 King PAPASMURF === Setup ended ===
2016/10/22:20:04:45 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:20:04:45 King PAPASMURF Path_Length: 141
2016/10/22:20:04:45 King PAPASMURF Current Directory C:\Autodesk\Autodesk_Maya_2017_wi_en-US
2016/10/22:20:04:45 King PAPASMURF Launch
2016/10/22:20:04:45 King PAPASMURF CommandLine /PK 657I1 /SN 900-71267896 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/Autodesk_Maya_2017_wi_en-US_Setup.exe?dummy=0"
2016/10/22:20:04:45 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AI503F.tmp
2016/10/22:20:04:47 King PAPASMURF === Setup ended ===
2016/10/22:20:04:46 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:20:04:46 King PAPASMURF Path_Length: 141
2016/10/22:20:04:46 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AI503F.tmp
2016/10/22:20:04:46 King PAPASMURF Launch
2016/10/22:20:04:46 King PAPASMURF Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUPMAR...
2016/10/22:20:04:46 King PAPASMURF Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUP_x6...
2016/10/22:20:04:47 King PAPASMURF PageOpen LaunchDialog
2016/10/22:20:04:54 King PAPASMURF PageOpen LicenseDialog
2016/10/22:20:04:54 King PAPASMURF PageOpen ProductInfoDialog
2016/10/22:20:04:54 King PAPASMURF PageOpen ProductSelectionDialog2
2016/10/22:20:05:12 King PAPASMURF PageOpen FullProgressDialog
2016/10/22:20:05:13 King PAPASMURF Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/STARTMAR...
2016/10/22:20:05:13 King PAPASMURF Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/STARTMAR...
2016/10/22:20:05:13 King PAPASMURF Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/10/22:20:05:13 King PAPASMURF Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2017\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/10/22:20:05:15 King PAPASMURF Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/10/22:20:05:15 King PAPASMURF Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/10/22:20:05:15 King PAPASMURF Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2017\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/10/22:20:05:16 King PAPASMURF Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/10/22:20:05:16 King PAPASMURF Installing Autodesk Licensing Manager: TRANSFORMS="C:\Users\King\AppData\Local\Temp\_AI503F.tmp\x64\CLIC\CLIC_x64_Release-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Maya 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/10/22:20:05:36 King PAPASMURF Install Autodesk Licensing Manager Succeeded
2016/10/22:20:05:36 King PAPASMURF Download Play MAYA http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/MAYA_en-...
2016/10/22:20:10:59 King PAPASMURF Download Aborted MAYA http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/MAYA_en-...
2016/10/22:20:10:59 King PAPASMURF Install Autodesk® Maya® 2017 Failed Download Failed, Installation aborted, Result=1603
2016/10/22:20:11:17 King PAPASMURF Rollback Autodesk Licensing Manager Succeeded
2016/10/22:20:11:17 King PAPASMURF Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2016/10/22:20:11:17 King PAPASMURF Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/10/22:20:11:18 King PAPASMURF PageOpen InstallCompleteDialog
2016/10/22:20:12:07 King PAPASMURF === Setup ended ===
2016/10/22:20:24:00 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:20:24:00 King PAPASMURF Path_Length: 141
2016/10/22:20:24:00 King PAPASMURF Current Directory C:\Autodesk\Autodesk_Maya_2017_wi_en-US
2016/10/22:20:24:00 King PAPASMURF Launch
2016/10/22:20:24:00 King PAPASMURF CommandLine /PK 657I1 /SN 900-71267896 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/Autodesk_Maya_2017_wi_en-US_Setup.exe?dummy=0"
2016/10/22:20:24:00 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AIA1D6.tmp
2016/10/22:20:24:03 King PAPASMURF === Setup ended ===
2016/10/22:20:24:01 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:20:24:01 King PAPASMURF Path_Length: 141
2016/10/22:20:24:01 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AIA1D6.tmp
2016/10/22:20:24:01 King PAPASMURF Launch
2016/10/22:20:24:02 King PAPASMURF Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUPMAR...
2016/10/22:20:24:02 King PAPASMURF Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUP_x6...
2016/10/22:20:24:03 King PAPASMURF PageOpen LaunchDialog
2016/10/22:20:24:13 King PAPASMURF PageOpen LicenseDialog
2016/10/22:20:24:13 King PAPASMURF PageOpen ProductInfoDialog
2016/10/22:20:24:13 King PAPASMURF PageOpen ProductSelectionDialog2
2016/10/22:20:27:24 King PAPASMURF PageOpen ProductInfoDialog
2016/10/22:20:27:24 King PAPASMURF PageOpen LicenseDialog
2016/10/22:20:27:24 King PAPASMURF PageOpen LaunchDialog
2016/10/22:20:27:25 King PAPASMURF PageOpen LicenseDialog
2016/10/22:20:27:25 King PAPASMURF PageOpen ProductInfoDialog
2016/10/22:20:27:25 King PAPASMURF PageOpen ProductSelectionDialog2
2016/10/22:20:29:58 King PAPASMURF === Setup ended ===
2016/10/22:20:30:31 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:20:30:31 King PAPASMURF Path_Length: 141
2016/10/22:20:30:31 King PAPASMURF Current Directory C:\Autodesk\Autodesk_Maya_2017_wi_en-US
2016/10/22:20:30:31 King PAPASMURF Launch
2016/10/22:20:30:31 King PAPASMURF CommandLine /PK 657I1 /SN 900-71267896 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/Autodesk_Maya_2017_wi_en-US_Setup.exe?dummy=0"
2016/10/22:20:30:31 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AI994E.tmp
2016/10/22:20:30:32 King PAPASMURF === Setup ended ===
2016/10/22:20:30:32 King PAPASMURF Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUPMAR...
2016/10/22:20:30:32 King PAPASMURF Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUP_x6...
2016/10/22:20:30:32 King PAPASMURF PageOpen LaunchDialog
2016/10/22:20:30:38 King PAPASMURF PageOpen LicenseDialog
2016/10/22:20:30:38 King PAPASMURF PageOpen ProductInfoDialog
2016/10/22:20:30:38 King PAPASMURF PageOpen ProductSelectionDialog2
2016/10/22:20:30:55 King PAPASMURF === Setup ended ===
2016/10/22:20:31:35 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:20:31:35 King PAPASMURF Path_Length: 141
2016/10/22:20:31:35 King PAPASMURF Current Directory C:\Autodesk\Autodesk_Maya_2017_wi_en-US
2016/10/22:20:31:35 King PAPASMURF Launch
2016/10/22:20:31:35 King PAPASMURF CommandLine /PK 657I1 /SN 900-71267896 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/Autodesk_Maya_2017_wi_en-US_Setup.exe?dummy=0"
2016/10/22:20:31:35 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AI939C.tmp
2016/10/22:20:31:37 King PAPASMURF === Setup ended ===
2016/10/22:20:31:36 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:20:31:36 King PAPASMURF Path_Length: 141
2016/10/22:20:31:36 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AI939C.tmp
2016/10/22:20:31:36 King PAPASMURF Launch
2016/10/22:20:31:36 King PAPASMURF Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUPMAR...
2016/10/22:20:31:36 King PAPASMURF Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUP_x6...
2016/10/22:20:31:36 King PAPASMURF PageOpen LaunchDialog
2016/10/22:20:31:42 King PAPASMURF PageOpen LicenseDialog
2016/10/22:20:31:42 King PAPASMURF PageOpen ProductInfoDialog
2016/10/22:20:31:42 King PAPASMURF PageOpen ProductSelectionDialog2
2016/10/22:20:36:39 King PAPASMURF PageOpen ProductInfoDialog
2016/10/22:20:36:39 King PAPASMURF PageOpen LicenseDialog
2016/10/22:20:36:39 King PAPASMURF PageOpen LaunchDialog
2016/10/22:20:36:41 King PAPASMURF PageOpen LicenseDialog
2016/10/22:20:36:41 King PAPASMURF PageOpen ProductSelectionDialog2
2016/10/22:20:36:44 King PAPASMURF PageOpen LicenseDialog
2016/10/22:20:36:44 King PAPASMURF PageOpen LaunchDialog
2016/10/22:20:37:23 King PAPASMURF PageOpen LicenseDialog
2016/10/22:20:37:23 King PAPASMURF PageOpen ProductInfoDialog
2016/10/22:20:37:23 King PAPASMURF PageOpen ProductSelectionDialog2
2016/10/22:20:43:12 King PAPASMURF PageOpen ProductInfoDialog
2016/10/22:20:43:12 King PAPASMURF PageOpen LicenseDialog
2016/10/22:20:43:12 King PAPASMURF PageOpen LaunchDialog
2016/10/22:20:43:21 King PAPASMURF === Setup ended ===
2016/10/22:20:44:22 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:20:44:22 King PAPASMURF Path_Length: 141
2016/10/22:20:44:22 King PAPASMURF Current Directory C:\Autodesk\Autodesk_Maya_2017_wi_en-US
2016/10/22:20:44:22 King PAPASMURF Launch
2016/10/22:20:44:22 King PAPASMURF CommandLine /PK 657I1 /SN 900-71267896 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/Autodesk_Maya_2017_wi_en-US_Setup.exe?dummy=0"
2016/10/22:20:44:22 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AI47E3.tmp
2016/10/22:20:44:23 King PAPASMURF === Setup ended ===
2016/10/22:20:44:23 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:20:44:23 King PAPASMURF Path_Length: 141
2016/10/22:20:44:23 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AI47E3.tmp
2016/10/22:20:44:23 King PAPASMURF Launch
2016/10/22:20:44:23 King PAPASMURF Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUPMAR...
2016/10/22:20:44:23 King PAPASMURF Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUP_x6...
2016/10/22:20:44:23 King PAPASMURF PageOpen LaunchDialog
2016/10/22:20:44:34 King PAPASMURF PageOpen LicenseDialog
2016/10/22:20:44:34 King PAPASMURF PageOpen ProductInfoDialog
2016/10/22:20:44:34 King PAPASMURF PageOpen ProductSelectionDialog2
2016/10/22:20:44:49 King PAPASMURF === Setup ended ===
2016/10/22:22:39:48 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:22:39:48 King PAPASMURF Path_Length: 141
2016/10/22:22:39:48 King PAPASMURF Current Directory C:\Autodesk\Autodesk_Maya_2017_wi_en-US
2016/10/22:22:39:48 King PAPASMURF Launch
2016/10/22:22:39:48 King PAPASMURF CommandLine /PK 657I1 /SN 900-71267896 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/Autodesk_Maya_2017_wi_en-US_Setup.exe?dummy=0"
2016/10/22:22:39:48 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AIF7AC.tmp
2016/10/22:22:39:51 King PAPASMURF === Setup ended ===
2016/10/22:22:39:49 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:22:39:49 King PAPASMURF Path_Length: 141
2016/10/22:22:39:49 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AIF7AC.tmp
2016/10/22:22:39:49 King PAPASMURF Launch
2016/10/22:22:39:50 King PAPASMURF Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUPMAR...
2016/10/22:22:39:50 King PAPASMURF Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUP_x6...
2016/10/22:22:39:51 King PAPASMURF PageOpen LaunchDialog
2016/10/22:22:39:57 King PAPASMURF PageOpen LicenseDialog
2016/10/22:22:39:57 King PAPASMURF PageOpen ProductInfoDialog
2016/10/22:22:39:57 King PAPASMURF PageOpen ProductSelectionDialog2
2016/10/22:22:40:17 King PAPASMURF === Setup ended ===
2016/10/22:22:52:16 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:22:52:16 King PAPASMURF Path_Length: 141
2016/10/22:22:52:16 King PAPASMURF Current Directory C:\Autodesk\Autodesk_Maya_2017_wi_en-US
2016/10/22:22:52:16 King PAPASMURF Launch
2016/10/22:22:52:16 King PAPASMURF CommandLine /PK 657I1 /SN 900-71267896 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/Autodesk_Maya_2017_wi_en-US_Setup.exe?dummy=0"
2016/10/22:22:52:16 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AI3DC3.tmp
2016/10/22:22:52:18 King PAPASMURF === Setup ended ===
2016/10/22:22:52:17 King PAPASMURF Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUPMAR...
2016/10/22:22:52:17 King PAPASMURF Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUP_x6...
2016/10/22:22:52:18 King PAPASMURF PageOpen LaunchDialog
2016/10/22:22:52:25 King PAPASMURF PageOpen LicenseDialog
2016/10/22:22:52:25 King PAPASMURF PageOpen ProductInfoDialog
2016/10/22:22:52:25 King PAPASMURF PageOpen ProductSelectionDialog2
2016/10/22:22:52:27 King PAPASMURF PageOpen FullProgressDialog
2016/10/22:22:52:28 King PAPASMURF Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/STARTMAR...
2016/10/22:22:52:28 King PAPASMURF Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/STARTMAR...
2016/10/22:22:52:28 King PAPASMURF Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/10/22:22:52:28 King PAPASMURF Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2017\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/10/22:22:52:33 King PAPASMURF Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/10/22:22:52:33 King PAPASMURF Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/10/22:22:52:33 King PAPASMURF Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2017\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/10/22:22:52:34 King PAPASMURF Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/10/22:22:52:34 King PAPASMURF Installing Autodesk Licensing Manager: TRANSFORMS="C:\Users\King\AppData\Local\Temp\_AI3DC3.tmp\x64\CLIC\CLIC_x64_Release-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Maya 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/10/22:22:52:53 King PAPASMURF Install Autodesk Licensing Manager Succeeded
2016/10/22:22:52:53 King PAPASMURF Download Play MAYA http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/MAYA_en-...
2016/10/22:22:58:59 King PAPASMURF Download Aborted MAYA http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/MAYA_en-...
2016/10/22:22:58:59 King PAPASMURF Install Autodesk® Maya® 2017 Failed Download Failed, Installation aborted, Result=1603
2016/10/22:22:59:20 King PAPASMURF Rollback Autodesk Licensing Manager Succeeded
2016/10/22:22:59:21 King PAPASMURF Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2016/10/22:22:59:21 King PAPASMURF Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/10/22:22:59:21 King PAPASMURF PageOpen InstallCompleteDialog
2016/10/22:22:59:51 King PAPASMURF === Setup ended ===
2016/10/22:23:06:27 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:23:06:27 King PAPASMURF Path_Length: 141
2016/10/22:23:06:27 King PAPASMURF Current Directory C:\Autodesk\Autodesk_Maya_2017_wi_en-US
2016/10/22:23:06:27 King PAPASMURF Launch
2016/10/22:23:06:27 King PAPASMURF CommandLine /PK 657I1 /SN 900-71267896 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/Autodesk_Maya_2017_wi_en-US_Setup.exe?dummy=0"
2016/10/22:23:06:27 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AI3CBB.tmp
2016/10/22:23:06:30 King PAPASMURF === Setup ended ===
2016/10/22:23:06:28 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:23:06:28 King PAPASMURF Path_Length: 141
2016/10/22:23:06:28 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AI3CBB.tmp
2016/10/22:23:06:28 King PAPASMURF Launch
2016/10/22:23:06:29 King PAPASMURF Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUPMAR...
2016/10/22:23:06:29 King PAPASMURF Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUP_x6...
2016/10/22:23:06:30 King PAPASMURF PageOpen LaunchDialog
2016/10/22:23:06:40 King PAPASMURF PageOpen LicenseDialog
2016/10/22:23:06:40 King PAPASMURF PageOpen ProductInfoDialog
2016/10/22:23:06:40 King PAPASMURF PageOpen ProductSelectionDialog2
2016/10/22:23:06:43 King PAPASMURF PageOpen FullProgressDialog
2016/10/22:23:06:44 King PAPASMURF Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/STARTMAR...
2016/10/22:23:06:44 King PAPASMURF Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/STARTMAR...
2016/10/22:23:06:44 King PAPASMURF Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/10/22:23:06:44 King PAPASMURF Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2017\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/10/22:23:06:46 King PAPASMURF Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/10/22:23:06:46 King PAPASMURF Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/10/22:23:06:46 King PAPASMURF Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2017\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/10/22:23:06:46 King PAPASMURF Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/10/22:23:06:47 King PAPASMURF Installing Autodesk Licensing Manager: TRANSFORMS="C:\Users\King\AppData\Local\Temp\_AI3CBB.tmp\x64\CLIC\CLIC_x64_Release-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Maya 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/10/22:23:07:06 King PAPASMURF Install Autodesk Licensing Manager Succeeded
2016/10/22:23:07:06 King PAPASMURF Download Play MAYA http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/MAYA_en-...
2016/10/22:23:13:38 King PAPASMURF Download Aborted MAYA http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/MAYA_en-...
2016/10/22:23:13:38 King PAPASMURF Install Autodesk® Maya® 2017 Failed Download Failed, Installation aborted, Result=1603
2016/10/22:23:13:59 King PAPASMURF Rollback Autodesk Licensing Manager Succeeded
2016/10/22:23:13:59 King PAPASMURF Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2016/10/22:23:13:59 King PAPASMURF Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/10/22:23:14:00 King PAPASMURF PageOpen InstallCompleteDialog
2016/10/22:23:14:41 King PAPASMURF === Setup ended ===
2016/10/22:23:32:29 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:23:32:29 King PAPASMURF Path_Length: 141
2016/10/22:23:32:29 King PAPASMURF Current Directory C:\Autodesk\Autodesk_Maya_2017_wi_en-US
2016/10/22:23:32:29 King PAPASMURF Launch
2016/10/22:23:32:29 King PAPASMURF CommandLine /PK 657I1 /SN 900-71267896 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/Autodesk_Maya_2017_wi_en-US_Setup.exe?dummy=0"
2016/10/22:23:32:29 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AI87C.tmp
2016/10/22:23:32:32 King PAPASMURF === Setup ended ===
2016/10/22:23:32:31 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:23:32:31 King PAPASMURF Path_Length: 141
2016/10/22:23:32:31 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AI87C.tmp
2016/10/22:23:32:31 King PAPASMURF Launch
2016/10/22:23:32:31 King PAPASMURF Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUPMAR...
2016/10/22:23:32:31 King PAPASMURF Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUP_x6...
2016/10/22:23:32:32 King PAPASMURF PageOpen LaunchDialog
2016/10/22:23:33:00 King PAPASMURF PageOpen LicenseDialog
2016/10/22:23:33:00 King PAPASMURF PageOpen ProductInfoDialog
2016/10/22:23:33:00 King PAPASMURF PageOpen ProductSelectionDialog2
2016/10/22:23:33:27 King PAPASMURF PageOpen FullProgressDialog
2016/10/22:23:33:27 King PAPASMURF Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/STARTMAR...
2016/10/22:23:33:28 King PAPASMURF Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/STARTMAR...
2016/10/22:23:33:28 King PAPASMURF Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/10/22:23:33:28 King PAPASMURF Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2017\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/10/22:23:33:33 King PAPASMURF Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/10/22:23:33:33 King PAPASMURF Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/10/22:23:33:33 King PAPASMURF Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2017\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/10/22:23:33:33 King PAPASMURF Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/10/22:23:33:33 King PAPASMURF Installing Autodesk Licensing Manager: TRANSFORMS="C:\Users\King\AppData\Local\Temp\_AI87C.tmp\x64\CLIC\CLIC_x64_Release-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Maya 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/10/22:23:33:54 King PAPASMURF Install Autodesk Licensing Manager Succeeded
2016/10/22:23:33:54 King PAPASMURF Download Play MAYA http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/MAYA_en-...
2016/10/22:23:39:03 King PAPASMURF Download Aborted MAYA http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/MAYA_en-...
2016/10/22:23:39:03 King PAPASMURF Install Autodesk® Maya® 2017 Failed Download Failed, Installation aborted, Result=1603
2016/10/22:23:39:49 King PAPASMURF Rollback Autodesk Licensing Manager Succeeded
2016/10/22:23:39:49 King PAPASMURF Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2016/10/22:23:39:49 King PAPASMURF Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/10/22:23:39:50 King PAPASMURF PageOpen InstallCompleteDialog
2016/10/22:23:51:35 King PAPASMURF === Setup ended ===
2016/10/22:23:52:38 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:23:52:38 King PAPASMURF Path_Length: 141
2016/10/22:23:52:38 King PAPASMURF Current Directory C:\Autodesk\Autodesk_Maya_2017_wi_en-US
2016/10/22:23:52:38 King PAPASMURF Launch
2016/10/22:23:52:38 King PAPASMURF CommandLine /PK 657I1 /SN 900-71267896 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/Autodesk_Maya_2017_wi_en-US_Setup.exe?dummy=0"
2016/10/22:23:52:38 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AI721C.tmp
2016/10/22:23:52:47 King PAPASMURF === Setup ended ===
2016/10/22:23:52:40 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/22:23:52:40 King PAPASMURF Path_Length: 141
2016/10/22:23:52:40 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AI721C.tmp
2016/10/22:23:52:40 King PAPASMURF Launch
2016/10/22:23:52:41 King PAPASMURF Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUPMAR...
2016/10/22:23:52:41 King PAPASMURF Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUP_x6...
2016/10/22:23:52:47 King PAPASMURF PageOpen LaunchDialog
2016/10/22:23:53:05 King PAPASMURF PageOpen LicenseDialog
2016/10/22:23:53:05 King PAPASMURF PageOpen ProductInfoDialog
2016/10/22:23:53:05 King PAPASMURF PageOpen ProductSelectionDialog2
2016/10/22:23:53:09 King PAPASMURF PageOpen FullProgressDialog
2016/10/22:23:53:10 King PAPASMURF Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/STARTMAR...
2016/10/22:23:53:10 King PAPASMURF Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/STARTMAR...
2016/10/22:23:53:11 King PAPASMURF Download Play VCREDIST2010SP1X86 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/10/22:23:53:14 King PAPASMURF Download Complete VCREDIST2010SP1X86 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/10/22:23:53:14 King PAPASMURF Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2017\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart
2016/10/22:23:53:28 King PAPASMURF Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2016/10/22:23:53:28 King PAPASMURF Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/10/22:23:53:28 King PAPASMURF Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2017\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/10/22:23:53:38 King PAPASMURF Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/10/22:23:53:38 King PAPASMURF Download Play VCREDIST2010SP1X64 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/10/22:23:53:42 King PAPASMURF Download Complete VCREDIST2010SP1X64 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/10/22:23:53:42 King PAPASMURF Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2017\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart
2016/10/22:23:53:52 King PAPASMURF Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2016/10/22:23:53:52 King PAPASMURF Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/10/22:23:53:52 King PAPASMURF Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2017\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/10/22:23:53:56 King PAPASMURF Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/10/22:23:53:56 King PAPASMURF Download Play UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/UCRT_x86...
2016/10/22:23:54:00 King PAPASMURF Download Complete UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/UCRT_x86...
2016/10/22:23:54:00 King PAPASMURF Installing Universal C Runtime (KB2999226): "C:\Autodesk\WI\Autodesk Maya 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/10/22:23:54:00 King PAPASMURF Install Universal C Runtime (KB2999226) Succeeded
2016/10/22:23:54:00 King PAPASMURF Download Play VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/10/22:23:54:06 King PAPASMURF Download Complete VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/10/22:23:54:06 King PAPASMURF Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /q /norestart
2016/10/22:23:54:09 King PAPASMURF Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2016/10/22:23:54:10 King PAPASMURF Download Play VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/10/22:23:54:15 King PAPASMURF Download Complete VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/10/22:23:54:15 King PAPASMURF Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /q /norestart
2016/10/22:23:54:19 King PAPASMURF Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2016/10/22:23:54:21 King PAPASMURF Installing Autodesk Licensing Manager: TRANSFORMS="C:\Users\King\AppData\Local\Temp\_AI721C.tmp\x64\CLIC\CLIC_x64_Release-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Maya 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/10/22:23:55:14 King PAPASMURF Install Autodesk Licensing Manager Succeeded
2016/10/22:23:55:15 King PAPASMURF Download Play MAYA http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/MAYA_en-...
2016/10/22:23:59:43 King PAPASMURF Download Aborted MAYA http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/MAYA_en-...
2016/10/22:23:59:43 King PAPASMURF Install Autodesk® Maya® 2017 Failed Download Failed, Installation aborted, Result=1603
2016/10/23:00:00:36 King PAPASMURF Rollback Autodesk Licensing Manager Succeeded
2016/10/23:00:00:36 King PAPASMURF Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/10/23:00:00:37 King PAPASMURF Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2016/10/23:00:00:37 King PAPASMURF Rollback Universal C Runtime (KB2999226) Failed Failure is ignored, Result=1619
2016/10/23:00:00:37 King PAPASMURF Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2016/10/23:00:00:37 King PAPASMURF Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2016/10/23:00:00:37 King PAPASMURF Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/10/23:00:00:37 King PAPASMURF Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2016/10/23:00:00:41 King PAPASMURF PageOpen InstallCompleteDialog
2016/10/23:00:01:36 King PAPASMURF === Setup ended ===
2016/10/23:00:03:45 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/23:00:03:45 King PAPASMURF Path_Length: 141
2016/10/23:00:03:45 King PAPASMURF Current Directory C:\Autodesk\Autodesk_Maya_2017_wi_en-US
2016/10/23:00:03:45 King PAPASMURF Launch
2016/10/23:00:03:45 King PAPASMURF CommandLine /PK 657I1 /SN 900-71267896 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/Autodesk_Maya_2017_wi_en-US_Setup.exe?dummy=0"
2016/10/23:00:03:45 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AI9B0F.tmp
2016/10/23:00:03:52 King PAPASMURF === Setup ended ===
2016/10/23:00:03:47 King PAPASMURF === Setup started on PAPASMURF by King ===
2016/10/23:00:03:47 King PAPASMURF Path_Length: 141
2016/10/23:00:03:47 King PAPASMURF Current Directory C:\Users\King\AppData\Local\Temp\_AI9B0F.tmp
2016/10/23:00:03:47 King PAPASMURF Launch
2016/10/23:00:03:48 King PAPASMURF Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUPMAR...
2016/10/23:00:03:48 King PAPASMURF Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/SETUP_x6...
2016/10/23:00:03:52 King PAPASMURF PageOpen LaunchDialog
2016/10/23:00:03:56 King PAPASMURF PageOpen LicenseDialog
2016/10/23:00:03:56 King PAPASMURF PageOpen ProductSelectionDialog2
2016/10/23:00:03:58 King PAPASMURF PageOpen LicenseDialog
2016/10/23:00:03:58 King PAPASMURF PageOpen LaunchDialog
2016/10/23:00:04:09 King PAPASMURF PageOpen LicenseDialog
2016/10/23:00:04:09 King PAPASMURF PageOpen ProductInfoDialog
2016/10/23:00:04:09 King PAPASMURF PageOpen ProductSelectionDialog2
2016/10/23:00:04:14 King PAPASMURF PageOpen FullProgressDialog
2016/10/23:00:04:15 King PAPASMURF Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/STARTMAR...
2016/10/23:00:04:17 King PAPASMURF Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/STARTMAR...
2016/10/23:00:04:17 King PAPASMURF Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/10/23:00:04:17 King PAPASMURF Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2017\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/10/23:00:04:23 King PAPASMURF Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/10/23:00:04:23 King PAPASMURF Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/VCREDIST...
2016/10/23:00:04:23 King PAPASMURF Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2017\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/10/23:00:04:24 King PAPASMURF Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/10/23:00:04:26 King PAPASMURF Installing Autodesk Licensing Manager: TRANSFORMS="C:\Users\King\AppData\Local\Temp\_AI9B0F.tmp\x64\CLIC\CLIC_x64_Release-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Maya 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/10/23:00:05:03 King PAPASMURF Install Autodesk Licensing Manager Succeeded
2016/10/23:00:05:04 King PAPASMURF Download Play MAYA http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/MAYA_en-...
2016/10/23:00:09:32 King PAPASMURF Download Aborted MAYA http://edutrial.autodesk.com/NET17SWDLD/2017/MAYA/WI/{D4D3BFC8-8031-4358-8B37-49BF4A7F68E5}/MAYA_en-...
2016/10/23:00:09:32 King PAPASMURF Install Autodesk® Maya® 2017 Failed Download Failed, Installation aborted, Result=1603
2016/10/23:00:10:17 King PAPASMURF Rollback Autodesk Licensing Manager Succeeded
2016/10/23:00:10:17 King PAPASMURF Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2016/10/23:00:10:17 King PAPASMURF Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
Your installation is simply failing due to the method (web installer) you're using. This method is unreliable and shouldn't be used.
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
However if the installation does fail using this method, please post your installation log file here so we can review it. Posting info: Sometimes installation log files contain personal information such as your serial #. Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Although you were probably unaware of this, but when you post or share stuff here, please make sure it doesn't include your personal information such as your serial #. This is a world wide user forum and that type of info should not be included in your posting. Granted the installation log file helped us to determine your root cause (but it did contain your serial #)... So in the future remove or blur it out before posting. I will have the moderator remove it in order to protect your information.
Mark Lancaster
& Autodesk Services MarketPlace Provider
