i keep getting maya error codes 1603 and 1619 when i do install now and i cant use browser download because it keeps saying file corrupted error so install now is basically my only option and ive tried uninstalling then reinstalling microsoft visual c++ 2005 but that still doesnt help does anyone know the answer to this?
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
I used the virtual assistant. When I click 64-bit, it starts downloading the OSX version. Can Autodesk fix this??
Hi @kendall.w12345, try using a different download method. That usually resolves the error. Thanks!
I spent almost a month trying to get Maya 2015 to install, using all three methods offered: install now, download now, and browser download. Finally by (what seemed to be) a miracle, it installed. Until then I was getting errors with all three download types: file corrupted error, connection lost-sign in again, this file is already in the queue. However it did finally install. I thought that was the end of it, but no, I had no UV editor. As an educator that has to teach students how to edit UVs, I needed that thing. Another week of effort tells me it is related to a plugin called Nightshade that I actually don't have on my computer. Supposedly this tool causes the exact error I had, but I didn't have the program. Requests for help went nowhere, so I finally decided to actually install Nightshade and (by a miracle) that solved the problem instead of the other way around. So now I have to make a Maya 2015 format demo file for students and I have to save it. However, I can't save anything! Do I get an error? No. There is no feedback. There is a dialogue box with no dialogue and two buttons. I assume this is the standard "this is a student copy of Maya. If saved from this copy, the file will etc..." so I click 'enter' without knowing for sure what is going on. There is an audio warning and then another empty dialogue with one button shows up. I figure this is the 'are you sure?' dialog and hit'enter'. Problem solved? No. There is no file generated. I tried every permutation I could think of: selecting one button, or the other one. Using the tab key to change buttons or the cursor (which has changed to 'busy') and changing file format from .ma to .mb. No luck with any of these things. So, at the end of my rope, I reinstalled Maya 2015. This is about the 20th time I've done it this month, so I wasn't too happy to be doing it again. No luck.
Then I uninstall Maya completely, deciding I would just install from scratch by downloading it again. However, I am now stuck in download/install hell. When it tries to install now (on the couple of occasions it gets that far) it says it can't find a file called nightshade.ma and quits the install. Where is that file supposed to be coming from? Isn't this a fresh install? Did someone let their kids play with the code? Is this a practical joke? If I was a commercial customer I would just give up on Maya right now, but because I have to use it to teach Maya I have to solve this problem. The amazing thing is that I'm not the only one with these issues and all of them are show-stoppers. How can a program like this be released with these problems?
AP
Having similar problems, though I haven't been at it for a month...yet...
Receiving, after a host of other problems, "file corrupted error", and am completely unable to proceed beyond this.
Their support repeats the same answer to this and similar issue with "download using the autodesk virtual agent", which unfortunatlely has the same or similar problems. How is an organization functioning if the download from their site is bad and they have a second method that is supposedly "good", and this is all their support staff knows how to tell you?
In another chain one support staff told the person with a problem with Microsoft Visual C++ dlls to uninstall, and when that didn't work, she gave the customer a link to a mac OS file...and when she was told that obviously woudn't work, nothing...
For this I can only conclude that while the software may be amazing (it is!), the part of the organization that manages downloads is incompetent, and the support staff is not trained sufficiently in this issue.
I don't expect an answer any time soon, but please, if you would, anyone know how to resolve this issue of "file corrupted error" when trying to run the self-extracting files?
Hi @paqart,
We appreciate your feedback and concerns but you may want to try posting these comments in our Autodesk Maya community . There Maya experts will be able some insight! Thank you!
Hi @UndeadYogurt,
Have you tried any of the following steps to help the file corrupt error?
Do you have a support case open? Thanks!
Same. I am a student and need this installation at home to work. I've tried every possible way of downloading and installing multiple versions and have had a multitude of errors (many of which are listed here already), and in the end - NO SUCCESS. I've had to resign to handing in things late or incomplete because of installation issues.
Seriously - is this a joke to point out that nothing in life is free?? My time is precious and I've wasted too many hours trying to install this. Dont offer free software if it does not work, and you will save many people a lot of hassle. I am not inclined to use Maya because of this, and therefore not inclined to use it when I graduate. I don't want to pay thousands of $$ for a licence that might not install!
Autodesk: SORT YOURSELVES OUT.
This is ridicilous.
I've spent hours away from my work trying to sort this same problem out. I've followed all the instructions and nothing is working. I have NEVER and I mean EVER had any problems with firewalls or blocked ports, downloading software even with the use of several otehr common download managers, but this is just a joke. And I also can't do a browser download because I don't have a product key to log in to the subcription centre with.
This system is extremely flawed and makes a process that should be as easy as click / install a crazy hastle. Who decided to implement this system? It is absurd. Thank you autodesk for making this a thousand times more complicated than it has to be.
Hi @kosrich,
If you have an EDU Account and you have already downloaded a Student License from there, a Serial Number and Product Key is automatically sent.
You can download the Product from our Virtual Agent and refer here for the Product Keys.
Hey,
Had the same issues like the rest of the people posting here, but was able to find a way how to install Maya 2015 student for win64.
The problem was that some employee decided to split up the executable that will get downloaded if you download the "Browser download".
There is a second small part of the executeable which you can find if you follow the link of the joane (virtual Agent).
The file is stored in Download Links -> Maya Products -> Autodesk Maya -> 64 Bit Part 1 I Part 2.
Thought i post that here, so someone in the future can save some time on this...
This is rediculas. Seriously. I've been using Maya since 99. And every version comes with a tirrible bug. The new error bug is the worst. I tried all the solutions posted from the clock, to the anti virus, to the services to sp5 and reinstall. Nothing works.
