Installation & Licensing
Maya 2014 Installation Fail
0 REPLIES 0
Message 1 of 1
145 Views, 0 Replies
Hello dear Community i alrdy posted a thread but apparently there is nobody answering so im trying my luck again^^
I succesfully installed it on my Laptop which runs Windows 7 but on my tower which runs Vista it doesnt seem to work. I already did the thing where u delete ur Redistributables but it did not help. I hope you can find a solution.
This is my installation Log :
2014/4/11:13:23:58    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:13:23:58    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:13:23:58    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/4/11:13:23:58    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:13:23:58    Armée Tricolores    ARMÉETRICOLO-PC    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-46532129 /PK 657F1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/11:13:23:58    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI67E9.tmp
2014/4/11:13:24:28    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:13:24:00    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:13:24:00    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:13:24:00    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI67E9.tmp
2014/4/11:13:24:00    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:13:24:04    Armée Tricolores    ARMÉETRICOLO-PC    Download    Play    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/4/11:13:24:27    Armée Tricolores    ARMÉETRICOLO-PC    Download    Complete    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/4/11:13:24:28    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LaunchDialog
2014/4/11:13:26:07    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LicenseDialog
2014/4/11:13:26:07    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductInfoDialog
2014/4/11:13:26:07    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductSelectionDialog2
2014/4/11:13:26:16    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    FullProgressDialog
2014/4/11:13:26:16    Armée Tricolores    ARMÉETRICOLO-PC    Download    Play    VCREDIST2005SP1ATLX64    http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/VCREDIS...
2014/4/11:13:26:20    Armée Tricolores    ARMÉETRICOLO-PC    Download    Complete    VCREDIST2005SP1ATLX64    http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/VCREDIS...
2014/4/11:13:26:20    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/11:13:26:44    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)    Failed    Installation aborted, Result=1603
2014/4/11:13:26:44    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    InstallCompleteDialog
2014/4/11:13:27:01    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:13:28:52    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:13:28:52    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:13:28:52    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/4/11:13:28:52    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:13:28:52    Armée Tricolores    ARMÉETRICOLO-PC    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-46532129 /PK 657F1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/11:13:28:52    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AIE3EB.tmp
2014/4/11:13:28:56    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:13:28:53    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:13:28:53    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:13:28:53    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AIE3EB.tmp
2014/4/11:13:28:53    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:13:28:55    Armée Tricolores    ARMÉETRICOLO-PC    Download    Skipped    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/4/11:13:28:55    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LaunchDialog
2014/4/11:13:29:00    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LicenseDialog
2014/4/11:13:29:00    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductInfoDialog
2014/4/11:13:29:00    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductSelectionDialog2
2014/4/11:13:29:03    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    FullProgressDialog
2014/4/11:13:29:03    Armée Tricolores    ARMÉETRICOLO-PC    Download    Skipped    VCREDIST2005SP1ATLX64    http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/VCREDIS...
2014/4/11:13:29:03    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/11:13:29:23    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)    Failed    Installation aborted, Result=1603
2014/4/11:13:29:23    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    InstallCompleteDialog
2014/4/11:13:29:50    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:13:38:10    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:13:38:10    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:13:38:10    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/4/11:13:38:10    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:13:38:10    Armée Tricolores    ARMÉETRICOLO-PC    CommandLine
2014/4/11:13:38:10    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI66A2.tmp
2014/4/11:13:38:18    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:13:38:13    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:13:38:13    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:13:38:13    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI66A2.tmp
2014/4/11:13:38:13    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:13:38:22    Armée Tricolores    ARMÉETRICOLO-PC    [Error: 1056] Es wird bereits eine Instanz des Dienstes ausgeführt.
2014/4/11:13:38:22    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:13:40:02    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:13:40:02    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:13:40:02    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI1612.tmp
2014/4/11:13:40:02    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:13:40:05    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:13:43:04    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:13:43:04    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:13:43:04    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/4/11:13:43:04    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:13:43:04    Armée Tricolores    ARMÉETRICOLO-PC    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-46532129 /PK 657F1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/11:13:43:04    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AIE3DC.tmp
2014/4/11:13:43:26    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:13:43:06    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:13:43:06    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:13:43:06    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AIE3DC.tmp
2014/4/11:13:43:06    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:13:43:08    Armée Tricolores    ARMÉETRICOLO-PC    Download    Play    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/4/11:13:43:26    Armée Tricolores    ARMÉETRICOLO-PC    Download    Complete    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/4/11:13:43:27    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LaunchDialog
2014/4/11:13:43:30    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LicenseDialog
2014/4/11:13:43:30    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductSelectionDialog2
2014/4/11:13:43:39    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LicenseDialog
2014/4/11:13:43:39    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LaunchDialog
2014/4/11:13:43:45    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LicenseDialog
2014/4/11:13:43:45    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductInfoDialog
2014/4/11:13:43:45    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductSelectionDialog2
2014/4/11:13:44:03    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    FullProgressDialog
2014/4/11:13:44:03    Armée Tricolores    ARMÉETRICOLO-PC    Download    Play    VCREDIST2005SP1ATLX64    http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/VCREDIS...
2014/4/11:13:44:07    Armée Tricolores    ARMÉETRICOLO-PC    Download    Complete    VCREDIST2005SP1ATLX64    http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/VCREDIS...
2014/4/11:13:44:07    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/11:13:44:26    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)    Failed    Installation aborted, Result=1603
2014/4/11:13:44:27    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    InstallCompleteDialog
2014/4/11:13:45:26    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:13:49:20    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:13:49:20    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:13:49:20    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI9D5B.tmp
2014/4/11:13:49:20    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:13:49:24    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:13:49:19    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:13:49:19    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:13:49:19    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/4/11:13:49:19    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:13:49:19    Armée Tricolores    ARMÉETRICOLO-PC    CommandLine
2014/4/11:13:49:19    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI9D5B.tmp
2014/4/11:14:40:08    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:14:40:08    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:14:40:08    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/11:14:40:08    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:14:40:08    Armée Tricolores    ARMÉETRICOLO-PC    CommandLine
2014/4/11:14:40:08    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI23E9.tmp
2014/4/11:14:40:29    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:14:40:13    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:14:40:13    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:14:40:13    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI23E9.tmp
2014/4/11:14:40:13    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:14:40:22    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LaunchDialog
2014/4/11:14:40:29    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LicenseDialog
2014/4/11:14:40:33    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductInfoDialog
2014/4/11:14:42:04    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductSelectionDialog2
2014/4/11:14:42:12    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    FullProgressDialog
2014/4/11:14:42:12    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/11:14:42:29    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)    Failed    Installation aborted, Result=1603
2014/4/11:14:57:01    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:14:57:01    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:14:57:01    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/11:14:57:01    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:14:57:01    Armée Tricolores    ARMÉETRICOLO-PC    CommandLine
2014/4/11:14:57:01    Armée Tricolores    ARMÉETRICOLO-PC    An instance of setup is already running. Only one instance of setup can run at a time.2014/4/11:14:57:03    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:14:42:30    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    InstallCompleteDialog
2014/4/11:14:57:05    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:14:57:08    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:14:57:08    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:14:57:08    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/11:14:57:08    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:14:57:08    Armée Tricolores    ARMÉETRICOLO-PC    CommandLine
2014/4/11:14:57:08    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AIB243.tmp
2014/4/11:14:57:17    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:14:57:11    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:14:57:11    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:14:57:11    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AIB243.tmp
2014/4/11:14:57:11    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:14:57:14    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LaunchDialog
2014/4/11:14:57:17    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LicenseDialog
2014/4/11:14:57:30    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:15:24:00    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:15:24:00    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:15:24:00    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI3E7B.tmp
2014/4/11:15:24:00    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:15:24:03    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LaunchDialog
2014/4/11:15:24:04    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LicenseDialog
2014/4/11:15:23:56    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:15:23:56    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:15:23:56    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/11:15:23:56    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:15:23:56    Armée Tricolores    ARMÉETRICOLO-PC    CommandLine
2014/4/11:15:23:56    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI3E7B.tmp
2014/4/11:15:24:06    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:15:24:06    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductInfoDialog
2014/4/11:15:24:52    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductSelectionDialog2
2014/4/11:15:24:55    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    FullProgressDialog
2014/4/11:15:24:55    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/11:15:25:15    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)    Failed    Installation aborted, Result=1603
2014/4/11:15:25:16    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    InstallCompleteDialog
2014/4/11:15:31:05    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:15:31:59    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:15:31:59    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:15:31:59    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/11:15:31:59    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:15:31:59    Armée Tricolores    ARMÉETRICOLO-PC    CommandLine
2014/4/11:15:31:59    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI9D2E.tmp
2014/4/11:15:32:03    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:15:32:01    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:15:32:01    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:15:32:01    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI9D2E.tmp
2014/4/11:15:32:01    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:15:32:03    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LaunchDialog
2014/4/11:15:32:04    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LicenseDialog
2014/4/11:15:32:06    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductInfoDialog
2014/4/11:15:32:32    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductSelectionDialog2
2014/4/11:15:32:34    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    FullProgressDialog
2014/4/11:15:32:34    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/11:15:33:00    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)    Failed    Installation aborted, Result=1603
2014/4/11:15:33:01    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    InstallCompleteDialog
2014/4/11:15:33:04    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:15:34:41    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:15:34:41    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:15:34:41    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/11:15:34:41    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:15:34:41    Armée Tricolores    ARMÉETRICOLO-PC    CommandLine
2014/4/11:15:34:41    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI1578.tmp
2014/4/11:15:34:45    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:15:34:42    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:15:34:42    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:15:34:42    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI1578.tmp
2014/4/11:15:34:42    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:15:34:44    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LaunchDialog
2014/4/11:15:34:45    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LicenseDialog
2014/4/11:15:34:48    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductInfoDialog
2014/4/11:15:35:23    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductSelectionDialog2
2014/4/11:15:35:25    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    FullProgressDialog
2014/4/11:15:35:25    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/11:15:35:48    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)    Failed    Installation aborted, Result=1603
2014/4/11:15:35:49    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    InstallCompleteDialog
2014/4/11:15:38:17    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:15:40:43    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:15:40:43    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:15:40:43    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/11:15:40:43    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:15:40:43    Armée Tricolores    ARMÉETRICOLO-PC    CommandLine
2014/4/11:15:40:43    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI9C44.tmp
2014/4/11:15:40:51    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:15:40:47    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:15:40:47    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:15:40:47    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI9C44.tmp
2014/4/11:15:40:47    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:15:40:51    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LaunchDialog
2014/4/11:15:40:52    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LicenseDialog
2014/4/11:15:40:54    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductInfoDialog
2014/4/11:15:42:02    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductSelectionDialog2
2014/4/11:15:42:03    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    FullProgressDialog
2014/4/11:15:42:03    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/4/11:15:42:34    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Succeeded
2014/4/11:15:42:34    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/11:15:43:01    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)    Failed    Installation aborted, Result=1603
2014/4/11:15:43:02    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    InstallCompleteDialog
2014/4/11:15:43:55    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:15:44:44    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:15:44:44    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:15:44:44    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/11:15:44:44    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:15:44:44    Armée Tricolores    ARMÉETRICOLO-PC    CommandLine
2014/4/11:15:44:44    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI4742.tmp
2014/4/11:15:44:48    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:15:44:45    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:15:44:45    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:15:44:45    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI4742.tmp
2014/4/11:15:44:45    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:15:44:48    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LaunchDialog
2014/4/11:15:44:49    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LicenseDialog
2014/4/11:15:44:51    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductInfoDialog
2014/4/11:15:45:18    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductSelectionDialog2
2014/4/11:15:45:19    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    FullProgressDialog
2014/4/11:15:45:19    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/4/11:15:45:48    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Succeeded
2014/4/11:15:45:48    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/11:15:46:13    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)    Failed    Installation aborted, Result=1603
2014/4/11:15:46:14    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    InstallCompleteDialog
2014/4/11:15:46:34    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:17:28:58    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:17:28:58    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:17:28:58    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/11:17:28:58    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:17:28:58    Armée Tricolores    ARMÉETRICOLO-PC    CommandLine
2014/4/11:17:28:58    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AIB6C8.tmp
2014/4/11:17:29:01    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:17:28:59    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:17:28:59    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:17:28:59    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AIB6C8.tmp
2014/4/11:17:28:59    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:17:29:01    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LaunchDialog
2014/4/11:17:29:03    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LicenseDialog
2014/4/11:17:29:05    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductInfoDialog
2014/4/11:17:29:41    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductSelectionDialog2
2014/4/11:17:29:43    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    FullProgressDialog
2014/4/11:17:29:43    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/4/11:17:30:12    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Succeeded
2014/4/11:17:30:12    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2014/4/11:17:30:37    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2008 SP1 Redistributable (x86)    Succeeded
2014/4/11:17:30:37    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart
2014/4/11:17:30:49    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Succeeded
2014/4/11:17:30:49    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/11:17:31:18    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)    Failed    Installation aborted, Result=1603
2014/4/11:17:31:18    Armée Tricolores    ARMÉETRICOLO-PC    Rollback    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1619
2014/4/11:17:31:20    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    InstallCompleteDialog
2014/4/11:17:31:28    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:17:39:30    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:17:39:30    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:17:39:30    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/11:17:39:30    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:17:39:30    Armée Tricolores    ARMÉETRICOLO-PC    CommandLine
2014/4/11:17:39:30    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI5A57.tmp
2014/4/11:17:39:36    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:17:39:31    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:17:39:31    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:17:39:31    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI5A57.tmp
2014/4/11:17:39:31    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:17:39:36    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LaunchDialog
2014/4/11:17:39:37    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LicenseDialog
2014/4/11:17:39:39    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductInfoDialog
2014/4/11:17:39:55    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductSelectionDialog2
2014/4/11:17:39:56    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    FullProgressDialog
2014/4/11:17:39:56    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/4/11:17:40:28    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Succeeded
2014/4/11:17:40:28    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2014/4/11:17:40:52    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2008 SP1 Redistributable (x86)    Succeeded
2014/4/11:17:40:52    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/11:17:41:20    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)    Failed    Installation aborted, Result=1603
2014/4/11:17:41:21    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    InstallCompleteDialog
2014/4/11:17:41:56    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:17:43:41    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:17:43:41    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:17:43:41    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/11:17:43:41    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:17:43:41    Armée Tricolores    ARMÉETRICOLO-PC    CommandLine
2014/4/11:17:43:41    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI31C1.tmp
2014/4/11:17:43:51    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:17:43:47    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:17:43:47    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:17:43:47    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI31C1.tmp
2014/4/11:17:43:47    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:17:43:50    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LaunchDialog
2014/4/11:17:43:51    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LicenseDialog
2014/4/11:17:43:53    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductInfoDialog
2014/4/11:17:44:06    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductSelectionDialog2
2014/4/11:17:44:07    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    FullProgressDialog
2014/4/11:17:44:07    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/4/11:17:44:54    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Succeeded
2014/4/11:17:44:54    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2014/4/11:17:45:17    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2008 SP1 Redistributable (x86)    Succeeded
2014/4/11:17:45:17    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart
2014/4/11:17:45:29    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Succeeded
2014/4/11:17:45:29    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/11:17:46:00    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)    Failed    Installation aborted, Result=1603
2014/4/11:17:46:00    Armée Tricolores    ARMÉETRICOLO-PC    Rollback    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1619
2014/4/11:17:46:02    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    InstallCompleteDialog
2014/4/11:17:48:30    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:20:08:30    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:20:08:30    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:20:08:30    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/11:20:08:30    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:20:08:30    Armée Tricolores    ARMÉETRICOLO-PC    CommandLine
2014/4/11:20:08:30    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AIC76E.tmp
2014/4/11:20:08:37    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/11:20:08:31    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/11:20:08:31    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/11:20:08:31    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AIC76E.tmp
2014/4/11:20:08:31    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/11:20:08:36    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LaunchDialog
2014/4/11:20:08:51    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LicenseDialog
2014/4/11:20:08:55    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductInfoDialog
2014/4/11:20:09:10    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductSelectionDialog2
2014/4/11:20:09:13    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    FullProgressDialog
2014/4/11:20:09:13    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/4/11:20:10:08    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Succeeded
2014/4/11:20:10:08    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/11:20:10:37    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)    Failed    Installation aborted, Result=1603
2014/4/11:20:10:38    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    InstallCompleteDialog
2014/4/11:20:12:33    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/12:12:53:51    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/12:12:53:51    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/12:12:53:51    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/12:12:53:51    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/12:12:53:51    Armée Tricolores    ARMÉETRICOLO-PC    CommandLine
2014/4/12:12:53:51    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AIE771.tmp
2014/4/12:12:54:08    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/12:12:53:56    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/12:12:53:56    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/12:12:53:56    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AIE771.tmp
2014/4/12:12:53:56    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/12:12:54:07    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LaunchDialog
2014/4/12:12:54:10    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LicenseDialog
2014/4/12:12:54:13    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductInfoDialog
2014/4/12:12:54:38    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductSelectionDialog2
2014/4/12:12:54:40    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    FullProgressDialog
2014/4/12:12:54:40    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/12:12:55:14    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)    Failed    Installation aborted, Result=1603
2014/4/12:12:55:15    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    InstallCompleteDialog
2014/4/12:12:55:19    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/12:13:09:38    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/12:13:09:38    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/12:13:09:38    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/12:13:09:38    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/12:13:09:38    Armée Tricolores    ARMÉETRICOLO-PC    CommandLine
2014/4/12:13:09:38    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI57E0.tmp
2014/4/12:13:09:41    Armée Tricolores    ARMÉETRICOLO-PC    === Setup ended ===
2014/4/12:13:09:39    Armée Tricolores    ARMÉETRICOLO-PC    === Setup started on ARMÉETRICOLO-PC by Armée Tricolores ===
2014/4/12:13:09:39    Armée Tricolores    ARMÉETRICOLO-PC    Path_Length: 151
2014/4/12:13:09:39    Armée Tricolores    ARMÉETRICOLO-PC    Current Directory C:\Users\ARMETR~1\AppData\Local\Temp\_AI57E0.tmp
2014/4/12:13:09:39    Armée Tricolores    ARMÉETRICOLO-PC    Launch
2014/4/12:13:09:41    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LaunchDialog
2014/4/12:13:09:43    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    LicenseDialog
2014/4/12:13:09:45    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductInfoDialog
2014/4/12:13:10:05    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    ProductSelectionDialog2
2014/4/12:13:10:06    Armée Tricolores    ARMÉETRICOLO-PC    PageOpen    FullProgressDialog
2014/4/12:13:10:06    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/4/12:13:10:35    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Succeeded
2014/4/12:13:10:35    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2014/4/12:13:10:56    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2008 SP1 Redistributable (x86)    Succeeded
2014/4/12:13:10:56    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart
2014/4/12:13:11:08    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Succeeded
2014/4/12:13:11:08    Armée Tricolores    ARMÉETRICOLO-PC    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ARMETR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/12:13:11:34    Armée Tricolores    ARMÉETRICOLO-PC    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)    Failed    Installation aborted, Result=1603
2014/4/12:13:11:34    Armée Tricolores    ARMÉETRICOLO-PC    Rollback    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1619
Thanks a lot for ur help i really need it !
0 REPLIES 0
Administrator Productivity
