hello-
i am trying to install autocad LT 2018 and getting a material library failed error each time. is there a work around for this?
2017/3/22:20:33:14 xxuserxx LAPTOP-machine2 === Setup started on LAPTOP-machine2 by xxuserxx ===
2017/3/22:20:33:14 xxuserxx LAPTOP-machine2 Path_Length: 132
2017/3/22:20:33:14 xxuserxx LAPTOP-machine2 Current Directory C:\Users\xxuserxx\AppData\Local\Temp\_AID4F6.tmp
2017/3/22:20:33:14 xxuserxx LAPTOP-machine2 Launch
2017/3/22:20:33:15 xxuserxx LAPTOP-machine2 Download Skipped SETUPMARKER http://trial2.autodesk.com/NET18SWDLD/2018/ACDLT/28B6A007-E963-4F73-883B-61DCE39E44B1/WI/{B18E1DF6-F...
2017/3/22:20:33:15 xxuserxx LAPTOP-machine2 Download Skipped SETUP_CONFIG http://trial2.autodesk.com/NET18SWDLD/2018/ACDLT/28B6A007-E963-4F73-883B-61DCE39E44B1/WI/{B18E1DF6-F...
2017/3/22:20:33:15 xxuserxx LAPTOP-machine2 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\xxuserxx\AppData\Local\Temp\_AID4F6.tmp\Setup\AcSetup.dll
2017/3/22:20:33:15 xxuserxx LAPTOP-machine2 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/22:20:33:17 xxuserxx LAPTOP-machine2 PageOpen LaunchDialog
2017/3/22:20:33:32 xxuserxx LAPTOP-machine2 PageOpen LicenseDialog
2017/3/22:20:33:38 xxuserxx LAPTOP-machine2 PageOpen ProductInfoDialog
2017/3/22:20:33:38 xxuserxx LAPTOP-machine2 PageOpen ProductSelectionDialog2
2017/3/22:20:33:44 xxuserxx LAPTOP-machine2 PageOpen FullProgressDialog
2017/3/22:20:33:44 xxuserxx LAPTOP-machine2 Download Play STARTMARKER http://trial2.autodesk.com/NET18SWDLD/2018/ACDLT/28B6A007-E963-4F73-883B-61DCE39E44B1/WI/{B18E1DF6-F...
2017/3/22:20:33:44 xxuserxx LAPTOP-machine2 Download Complete STARTMARKER http://trial2.autodesk.com/NET18SWDLD/2018/ACDLT/28B6A007-E963-4F73-883B-61DCE39E44B1/WI/{B18E1DF6-F...
2017/3/22:20:33:44 xxuserxx LAPTOP-machine2 Download Skipped DIRECTX http://trial2.autodesk.com/NET18SWDLD/2018/ACDLT/28B6A007-E963-4F73-883B-61DCE39E44B1/WI/{B18E1DF6-F...
2017/3/22:20:33:44 xxuserxx LAPTOP-machine2 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD LT 2018\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/22:20:33:52 xxuserxx LAPTOP-machine2 DirectX Runtime return code: 0
2017/3/22:20:33:52 xxuserxx LAPTOP-machine2 Install DirectX Runtime Succeeded
2017/3/22:20:33:52 xxuserxx LAPTOP-machine2 Download Play CM http://trial2.autodesk.com/NET18SWDLD/2018/ACDLT/28B6A007-E963-4F73-883B-61DCE39E44B1/WI/{B18E1DF6-F...
2017/3/22:20:34:39 xxuserxx LAPTOP-machine2 Download Aborted CM http://trial2.autodesk.com/NET18SWDLD/2018/ACDLT/28B6A007-E963-4F73-883B-61DCE39E44B1/WI/{B18E1DF6-F...
2017/3/22:20:34:39 xxuserxx LAPTOP-machine2 Install Autodesk Material Library 2018 Failed Download Failed, Installation aborted, Result=1603
2017/3/22:20:34:39 xxuserxx LAPTOP-machine2 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/3/22:20:34:39 xxuserxx LAPTOP-machine2 PageOpen InstallCompleteDialog
2017/3/22:20:38:32 xxuserxx LAPTOP-machine2 === Setup ended ===
Solved by natasha.l. Go to Solution.
This issue is caused by the method you're using to download/install the application.
Solution:
Download the software using the Browser Download option:
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
I am having the same trouble with AutoCAD Electrical 2018. There is no other option to download all the components first on the website. I am downloading this via my university's T1 internet. I have plenty of speed to keep up with the downloads while installing at the same time.
Welcome to the community...
Update: Man I must be blind today... I was thinking @Darin.Green was showing the Virtual Agent Method...
2018 information is not on the virtual agent..
Although this image shows CFD and version 2017, the steps are the same. Access you Autodesk Account, configure version, platform and language and then select View all to get the other options. IF you do not see the view all option, select the language portion and pick the one that has all the options. When using the browser download method make sure your browser doesn't have the pop-up block enabled or you may not get all the required parts. Also take note of how many parts..
Download and install per:1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first as indicated above. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
However if the installation does fail using this method, please post your installation log file here so we can review it. Posting info: Sometimes installation log files contain personal information such as your serial #. Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hello @atsprink,
Welcome.
Did you have any luck finding it in your account. Conducting the steps below before the download & install helps.
Continue if you are still missing the Material Libraries:
Keep us posted on the progress.
Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
@natasha.l wrote:
Hello @atsprink,
Welcome.
Did you have any luck with the Virtual Agent.
2018 is not on the Autodesk Virtual Agent.... But it should be #1 priority...
Mark Lancaster
Hey Natshal84,
After an afternoon of frustration, I found your solution, which worked for me.
Thank you so much for your post. You deserve a big hug!!
Don
Sir
Thank you very much, this really helped me.
but the download is get complete installation only when i have downloaded with Autodesk download manager.
