After logging in the page goes blank and can not pressed to the next screen. What is the fix so that I can install AutoCad2012? My E-Mail is patrickmarcus@hotmail.com or 10622767@uvlink.uvu.edu. I would like to know so I can do my AutoCad home work at home.
Hi Patrick,
could you be more specific about when this problem occurs?
Is it during the installation, or when you try to register/activate it? Or at some other point?
If the problem is with the Registration / Activation screen, have a look at the following article:
http://usa.autodesk.com/getdoc/id=TS1053941
Hope this helps
Best regards,
Silvia
Silvia Menon
Support Specialist
Product Support
Autodesk, Inc.
http://www.autodesk.com/autocad-support
