LMTOOLS Utility
LMTOOLS Utility
LMTOOLS Utility
selam arkadaşlar ben laptopa geçen sene 2015 öğrenci lisansı yüklemiştim yalnız geçen hafta bilgisayarım windows güncellemesi sorun çıkarttığı için servisi aradım onlarda sıfırlama yaptırıdı tabi proğramlarda gitti.
Bugün yeniden internetten 3dsmax 2015 öğrenci lisansını  kurmak için yüklemeye çalıştım, LMTOOLS Utility masa üstüne indi yotube de arattım ingilizce bir şeyler anlatıyo hiç bir şey anlamadım.  Help kısmında yazan numaraları anlatıyordu benimkinde yazan numaralar V11.12.0.0 build 136775X64_n6. bu nedir?
Nası yapıcam, bir yol gösterirmisiniz?
natasha.l
Google Translate
Hi friends I installed a laptop license last year 2015 student license only last week my computer windows update problem because ı made the service ı did not reset the program went to the program.
Today I tried to install again to install 3dsmax 2015 student license from the internet, LMTOOLS Utility went down to the table and yotube did not understand anything about english. I was talking about the numbers in the help section, the numbers I wrote in my V11.12.0.0 build 136775X64_n6. what is this?
How can I make a path?
Hello @Anonymous.
Thank you for posting. I have translated your post for you this is an English forum, please translate your posts for better feedback in the future.
I understand that you are using a student license, if you are then that is the issue students do not have access to Network Licensing which uses LMTools. During the activation process, you should be selecting "Enter Serial Number", please take a look at Steps for Setting-Up Student Software
If you are a qualified Educator or someone working for an educational institution you should set up the proper educational account.
Keep us posted. Smiley Happy
Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
teşekkürler
natasha.l
Hello @Anonymous,
Thank you for returning to the community & contributing by accepting as a solution to a reply. This will help a visitor in the future with a similar issue.
Keep posting! Smiley Happy
