Installation & Licensing
cancelar
Mostrando los resultados deĀ
MostrarĀ Ā soloĀ  | Buscar en lugar deĀ
Quiere decir:Ā
Responder
Mensaje 1 de 4
golnaz.golestani
361 Vistas, 3 Respuestas
Liscence error
I have  installed my AutoCAD Civil 3D from my university account and have licensed it but when I open it I receive this error. Any ideas how I can fix it?
Etiquetas (1)
3 RESPUESTAS 3
Mensaje 2 de 4
handjonathan
en respuesta a: golnaz.golestani
Hi @golnaz.golestani
Thanks a lot for posting your question to the forums!   There could be a few reasons for this. Please see below suggestions.
Note: Some of the below suggestions require administrator rights or access to the license server. Consult with your system or network administrator.
First, check that the server can be reached via the ping command:
  1. Click Start.
  2. Type cmd
  3. Press ENTER.
  4. Type ping <servername> (where <servername> is your license server hostname or IP address).
  • If a reply is returned, then proceed with the following solutions.
  • If the command times out appears check with your network administrator.
License server is not setup properly or runs an old version of the Network License Manager (NLM)
Ensure the License server is properly setup:
If the last version of NLM is installed but the issue persists, use the following guide: Error: "Network License Not Available - Error [0.0.0]" despite LMTOOLS is updated to latest version
Rollback the Autodesk Desktop Licensing Service update
See "Network License Not Available. An incompatible version [...] is installed. Error [0.0.0]" when star....
Invalid license type selected
Verify in the Autodesk Account if the correct license is used. If your software license is "Sign In" but the software is accidentally launched as "Multi User" or "Network License", the above error is displayed.
In this case, do the following:
  1. Change the license type (see: How to change or reset a license for Autodesk software).
  2. Launch again the software.
  3. Select Single user or Sign In on the Let's Get Started screen.
Invalid or outdated license file
Verify that the license file is valid and/or includes the version you are trying to run. Errors may occur if the license file is corrupted or if licenses have been combined incorrectly.
Corrupt CascadeInfo.cas file
Delete the CascadeInfo.cas file. A new file will be created automatically when the product opens. The CascadeInfo.cas file is located in the following locations:
  • C:\ProgramData\Autodesk\Adlm\CascadeInfo.cas
Essential ports are blocked by the Windows firewall or incorrect port is being used
  1. Enable ports 2080 and 27000-27009, which are used for network licensing. See How to set exceptions for Autodesk Network License Manager in Windows Firewall
  1. Confirm that the server and workstation are using the same ports:
Server: Open the license file and review the first 3 lines. If no port is listed at the end of SERVER 27000 is the default port.
SERVER Master01 00d0b757050C0
      USE_SERVER
      VENDOR adsklflex port=2080
If the port was to be changed it would appear similar to the following example:
SERVER Master01 00d0b757050C0 27005
     USE_SERVER
     VENDOR adsklflex port= 2085 (This is rarely changed)
  1. Check environment variable ADSKFLEX_LICENSE_FILE and LICPATH.lic to see what port is being used. If a port is not listed the default port used is 27000.
The client workstation is not listed in an options file with INCLUDE command
If an Options File is used with INCLUDE command to restrict license usage, a client workstation should be listed in the options file INCLUDE command. If that is the case, follow these steps:
  1. On the server, open the adskflex.opt file located in the same directory as your network license file.
  2. Make sure that your client hostname is included in the INCLUDE command for the specific license.
  3. For example, the client hostname is paul. The software is AutoCAD. The OPTIONS file will look like below:
INCLUDE 64300ACD_T_F USER paul
  1. Restart the server to re-read the OPTIONS file.
  2. Finally, open the software on the client machine - the software will now check the license and open.
Autodesk NLM port already in use
Verify whether another program is using the same port as Autodesk NLM. If it is, identify an open TCP port between 27000 to 27009 and add it to the network license file:
  1. Open network license file on the server.
  2. On the top row, after the MAC address, enter a space and then the new open port.
  3. Save the file.
  4. Stop the services.
  5. Start the services.
For example, if choosing 27004 as the new open port for NLM, the licpath.lic file might contain these lines:
SERVER serverName 00112233445566 27004
USE_SERVER
VENDOR adskflex port=2080
Note: The number 00112233445566 in the first line represents the server MAC address.
License retrieval timeout
The current license retrieval timeout value, expressed in milliseconds, may be too short. This can happen if accessing a network license through a VPN.
This can be increased, giving more time to retrieve the license: How to create a FLEXLM_TIMEOUT environment variable .
Incorrect date/time on license server
To resolve the error, correct the date/time on the license server and restart the licensing service in LMTOOLS.
Autodesk Desktop Licensing Service not working properly
Autodesk Desktop Licensing service acts as a entry point and it is always good to ensure it is working. See How to check the status of Autodesk Desktop Licensing Service.
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Mensaje 3 de 4
mdavis22569
Are you school using it when the error happens?  On their Internet?
What type of license do you have?
If not, you'll need a home license, as that's showing you have a Network License.
But I also so you're signed in at the top. ...
Mike Davis
Mensaje 4 de 4
mdavis22569
Mike Davis
ĀæNo encontraste lo que buscabas? PregĆŗntale a la comunidad o comparte tus conocimientos.
Publicar en los foros
Administrator Productivity
