Licesing error
Licesing error
dionnupoort
Message 1 of 8
Licesing error
dionnupoort
A fatal error accured (because i made a realy big hatch).
But when i restarted Autocad i got a Licensing error?
Please help me.
I have a big deadline tomorrow...
Replies (7)
Message 2 of 8
Otto
Hello dionnupoort
We noticed you were receiving a fatal error. The fatal error message can indicate several issues. A video card driver update will typically help with this, but fatal errors usually are generic errors, give these steps a try.
  1. Update to the latest certified graphics drivers & Adjust Global Setting to run it
  2. Check the system requirements for the software & make sure you have the required OS updates
  3. Verify the Microsoft Products (Visual C++, Libraries, .NET) properly installed by checking the install log or Control Panel (uninstall/reinstall)
  4. Conduct a Clean Uninstall of the program use MSfixitTool to complete the uninstall
  5. Download all of the parts Autodesk Virtual Agent & Re-Install the product
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 8
natasha.l
Hello @dionnupoort,
Please review the information here Licensing Error - Please contact Autodesk Customer Support" when launching your Autodesk software
Remember to “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 4 of 8
rkmcswain
@natasha.l - if you find out the cause here, I've love to know how the software is working fine and then all of a sudden there is a licensing error.
It would help us help people like @dionnupoort in the future.
It might help you guys fix whatever is breaking and causing down time for your users too.
Thanks.
R.K. McSwain     | CADpanacea | on twitter
Message 5 of 8
Mark.Lancaster
@rkmcswain
In cases like this (if the other items don't resolve the issue) where its been working
I always recommend to disconnect for your network/internet and then launch the product.  Run it for a few days in off-line activation mode.  Once the product is running, plug or connect back to your network.  I know its a band-aide fix but every time I suggest it, the user is back up and working..  Smiley Wink
In this off-line activation mode you have 30 days before it requires activation again..
But this work-around only works if the application has already been run once and the license activated.
Mark Lancaster
Message 6 of 8
dionnupoort
What do i have to uninstall? Autodesk
Or License Service?
Message 7 of 8
Mark.Lancaster
@dionnupoort
No need to uninstall anything..  The automated response of OTTO is not correct.
Just disconnect for your network, launch the product and go into off-line activation mode.  Once the product is running, connect back to your network/internet.
Mark Lancaster
Message 8 of 8
rkmcswain
Good idea @Mark.Lancaster - thanks. I still hope that Autodesk will make adjustments in the software internally so that their users (like @dionnupoort here) won't have to deal with these problems. It should be handled behind the scenes. Smiley Happy
