Licensing 1603 error
renatois
Observer
renatois
Observer
Observer
I am very disapointed wth Autodcad, I spent 1 entire day trying to solve un installation problem following all their instructions without  sucess, very stressfull. I have that 1603 error, I install the Autodesk Licensing Service -win-11.1.0.5629 installer file but I change nothing!!!
I also have that when trying to activate the service
Services
Windows could not start the Autodesk Desktop Licensing Service service on Local Computer.
Error 1053: The service did not respond to the start or control request in a timely fashion.
leowarren34
Hi @renatois,
Have you seen this article: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-... ?
It should sort your licensing error, let me know if there any further issues.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
rouling
Autodesk Support
Autodesk Support
Hello @renatois
I am sorry that you are having these issue with the installation, wanted to ask you if the suggestion of @leowarren34  did help you.  I had the same issue and on my side was WebCompanion from Lavasoft that was causing the issue during the installation I uninstall it, and I was able to install AutoCAD.
In some cases the antivirus can also cause this problem, you may try to turn it off and then try the Installation. Let me know if you need more help.
Gilles Roulin
Customer Service Technical Specialis
renatois
Observer
Observer
Thanks guys, following the article didnt help, also I dont have WebCompanion from Lavasoft.
I had AutoCAD installed previously in my PC but as I decided to stop some services to improve the performance so I desactivated "FlexNet Licensing Service 64" and later found this article https://knowledge.autodesk.com/fr/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/FRA/C... the problem is that even when I reactivate it bugs. I am still looking for a solution.
rouling
Autodesk Support
Autodesk Support
Hello @renatois
What Windows version are you using at the moment? The FlexNet Licensing Service 64 is used for the older version of Autodesk software from 2019 back to the older version. For the 2020 and newer version, the AdskLicensingService. These service need to be running for AutoCAD to be able to verify the license, what at the moment is not starting.
Try the following:
  • Navigate to  C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing and use the Unistall.exe to uninstall the adsklicensing from these link
  • Try the installation and once the installation is done open the task manager under services and check it the AdskLicensingService is running. If yes, try to launch AutoCAD and login
  • If not, try to start it. If if fails again please let me know.
Gilles Roulin
renatois
Observer
Observer
Thanks for your help rouling, I am donne with Autodesk, I will try to install it another day in a VM cause nothing else is working. The only reason I will install it is to finish my course, otherwise I would never ever open an Autodesk product, I am fed up of all those error messages that leads you nowhere, services that doenst start, permissions not set, I am donne with Autodes. Thanks anyway for your precious time, have a good day my friend
rouling
Autodesk Support
Autodesk Support
Hello @renatois
I am sorry that you are having these issue, send me a private message, and we could take a closer look to the issue.
Gilles Roulin
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
