I am having a huge issue trying to resolve this error,
I have tried to follow online resources and contacted support many times, however all of the steps I have tried do not work.
Solved by natasha.l. Go to Solution.
In the first link, i followed the commands for terminal, however it tells me "no such file or directory"
the 2nd link also does not solve the problem
Hello @Anonymous,
The error mentions a standalone, but the title of this post states Network license. Just want to verify which license type you have, you change the license type by doing a license reset this maybe the issue.
Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
Thank you.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Resetting the license via this steps solved my issue!
thanks,
Reset License on a Mac
1. Delete /Applications/Autodesk folder
2. Delete /Library/Application Support/Autodesk folder.
3. Open /private/var/db/receipts/ folder and delete all files that start with com.autodesk, com.Autodesk and com.alias
4.Delete /Library/Autodesk
5. Navigate to the folder /Library/Preferences/Flexnet Publisher/FLEXnet and delete the files prefixed with adskflex.
6. Delete the folder /Users/Username/Library/Application Support/Autodesk
7.Delete ~/Library/Application Support/Autodesk folder.
8. Delete the ~/Library/Autodesk folder
9. Reboot & Redownload product
10. Install product and select correct license type (Serial Number > Standalone) or (Network License>Network Server)
Hello @Anonymous,
That's great! Glad you resolved the issue, happy to hear you are up and running.
Thank you for contributing to the community with your feedback.
Natasha
Helpful Links:
