Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
License server issues more than one license
PatrikLarking8303
PatrikLarking8303
Hi
We have the problem that about every now and then the licenses server issue more the one 3ds max licens to a client/render node.
The only way too fix this is to restart the LMTOOLS by stoping and starting the services.
Is there any way for us too fix this?
This problem have stop our rendering farm working bechuas it dont get licenes.
thank you!
< Edited Content for better support. >
Mark.Lancaster
@PatrikLarking8303
What version is the license manager and is3DS Max coming from a collection, suite or do you just have single products of 3DS Max?
Mark Lancaster
PatrikLarking8303
the ver. is v11.14.1.3
When you say "is 3DS Max coming from a collection, suite or do you just have single products of 3DS Max?"
do you mean the clients or on the license server.
If you mean the licensserver it is hosting 3 systems 3ds max, vred and DEADLINE
If you mean if the program is installed its singel.
TravisNave
Can you post a copy of your Status Enquiry from LMTOOLS and perhaps your debug.log file as well?  That will help to see what is going on.
Autodesk Forums:
PatrikLarking8303
I will wait to i get the problem.
then give you the logs.
I will be back.
