Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Question: Where can I find a list of the latest Autodesk Knowledge Network support solutions that were created and/or updated regarding Installation & Licensing?
Solved by matthew.d. Go to Solution.
December 2017
November 2017
October 2017
September 2017
August 2017
July 2017
June 2017
May 2017
April 2017
March 2017
Error: [-15.570.0] A valid license could not be obtained by the network license manager
How to uninstall when FixIT doesn’t detect a software as installed
Industry Collections licensing
error 1: 5 2: Error : CreateFile() API failed! 3:5
Install Error: Installer encountered error and could not start the NetSession client
Updates not appearing within Autodesk Desktop App for Multi-user(Network license) user’s.
When is software uninstall/reinstall required after a subscription change?
Autodesk T-Splines Plug-in for Rhino 4 Error
Previous version for Clic licenses
What is a Clic License?
Is it possible to deploy a 2017 product as trial?
Cannot use serial number starting with 900- for educational institution deployment
License Borrow Error - You cannot borrow a license at this time within a redundant server environmen...
Trouble accessing network licenses with a mixed combine license file
Restricting users from borrowing licenses may result in license being temporarily borrowed.
AEC collections, Trial: The License manager is not functioning or is improperly installed
Best practice for installing Autodesk Products
How to get a student version of Autodesk products
February 2017
Missing download for subscription end users with multi-user licenses
how to identify IP address subnet mask range
No Serial Number Needed - Just Sign In (CLic Licensing)
Signing into Autodesk Account goes into a loop
Renew or Extend an Education License
Desktop App. Manager, Turn on/Off Updates Notification
Computer freezes after selecting “Enter a serial number” option during activation
Error 1327. Invalid Drive Letter and AdskExecuteSequence
The specified path is too long C:\ProgramData\Application Data\Autodesk
Delete or inactivate the Autodesk Community Account
How to activate a subscription or maintenance plan license from within a trial product
How to enable hidden files and folders in the Mac OS
Autodesk 2017 software hangs checking license
You don’t get a serial number when you renew your subscription (Mac)
You don’t get a serial number when you renew your subscription (Windows)
Installation of BDS 2017 deployment causes bluescreen on Windows
The Windows 10 default path length limitation (MAX_PATH) is 256 characters
Processing error when trying to activate subscription license
How do customers that have purchased a product on the estore become entitle for the next new release
Maintenance plan entitlement version products
What is SAM (Software Asset Management)?
How to disable the Start tab in DWG Trueview
Salesforce is disabling support for TLS 1.0 encryption. Am I prepared?
Autodesk Licenses for Citrix Environment
Installation fails with a CER error
Billing email address for monthly subscriptions
Using the Autodesk Prerequisite Checker
January 2017
How to start Autodesk Network License manger from a Windows command line.
Missing product updates in Autodesk Account and Autodesk Application Manager
Registry key that is set after AutoCAD 2016 Hotfix 4 installation
System requirements for Autodesk EAGLE
Why your old version program requires Activation Code every time when it is launched?
