Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Installation & Licensing
Latest Updates | New Knowledge Network Solutions | Installation & Licensing
2 REPLIES 2
matthew.d
3423702 Views, 2 Replies
Question: Where can I find a list of the latest Autodesk Knowledge Network support solutions that were created and/or updated regarding Installation & Licensing?
 Subscribe to receive updates for new Knowledge Network articles on Installation & Licensing.
For more updated solutions, also check out the Autodesk Blogs!
2016 Solutions 2017 Solutions
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
2 REPLIES 2
matthew.d
in reply to: matthew.d
August 2018
Background Reactor jobs fail with the message “ERR Job name ‘StartBackgroundReactorDaemon’ (#$$??$$#...
Flame Assist Network License Not Available Error -15.570.64
How to do an offline installation of your Autodesk product
Playback dropped on Flame
Student license showing as a trial version
Timeline FX can no longer be copy and pasted in Flame
Using student and commercial licenses for Autodesk products on the same computer
Change from network license to single license for Flame 2018 and later version
How to run multiple Autodesk license services at the same time
WaterMark in Cinema 4D or Arnold Render Farm (Arnold Terminal) on macOS
How to switch back to Arnold 4 with RLM licensing once new licenses with LMTools have been used
How to check how many users are connected to network license server / LMTools
How to obtain a license activation report
How to prevent the FLEXlm license server from being shut down remotely using LMTOOLS 11
Network license service unable to start with error -15.570.0
How to change server priority in network license environment on Windows
July 2018
Arnold License error: No SERVER lines in license file
How to check how many times my files have been accessed and downloaded in Autodesk Viewer
How to specify a specific port to the license server within a deployment
Adding seats to an existing subscription purchased from the online store
How to check if your VAT number is VIES compliant
What is the difference between Autodesk Stand-alone (Single-User) and Network (Multi-User) licensing...
When do I enter the VAT number of my company when purchasing online
When will I receive my invoice?
How to determine your computer and software operating system versions
June 2018
Licensing Error: “Establish an Internet connection to continue” due to inaccurate local system time ...
Option File Not Working or Functioning with Autodesk Network License Manager
System Error: 10049 “WinSock: Invalid
System requirements for Autodesk Factory Design Utilities 2019
How to change a trial standalone license of Autodesk Point Layout to network or BIM 360 license?
How to change the contract length during active subscription?
How to update your VAT number for your renewal
Unable to create deployment image for Autodesk Nesting Utility
May 2018
Replacing an existing license file LMTools
Software requires license information after using Batch File deployment method
Installing different versions on the same computer
April 2018
Error: 0.0.0 when pulling a 2017 license from the network license manager
Multi-User (network) licenses issue opening your Autodesk Software 2019
License manager not reading all network licenses
Inventor ETO license availability
How do I activate my student license for AutoCAD
How do I sign out of my software.
Safari can’t open the file “.exe” because no available application can open it.
Desktop Application - Web Services Error: Cannot use Production server.
Autodesk Desktop Application - how to implement the shared directory option
Options file RESERVE not work for client
Raster Design not working as expected after installation of 3th party Symbollibrary
Revit crashes frequently while in a machine
Vault security changes not effecting existing files
What directories are used by Autodesk software
C:\Autodesk contain to many files - can I delete these folders?
Autodesk software not activating requesting to log in instead
Autodesk Desktop Connector shows error code 400
Error: “The clock on your computer is wrong” when launching Autodesk Desktop App
Installing a software from the Autodesk Desktop App you get the error: “Error Code: 110”
You just installed Inventor 2017, but the professional features are missing.
Disaster Recovery Plan for Network License Manager (LMTOOLS) installation
Activation error-This session has timed out
You are trying to install the latest Autodesk Network License Manager (LMTOOLS), but you cannot remo...
can’t find the “setup.exe” file when attempting to install Autodesk Software.
Determining Installation Requirements… and Install Window Disappears
Subscribe to Communication Email
March 2018
Where to get more information about climate information for building energy analysis
Can Arnold 4 and 5 run together through NLM?
How to bound a command, on an option file, to a specific license using the “SIGN=” from the INCREMEN...
How to Move an installation from one computer to another.
How to regenerate Root Certificates for Serial Number based Single-User Subscription client computer
License manger is not reading vault licenses
Merge of several Recap Pro licenses possible to get more A360 online space
Autodesk License Service (x64) - 5.1.5 Hotfix installation
FAQ for CADdoctor for Autodesk Simulation FY19 Updates
After an Autodesk Application Crash and a CER report is submitted, an inaccurate reply message with ...
Can’t uninstall my Autodesk software
Having issues installing Autodesk software
How to install silently
Transfer License Utility is not working - What should I do?
When I download the software there are multiple download files however when you load the software it...
When I try to activate my Autodesk program it goes into trial mode
Device Management Discontinued in Autodesk Account
Licensing methods for Autodesk software
CER as soon as computer boots up
Installing Autodesk Product Design Suite to External Hard Drive?
Desktop App starts and close after a few seconds
How can I remove an Autodesk license from my computer?
How to specify a Serial Number to user in Network License
Error: 1325 is not a valid short file name
Autodesk Desktop App - Autodesk Product version not updated after installing update
How to provide feedback for the online Autodesk Viewer
FAQ - What settings to check when changing a Vault server IP or Subnet
Performing a “Status Enquiry” on LMTOOLS you notice that a command set on the option file is not hon...
4002 CLIC Error = 4002 = 0, No License available to run PowerInspect errors
File not found during installation (error code: 1308 or 1311)
Inventor Link XLS in Parameters dialog box will not read file in vertical format
How to reinstall Microsoft Visual C++ Runtime Libraries from Autodesk software installation package.
February 2018
Missing mcf120.dll installing an Autodesk software
How to add .MSP updates to Deployment Package
A360 Desktop Error: “Your A360 Desktop installation cannot be used anymore. Please install the lates...
Can you change the hostname in the license file after a server name change
-15,10.System Error: 10061 WinSock: Connection refused
How to configure Squid Proxy for single-user subscription license
How to install an individual Autodesk application if you are using a Suite
Job Processor does not create .dwg or .stp files
License server denials in debug.log file
The blue spinning circle does not go away on the thumbnail of a model in Fusion 360
Transferring scans from iPad to PC freezes at 64%
You cannot change serial number when activating your software
How to download Individual Products from an Industry Collection
How to hold and pull network license on same machine
Not able to take a particular network license from the server
Unable to reserve license with option file (Error: Exceeds License Count - Ignored)
Can student assets created with Educational Licenses be used once a subscription is purchased?
Does Point Layout included in AEC collection list
High availability servers
Icons are displayed too small in Sketchbook for Enterprise running on Windows Surface
Trying to download/install an Autodesk software you get the error Error 324 (net::ERR_EMPTY_RESPONSE...
Virtual Environments when using Autodesk software
Can I remove “Offline” devices from the Device tab in the Autodesk Account?
January 2018
License usage reporting conflict in NLM usage reporting
Licensing problem after upgrading computer (-15,570:36 “Operation now in progress”)
Need help with installing an Autodesk product without a license.
Quick Start: General installation workflow for Autodesk Product or Suite
HSM flow operation direction change crashes Inventor
How to install updates after deleting the C:\Autodesk folder
How to check my Network License file content
The basics of using procmon to troubleshoot issues
Error: “The upgrade patch cannot be installed by the windows installer service” when installing upda...
Error creating process < folder name\VCREDI~3.EXE > Reason C:\Windows\system32\advpack.dll
Does the RESERVE command overrides MAX_BORROW_HOURS command
Error 1638 “Another version of this program is already installed”
How Revit count elements in project
Licensing problem on CAMDUCT SOFTWARE 2018
Option File - How to use RESERVE PROJECT command
What’s the behavior and what licenses will be taken first if in an environment with Mullti-User Subs...
Browse button is grayed out when installing Autodesk software on a drive other than C:
C4R - Communicator shows a stuck sync process
Files affected by DRM tool can’t be opened
There is no place to enter a serial number or server name.
Despite my Autodesk software has been activated the registry shows 000-00000000 as serial number
Error: [-88.147.0.] A valid license could not be obtained by the network license manager is given
Extracting Software will cause an error “Autodesk Download Manager has stopped working”.
Source settings in Process Analysis
When installing or running AutoCAD/AutoCAD LT you get the error message ‘The product failed due to m...
What are the Autodesk installation program return codes for success and failure using SCCM
A360 Desktop is crashing randomly
Autodesk Desktop App reinstall fails
Autodesk Rendering: How to privately share renderings
Error: “A software problem has caused A360 Desktop to close unexpectedly” in A360 Desktop when tryin...
How to set up network license for T-Splines for Rhino
Opening Revit or AutoCad still keeps coming back with “put in the network server address” and keeps ...
Are there available SCCM scripts for installing updates and service packs
Cascading does not appear to work properly for Product Design Collection & Point Product Inventor
Error: The installer has encountered an unexpected error installing this package.
installation error 2502 and 2503
Unable to uninstall Autodesk software with Uninstall Tool
Where can I download Autodesk Desktop App?
Matt DiMichele
diana.yr
October 2018
Autodesk Desktop Connector will not launch on Mac
How to locate and install the Linux Network License Manager (NLM) init.d start script
Error “FlexNet Licensing error:-18,147” in LMTOOLS
How to create a plain text file using TextEdit on a Mac
Files saved in Autodesk application are not being saved into A360
How to submit a chat request for Registration and Activation team
How to make network files available while not connected to the network
Cannot share a download link for A360 Drive folders and recipients are always asked to sign in to th...
Autodesk Generative Design freezes on saving or is unable to save a model
​Editing a direct bolt joint value in the dialog causes a crash in Advance Steel 2016
Breaklines are being ignored when adding multiple at once to the surface definition in Civil 3D
Certificate of validation for Nastran solver
Inventor crashes during startup when Wacom device is connected
Animation flow script error using Raycast in 3ds Max Interactive
Debug log Error starting the Autodesk Network License Manage: EXITING DUE TO SIGNAL 15
Floor sections highlight in green when using 3ds Max Interactive VR projects
Error: “Failed to validate flow” when launching level in 3ds Max Interactive
How to install Autodesk products using command line
The VAT was not applied to my European purchase
Error: “Transaction check error” when trying to install the Network License Manager for Linux
Can I buy now and use later?
September 2018
Do I need to restart license server after changes made on Option file
Education license details for software downloaded from the Autodesk Education Community
How to restrict industry collection license usage with options file
Will the set flow rate be constant through each gate when using flow rate filling control on a valve...
Error : “Insufficient privileges” from Autodesk Customer Account opening a new support case
Crash when launching Screencast
Error: “Your firewall might be blocking the connection” appears for the Autodesk Desktop app when st...
Obtaining Autodesk Screencast support
Can a network license manager to be setup in Citrix Virtual Desktop?
Can Backburner run on Community Enterprise Operating System (CentOS) 6.7?
Cannot open Smoke 2016 archive on Flame Assist
Cuts don’t use ramp spindle speed when using 2D Adaptive toolpath
Unable to change the project role from Project Admin to Project Member in a Fusion Team Hub
Autodesk updates not showing on a deployment for a network license
Some licenses are missing from the license file, unable to pick up few licenses
Autodesk Self-Extract tool closes in your Windows environment when using Parallels Desktop on a Mac
Can I create deployment with multiple serial numbers into one SCCM?
Error: “The critical Stone+Wire database server is offline” appears when trying to render in Flame
Simulation Job Manager server connection issues after installing Moldflow 2019
Unable to return borrowed license because machine crashed or reformatted
Diana Rouge
Social Media Specialist
Administrator Productivity
