I have Inventor Product Design Suite 2018 and Entertainment Creation Suite 2018 on a perpetual licence and I'm thinking about reinstalling Windows 10, what are my options for re-installing the software?
Thanks in advance for your help.
Scott
Solved by pendean. Go to Solution.
You install like normal
If doesn't automatically activate online
You will need to contact Autodesk to get an activation code
You can try contacting Autodesk here: https://www.autodesk.com/support/contact-support?startHelpBranch=post-purchase/download-software
DarrenP
Hmmm, I wasn't very clear, sorry about that. 🙄
When I login to my account the software isn't showing, I have no products I can download, the question is where can I get the software again?
You either used the wrong login credentials (most common issue like you just wrote about), or if there is an account admin at your company at your end, they removed that from you for a reason.
Or you forget to tap this button at
https://manage.autodesk.com/products
Use the link above to contact Autodesk for the download if they provide them
DarrenP
