Hello Comunity,
Which Autodesk products does install or update it?
Our Security scanner found a long outdated version of it.
How could I uninstall or update this product alone?
@michel_ketterle wrote:...How could I uninstall or update this product alone?
Are you paying Autodesk an annual subscription for INVENTOR? IF yes, all updates and new versions are at your Subscription Autodesk Account Page here https://manage.autodesk.com/products
Yes I know. But "inventor interoperability" is not listed there. I assume it came with AutoCAD, Inventor or Navisworks. The only listed Product is Interoperability Revit
Do you mean this
https://manage.autodesk.com/products/updates
https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=GUID-0D655FB1-B3A1-47E6-86EC-77A2DCE5FBFC#:~:t....
https://interoperability.autodesk.com/ada.php
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-install-Rev...
https://www.cadforum.cz/en/download.asp?fileID=3744
Or something else?
Can you share a screenshot of this:
Also, what software do you use?
It is missing in my list.
The security scanner had a Problem with an outdated SSL library. I have no access to the scanner. I got an advice to check on this file paths.
The check was probably also due to the fact that we only have one PC that was reported. It seems that only this PC has Inventor Interoperability installed. However, we do not have any Autodesk products that are only used by one user.
I'd start there .. for the updates
I was asking more about what program was used:
Our Security scanner found a long outdated version of it.'
The Autodesk updates if installed should resolve theses.
On the specific Installation, Autodesk Navisworks Manage 2025 and "Revit interoperability" is installed. (as on many other PC)
In windows Apps & Features is no entry for "Interoperability for Inventor" the security scanner found the path to the program files directory.
@michel_ketterle wrote:It is missing in my list....
Here are the ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
and
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Contacting-a-techn...
