Good day!
I've been using Autodesk Inventor Pro 2021 with education license for a little while now. But suddenly i get a prompt saying "Inventor cannot access your license" whenever i start inventor. How can i resolve this? I've searched in the net for solutions but i think it is better to just ask it here. I attach a screenshot of the error below.
Thank you!
Solved by natasha.l. Go to Solution.
Solved by pendean. Go to Solution.
I have same problem but my license is not edu do you have any solution?
Sorry for late reply. No, I still havent solved it. I tried asking the online support but the solutions they suggested didnt solve the problem. 😕
I talked with customer support but at the end of talking we decided to clean uninstall.
I did it but ı didn't install yet
i posted the same error. and is the second time that it happened . could you solve this?
Are you done reinstalling it? Did it work? The customer support advised me the same solution. But im hesitant on uninstalling my inventor.
Hello @743705WVB67 & @cetin_yildirim,
Depending on your license type & current environment the solutions will be different, the error message indicates the possible solutions based on license type.
What license type do you have? Are you working remotely, via VPN etc.?
Network License Type
It is recommended that multi-user subscribers Borrow a License or Request an at home use license to avoid issues accessing a remote license. Make sure your products are eligible for a home use license by reviewing the eligibility requirements.
Single User License Type
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
we cleaned uninstall after Install lmtools and Inv 2021 also ACAD 2021 then both of them working.
There is no problem.
but this should be last way to solve this case.
hello @natasha.l
You r right but my license is NFR and I don't use any server pc, client and server machine are same pc so I dont't need to use borrow license or VPN.
When I have install first time Inv 2021 I met same problem also I get license error message from ACAD (
"License Error - ADLSDK_STATUS_AUTH_PENDING 22:Retry limit exceeded connecting to the Service" when launching AutoCAD or AutoCAD LT 2021 | AutoCAD 2021 | Autodesk Knowledge Network
I have used this solution for ACAD error and after this my Inventor license problem solved (kill two birds with one stone)
the problem has repeated for Inventor but ACAD error message changed and I couldn't solved this time so I had to clean uninstall.
@743705WVB67 you can try this https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Licens...
after ıf don't you can try clean uninstall
Hi @natasha.l ,
Im using a single user, educational license of Autodesk Inventor Pro 2021. Ive done updating the licensing service as instructed in the link
but i still have the same error. I may be wrong, but i recall that my license activation was automatic when i installed inventor. I didnt have license manager, but i was still able to use inventor before without any error.
Should i have a license manager (LMtools) even if my license is single sign on license type?
Hello @jken25,
You don't need LMtools or anything like that, because your license is managed & validated by online services.
Please run through all the steps I provided above for Single User because your license uses this technology.
Natasha
Helpful Links:
Hi @natasha.l ,
Thank you! I resolved it now. I just discovered that Autodesk Licensing Service is disabled on startup in my windows services setting. The error has nothing to do with the license at all. Thank you for the help!
Hello @jken25,
Thank you for returning. I am very glad you resolved this & I wanted to explain how this licensing service operates. 😊
When starting an Autodesk application, the Autodesk Licensing Service validates your license by accessing the Autodesk server & verifying your username. When this service is not running it will cause all Autodesk products that utilize this licensing to stop working.
Users of Autodesk software will need to maintain this service in good standing by applying the necessary updates & verify that the service is running so a license can be validated on start up.
Natasha
Helpful Links:
