03:53 PM
Hi everybody!
I'm trying to install Inventor 2019 but seems like Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 is failing (screenshot attached)
I checked the logfile and found the following:
2019/1/24:20:36:30 Guille W1L Download Complete VCREDIST2008SP1X64_6161 http://edutrial.autodesk.com/NetSWDLD/2019/INVNTOR/FC2A7A80-FF67-4FAA-9F95-918FFFCE2B6B/WI/{0E12F6B2-0EA6-4301-9BFA-52360BA5C4B6}/VCREDIST2008SP1X64_6161.tar.lzma2 2019/1/24:20:36:30 Guille W1L Notify complete VCREDIST2008SP1X64_6161 http://edutrial.autodesk.com/NetSWDLD/2019/INVNTOR/FC2A7A80-FF67-4FAA-9F95-918FFFCE2B6B/WI/{0E12F6B2-0EA6-4301-9BFA-52360BA5C4B6}/VCREDIST2008SP1X64_6161.tar.lzma2 2019/1/24:20:36:30 Guille W1L Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "C:\Autodesk\WI\Autodesk Inventor 2019\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q 2019/1/24:20:36:36 Guille W1L Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 return code: -1073740777 2019/1/24:20:36:36 Guille W1L Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Failed Installation aborted, Result=-1073740777 2019/1/24:20:36:36 Guille W1L verifyCertificates The file "C:\Users\Guille\AppData\Local\Temp\_AI3BA5.tmp\Setup\SolutionProvider.dll" is signed. 2019/1/24:20:36:36 Guille W1L CertFindCertificateInStore C:\Users\Guille\AppData\Local\Temp\_AI3BA5.tmp\Setup\SolutionProvider.dll Succeeded 2019/1/24:20:36:38 Guille W1L Download Play SOLUTION_PROVIDER_PACKAGE
I already search this issue in the forum, but I didn't found any solution or something that helps.
Thanks in advance!
Guille
Link copied
