Before I nuke all my Autodesk instalations (and they are many) removing all key and authorizations, I'd like to know If someone has a simple solution for this:
Already done the repair and re-install routine and the problem persists.
What hot fix 3 did you apply to Inventor 2017? There's no hot fix 3 so please clarify...
Also I never seen this message before either...
Mark Lancaster
& Autodesk Services MarketPlace Provider
Yesterday my Autodesk Desktop App flagged 2 updates for Inventor 2017, a SP2 and Hotfix 3, I set them to autodownload/install, after instalation I got that message.
So I assume you are referring to seeing Inventor 2017 R3.1.1 hot fix, is that correct?
If so have you even applied the mid-year release of Inventor 2017 R2 and then R3? If not then that hot fix is not going to work.
Launch Inventor, select Help/About Inventor and share a screen shot of what your Inventor is updated to. Make sure to remove any personal info like serial #s from the image if present.
Also just because your Desktop App shows there's a hot fix/update/service pack doesn't mean you need to install. Only install if you are having an issue and that the update resolves the issue. If its a mid year release like R2 and R3. Use your Autodesk Account and download/install from there.
Mark Lancaster
Mark and I are on the same page with this issue. I kind of use it as a learning experience. The mantra holds true, "If it is not broken, don't fix it." I always advise people that updates should only be installed if it fixes an error that you are experiencing or if it adds a feature that you require. Otherwise, ignore it. Most engineers can't afford to lose productivity because an unnecessary update broke their software.
