hi im trying to install Autocad Electrical 2017
heres my specs
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_rtm.101119-1850)
Language: English (Regional Setting: English)
System Manufacturer: ASUS
System Model: All Series
BIOS: BIOS Date: 06/28/13 21:39:24 Ver: 04.10
Processor: Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz (4 CPUs), ~3.2GHz
Memory: 4096MB RAM
Available OS Memory: 3776MB RAM
Page File: 1760MB used, 5790MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
the problem is it says Internal Error 2337.0, Ac32BitAppServer.dll like it says on the picture i have attached hope you guys can help me thanks a lot
Well you are not installing AutoCAD Electrical 2017, you are installing AutoCAD 2017. Look at the titlebar of your image. If you were installing AutoCAD Electrical if would state that.. Anyhow that error usually points to a corrupt download..
Download and install per:
1. Access the Autodesk Virtual Agent (http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...) and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
Good luck on your installation.
Mark Lancaster
& Autodesk Services MarketPlace Provider
A similar problem arose in Civil3D 2018. Now the answer is probably not relevant. But I was helped by the installation of SP1 from Windows
