Announcements
installing revit 2014
hello i am having trouble installing revit 2014 on my hp. i need revit on my computer for my college course as we have a test on it this weekend so i need it asap!
Otto
Hello jakeller12 and welcome to the Autodesk community!
It looks like you are having Revit installation issues. Community members with similar questions found the following article(s) useful:
For issues with Revit Server, please see the System Requirements for Revit Server.
If you are installing on Windows 10, please check that your product is compatible.
Software & Downloads
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Performing a Clean Uninstall
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
BJ.C
Hello @Anonymous
I'm sorry to hear that you are having problems with your installation.
The first thing I would do is downloading the product using this download method.  To download try the following:
  1. Click on the following link:  Downloading Previous Versions of Autodesk Software Using the Virtual Agent
  2. Click the link in step 2 to access the Virtual Agent
  3. Click on Download Links
  4. Click on Revit Products
  5. Then on Revit
  6. Select the appropriate product and click the link to download.  Note: Your product may have multiple files to download and you will need to download and activate each link separately.
It is necessary to perform the following steps to assure a successful installation:
  1. Make sure you Logon to your computer as an Administrator.
  2. Empty your TEMP folder.  To open the TEMP folder type %TEMP% in the address bar of Windows Explorer and hit Enter.  Delete all the contents of this folder.  Don't worry if deleting doesn’t remove everything by skipping files.
  3. Disable your Antivirus software.  All Antivirus programs are different.  You may need to consult your Antivirus website to learn how to temporarily disable your service.
  4. Disable UAC.  The following link will instruct you on how to disable UAC:
Turn User Account Control on or off
Double clicking on any of the downloaded files will begin the installation process.
You will not likely be able to install this on a Windows 10 machine.
Thank you for taking part in our community forum!
Kind Regards,
BJ.C
Technical Support Specialist
