I'm having trouble installing aTools on maya 2016.
I'm getting this -
# Error: ImportError: file <maya console> line 154: No module named aTools
I just downloaded the files, and pulled it into the maya viewport like the info said.
Solved by MAMILOVE98. Go to Solution.
Solved by beorn.leo. Go to Solution.
Solved by pshwayka. Go to Solution.
The installation script for aTools wants to download the aTools.zip file from the internet. If you aren't connected to the internet or have a firewall in place that prohibits that kind of activity, you will get this error.
ok, just found the answer. I'll leave it here for those who come looking...
Download the aTools.zip file from here:
http://www.trickorscript.com/aTools/
Then point the installer to wherever you saved the file. It will do an offline installation.
I'm trying to install aTools on a PC in Maya 2017. I drop the .mel File into the window to install and get this error...
Error: file: C:/Users/kelly/Downloads/aTools_install.mel line 174: AttributeError: file C:\Program Files\Autodesk\Maya2017\bin\python27.zip\hashlib.py line 138: 'module' object has no attribute 'openssl_md_meth_names' #
Since I'm working on a work machine I'm guessing there's a firewall set up preventing me from installing it? I want to do the offline install but I don't even get that option. Nothing happens when I try to install it. I just get this error in the script editor. Whats weird is it works fine in 2015. No issues. Didn't even have to do an offline install.
Thanks in advance for the help!!
Hello @Vawter19,
Welcome.
Try to clean your temp folder & also take a look at how you can check the permissions on the mentioned folder.
Thank you for posting to the forums.
Please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Hello @Vawter19,
Sure, I can try to provide some more detailed steps for you but if you need further assistance with Windows you should contact them or an IT professional.
Please try the steps below:
Keep us posted.
Natasha
Helpful Links:
Hello @Anonymous
Just checking in with you, hope you were able to resolve this issue.
Natasha
Helpful Links:
Hello @stavhavivi,
Reach out to the creators of a Tool to find out more about installing it to use with Autodesk Maya 2016. They should be able to offer some better input on why this is not installing, as this is not an Autodesk product.
Natasha
Helpful Links:
Hello. May I question another one?
First. Thanks your comment.
That is very useful.
I got a Maya2022 in window.
I Know maya 2022 uses python3. So I fix the atools script that using "urllib2" to using "urllib"
Then, a offline installation pop-up window appears.
Connecting "atools.zip" to maya, there is a error.
# Error: UnboundLocalError: file <maya console> line 91: local variable 'response' referenced before assignment
How can I fix it..?
I got a solution without correction. I hope it helps someone.
