Installer Initialization Failed
epconde
epconde
Recently, I've been trying to install Revit since I need it for a school project, but every time I try to do it, I get the "Installer initialization failed" window. It always fails, and I always receive Error 1. I tried looking at the Registry Editor to follow any tips. I tried a clean uninstall and even uninstalling my AutoCad to see if that was causing problems. I even tried installing previous versions to see if it was an issue with the version, but none are working. Can anyone please help me with this? Now, I can't install Revit AND AutoCAD even though I had previously managed to install AutoCAD 2024.
 I attached the windows that I've been getting when trying to install it
Replies (17)
epconde
I tried using custom install and this is the error code I got this time
pendean
Community Legend
Community Legend
epconde
I tried clicking it but nothing pops up
epconde
I checked the link before hand and none worked, and when I clicked the log file, nothing pops up
pendean
Community Legend
Community Legend
Odd, but that can happen.
In your Windows File Explorer, type this in the address bar
%TEMP%
This will take you to your login's TEMP folder where you will find log file(s) and perhaps the one you need if you sort by date. Share that here.
Oh, and by the way, if you have more than say 5000 objects in that folder it is time you tried to empty it as much as Windows will let you too (you cannot delete everything but you can safely remove a good portion of them).
epconde
Is it this one?
Simon_Weel
On line 54 it says "Access is denied [system:5]". You need to be logged in as Administrator to perform installations.
The Windows Troubleshooter could be of help too.
epconde
Tried it and still didn't work. Here's the log this time
mdavis22569
Hi @epconde
Can you try using the full offline installers from the following:
https://forums.autodesk.com/t5/installation-licensing/2025-product-download-links/m-p/12663593/highl...
Revit 2025:
P1:
https://efulfillment.autodesk.com/NetSWDLD/ODIS/prd/2025/RVT/686CE2A3-7C33-3AD5-806A-75A6E648117F/SF...
P2:
Mike Davis
epconde
Same error still
mdavis22569
This one is slightly different, but 3 different ones worry me, that it's someone on the PC blocking it.
What do you have for a firewall / anti-virus?
So let's look at a few things:
Do you have Admin rights on this PC?
Is your Anti-Virus / Firewall turned off?
Can you try this:
Can you clean out your %temp% folder
Clean out the C:\Autodesk folder of any prior Revit 2025 folders
Clean out the C:\Download (except my 2 downloads)
Turn off / or disable your firewall - antivirus.
After, right click on the first zip and run as admin and let it fully extract.
Mike Davis
epconde
I am using Windows Defender only for my antivirus
I have admin rights
My anti-virus and my firewall in on
I already tried clearing out the %temp% folder, the autodesk folders, and the download folder
I will try out the turning off of the firewall and see if it will be installed
mdavis22569
Can we also try running the Microsoft Fixit tool prior.
https://support.microsoft.com/en-us/topic/fix-problems-that-block-programs-from-being-installed-or-r...
Lets also make sure if possible that you check and verify that you don't have any pending Windows updates.
Mike Davis
epconde
For some reason, it still didn't work
epconde
My device is fully updated and the tool can't detect autodesk on my device
epconde
I think I found the problem, I can't install ADSK Licensing Servives since I'm trying to install it first before Revit. I tried installing it but installing adsk licensing installer also says intaller failed to initialize
mdavis22569
Can you share the error for this: I can't install ADSK Licensing Services.
And you have 100% full Admin rights on this PC?
I didn't see, is this a work PC or personal?
Mike Davis
