Installatoin hangs at adsklicensing-installer.exe
licensingX4M2F
licensingX4M2F
I created a deployment for Revit, Inventor and Autocad. installing during OSD with SCCM. It appears to hang at adsklicensing-installer.exe.  The install log for the .exe is never created so i have no way to post it. If i end the task in taskmgr during OSD it will continue to install the program. and the other Auto-desk programs as well with no issue.  It only does this on what ever the first auto desk program that is ran in the task sequence. I have tried to change the order of installation but it does the same thing.
Again i would post a log but no log is being created.
Windows 10 1809
Autodesk 2020
any ideas?
EDIT:
Just tried again this time after ending task it failed the installation of the program. and it didnt install.  I guess its random but it seems to link back to adsklicensing-installer.exe
Replies (78)
Mark.Lancaster
@licensingX4M2F
Are you seeing this service and its is started?
Mark Lancaster
licensingX4M2F
No that does not appear in services, which makes sense because that .exe is not installing.
Mark.Lancaster
@licensingX4M2F
On the machine, do you see this folder C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing
Mark Lancaster
licensingX4M2F
Yes that folder is there but ill have to restart OSD to see if it gets created on the first attempt,  Currently it has moved to inventor and it still hanging on the adsklicensing-installer.exe for that program.
Mark.Lancaster
@licensingX4M2F
Go to this location C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\9.0.1.1462\AdskLicensingService and right mouse click on AdskLicensingService.exe and run as administrator.
Mark Lancaster
licensingX4M2F
Currently says another program is already using this file.
Please note still in OSD.
Mark.Lancaster
@licensingX4M2F
Not sure what you mean still in OSD..
Anyhow stop any installation going on, reboot the machine and then run that program as admin.
Mark Lancaster
licensingX4M2F
SCCM OSD stands for operating system deployment.  its when on is imaging the computer.  A deployment was created for autodesk that works with sccm, however its hanging on adsklicensing-installer.exe.
licensingX4M2F
From the research i have been doing it seems that adsklicensing-installer.exe  does not like to be ran as The System account.
As the program will run fine as local admin or domain account.  This appears to be an issue with the adsklicensing-installer.exe installer.
Mark.Lancaster
@licensingX4M2F
Some people have experience this and others have not..  If you get the service to start then the installation will finish.
Mark Lancaster
licensingX4M2F
@Mark.Lancaster   Thats the thing During OSD i check when it first hangs there is no service to start... and no logs.. the exe starts but nothing happens..
Do you know of other post to review with a similar issue?
Mark.Lancaster
@licensingX4M2F
For 2020 product line there's numerous posting and Autodesk articles about not getting an installation of the product to finish.   But I haven;t really heard on anything related to SCCM..  Its all about this service and getting it to start.
Mark Lancaster
licensingX4M2F
@Mark.Lancaster  or @natasha.l Do you know if Autodesk has recognized there is an issue, and they a fix will be released or a KB?
licensingX4M2F
So i got in this morning and ran an elevated command prompt with "nt authority\system" and ran (.\Img\Setup.exe /W /q /I Img\AUTOCAD2020_SCCMDeployment.ini /language en-us) which is waht is used in SCCM during OSD. And autodesk installed successfully. I also used the same source files that SCCM uses as well..
so the mystery continues why does it hang during OSD.....
Maybe a full gui is needed?
licensingX4M2F
I had to take adsklicensing-installer.exe and break it out under its own install.
AdskLicensing-installer.exe --mode unattended --unattendedmodeui none
After i run the above during OSD the other Autodesk programs install fine.
OP,
I heard of this issue but it didn't start happening to me until deploying fresh labs started. Next to no issue on my test OSD box until things started to get down to deadlines....
Any way, did you use a package or app? I had the same issue using the adksLicensing-Installer.exe (app model) from 3DSMax (cause well my apps are in alpha order)…. Testing a package right now - but may have to pull the .exe from a different adesk app.
Mark.Lancaster
@Anonymous
You may want to review this recommendation:  https://synergiscadblog.com/2019/07/24/autodesk-licensing-mechanism/ before installing or deploying any 2020 product line.
Mark Lancaster
Hey Mark,
Thanks for the quick reply!
We use network license manager … so not affected by what I'm taking from the article.
And the adesk packages were all built at the begging of july.
I guess my take away from this since I use license server is that I need to remove the adksLicense code from the .ini configuration?
Please advise if I happen to miss a detail from the article.
-M
Mark.Lancaster
@Anonymous
That licensing mechanism is only for carried over standalone perpetual license or single user subscription based product.  As far as I know it is not needed for those products that are network based.
Update:  However let me clarify this... it is needed if you ever need to reset your 2020 product line license (like single user to network based or visa-versa..
Mark Lancaster
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
