Message 1 of 11
Installation Incomplete. Some products failed to install. Error code:1603
I am trying to install 3ds max for the 16th or 17th time but getting the same message as shown below.
This is the error I get while installing 3ds max.
Not only with max but also with Revit and Autocad the same error appears.
The things I have already tried:
- Clean uninstallation then reinstalling.
- Long file name change in the registry as told in one of the Autodesk forums.
- Making space in the windows drive and the drive I am trying to install the program.
- .NET framework and C++ Redistributables uninstalled and installed the ones that comes with the setup.
- Using the .msi setup from the (x64) folder instead of the Setup.exe.
- Uninstalled all the Autodesk products as mentioned before.
I have tried everything but still can't get the programs to install. It happens with Autocad, Revit and 3ds Max.
I am also attaching my setup log file in case it helps.
Thank you in advance as I have received much help from this community before too.
Thank you again.
