Announcements
AREA content is being relocated to the Autodesk Community M&E Hub and Gallery. Notifications may be intermittently unavailable 10–12 November. Learn more HERE.
INSTALLATION ERROR
INSTALLATION ERROR
INSTALLATION ERROR
HI upon installing the software im getting this error message :
AutoCAD Installation Error; "Aborted.(Error: 9). h
How can i fix this??
Otto
Hello iamsupermart and welcome to the Autodesk community!
It looks like you're receiving Error 9 during installation. This is typically due to the download manager getting disconnected. The following article(s) should help you resolve the problem:
Error 8 or Error 9 during install
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
yes
RDAOU
Hello @Anonymous
Try the following:
  1. Add the domain *autodesk.com to the safe list in Internet Security Options
  2. disable your Antivirus and Firewall temporarly throughout the download & Installation. You can re-enable after you download and install
  3. Try again
If the above doesn't work; you can try one of the following two options:
  1. Try using a different browser (I recommend Safari)
  2. Try downloading from Virtual Agent then install...Autodesk VIRTUAL AGENT
