Já tentei instalar pelo instalador padrão, já baixei os arquivos no browser e tentei instalar, e já fiz uma limpeza no meu computador pra apagar todos os arquivos do AutoCAD e do AutoDesk q pudessem atrapalhar. Nada surtiu efeito, alguém poderia me ajudar?
An image of a failed installation is no use to us.. However in that same message of a failed installation, is a link to your installation log file. That's crucial in determining the root cause of a failed installation. At this point we can only speculate what the issue is.. So post your installation log file if you are still having an issue. If you do end up posting your installation log file, make sure to review it first to ensure there's no personal information such as your serial # in it. Personal information such as your serial # should never be shared here.
Or follow these steps to download and install your product
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
Good luck on your installation and report back on your progress.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Google Translate
I already tried to install it by the default installer, I already downloaded the files in the browser and tried to install, and I already did a cleaning in my computer to delete all the AutoCAD and AutoDesk files that could disturb. Nothing worked, could anyone help me?
Hello @delpupo14,
I have translated your post for you this is an English forum, please translate your posts for better feedback in the future. As Mark mentioned, try to download via the Virtual Agent and prepare the system before downloading & installing. Please run through the steps:
Thank you for posting. Please let us know if you resolved the issue.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
that's the installation log
This is a public forum, please refrain from posting serial numbers or personal information
Edited by
Discussion_Admin
First I guess you didn't read the warning about checking to make sure to remove personal information before posting your installation log. You just shared your serial # with everybody.
Your installation is failing on Microsoft C++ 2008. So remove all instances of Microsoft C++ under Windows Control Panel/Program&Features/Add and Remove programs. Then run the setup.exe located in the extracted files from the downloaded parts.
Mark Lancaster
Hello
I have the same issue.... text reads like this in the fail log on the image, can someone help why this happens?
Welcome to the community.
Your installation is simply failing due to the method (web installer) you're using. This method is unreliable and shouldn't be used.
However if the installation does fail using this method, please post your installation log file here so we can review it. Posting info: Sometimes installation log files contain personal information such as your serial #. Prior to posting your log file please make sure to remove such info.
Mark Lancaster
Followed the steps, but not success on install
here`s the log, hope you can give me some help on this
2017/3/24:05:08:23 === Setup started ===
2017/3/24:05:08:23 Path_Length: 154
2017/3/24:05:08:23 Current Directory C:\Autodesk\AutoCAD_Architecture_2016_English_Win_32_64bit_wi_en-us
2017/3/24:05:08:23 Launch
2017/3/24:05:08:23 CommandLine /akamai /sid a1b3A00000AR5JlQAL /skipEULA /url "http://efulfillment.autodesk.com/NET16SWDLD/2016/ARCHDESK/WI/AutoCAD_Architecture_2016_English_Win_3..."
2017/3/24:05:08:23 Current Directory C:\Users\workstat\AppData\Local\Temp\_AI3534.tmp
2017/3/24:05:09:59 === Setup ended ===
2017/3/24:05:08:33 Setup started on DESKTOP- ===
2017/3/24:05:08:33 Path_Length: 154
2017/3/24:05:08:33 Current Directory C:\Users\ \AppData\Local\Temp\_AI3534.tmp
2017/3/24:05:08:33 Launch
2017/3/24:05:09:14 Download Play SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ARCHDESK/WI/{2159C9BF-CFE1-43AA-9A31-917B96A01A28}/...
2017/3/24:05:09:15 Download Complete SETUPMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ARCHDESK/WI/{2159C9BF-CFE1-43AA-9A31-917B96A01A28}/...
2017/3/24:05:09:15 Download Play SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/ARCHDESK/WI/{2159C9BF-CFE1-43AA-9A31-917B96A01A28}/...
2017/3/24:05:09:57 Download Complete SETUP_CONFIG http://efulfillment.autodesk.com/NET16SWDLD/2016/ARCHDESK/WI/{2159C9BF-CFE1-43AA-9A31-917B96A01A28}/...
2017/3/24:05:09:57 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ \AppData\Local\Temp\_AI3534.tmp\Setup\AcSetup.dll
2017/3/24:05:09:57 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/24:05:09:59 PageOpen LaunchDialog
2017/3/24:05:10:16 PageOpen LicenseDialog
2017/3/24:05:10:16 PageOpen ProductInfoDialog
2017/3/24:05:14:28 PageOpen ProductSelectionDialog2
2017/3/24:05:14:34 PageOpen FullProgressDialog
2017/3/24:05:14:35 Download Play STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ARCHDESK/WI/{2159C9BF-CFE1-43AA-9A31-917B96A01A28}/...
2017/3/24:05:14:36 Download Complete STARTMARKER http://efulfillment.autodesk.com/NET16SWDLD/2016/ARCHDESK/WI/{2159C9BF-CFE1-43AA-9A31-917B96A01A28}/...
2017/3/24:05:14:36 Download Play VCREDIST2008SP1X86 http://efulfillment.autodesk.com/NET16SWDLD/2016/ARCHDESK/WI/{2159C9BF-CFE1-43AA-9A31-917B96A01A28}/...
2017/3/24:05:14:38 Download Complete VCREDIST2008SP1X86 http://efulfillment.autodesk.com/NET16SWDLD/2016/ARCHDESK/WI/{2159C9BF-CFE1-43AA-9A31-917B96A01A28}/...
2017/3/24:05:14:38 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD Architecture 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/3/24:05:14:49 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/3/24:05:14:51 PageOpen InstallCompleteDialog
2017/3/24:05:15:28 === Setup ended ===
2017/3/24:05:43:55 === Setup started on DESKTOP- by ===
2017/3/24:05:43:55 Path_Length: 154
2017/3/24:05:43:55 Current Directory C:\Autodesk\AutoCAD_Architecture_2016_English_Win_64bit_dlm
2017/3/24:05:43:55 Launch
2017/3/24:05:43:55 CommandLine
2017/3/24:05:43:55 Current Directory C:\Users\ \AppData\Local\Temp\_AIBEAC.tmp
2017/3/24:05:44:19 === Setup ended ===
2017/3/24:05:44:01 === Setup started on DESKTOP- by ===
2017/3/24:05:44:01 Path_Length: 154
2017/3/24:05:44:01 Current Directory C:\Users\ \AppData\Local\Temp\_AIBEAC.tmp
2017/3/24:05:44:01 Launch
2017/3/24:05:44:01 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ \AppData\Local\Temp\_AIBEAC.tmp\Setup\AcSetup.dll
2017/3/24:05:44:01 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/24:05:44:16 PageOpen LaunchDialog
2017/3/24:05:44:20 PageOpen LicenseDialog
2017/3/24:05:44:25 PageOpen ProductInfoDialog
2017/3/24:05:47:15 PageOpen ProductSelectionDialog2
2017/3/24:05:47:21 PageOpen FullProgressDialog
2017/3/24:05:47:21 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\AutoCAD_Architecture_2016_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/3/24:05:47:28 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/3/24:05:47:31 PageOpen InstallCompleteDialog
2017/3/24:05:48:11 === Setup ended ===
2017/3/24:05:56:59 === Setup started on DESKTOP- by ===
2017/3/24:05:56:59 Path_Length: 154
2017/3/24:05:56:59 Current Directory C:\Autodesk\AutoCAD_Architecture_2016_English_Win_64bit_dlm
2017/3/24:05:56:59 Launch
2017/3/24:05:56:59 CommandLine
2017/3/24:05:56:59 Current Directory C:\Users\ \AppData\Local\Temp\_AIB6D2.tmp
2017/3/24:05:57:21 === Setup ended ===
2017/3/24:05:57:02 === Setup started on DESKTOP- by ===
2017/3/24:05:57:02 Path_Length: 154
2017/3/24:05:57:02 Current Directory C:\Users\ \AppData\Local\Temp\_AIB6D2.tmp
2017/3/24:05:57:02 Launch
2017/3/24:05:57:03 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ t\AppData\Local\Temp\_AIB6D2.tmp\Setup\AcSetup.dll
2017/3/24:05:57:03 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/24:05:57:19 PageOpen LaunchDialog
2017/3/24:05:57:25 PageOpen LicenseDialog
2017/3/24:05:57:28 PageOpen ProductInfoDialog
2017/3/24:05:58:09 PageOpen ProductSelectionDialog2
2017/3/24:05:58:12 PageOpen FullProgressDialog
2017/3/24:05:58:13 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\AutoCAD_Architecture_2016_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/3/24:05:59:13 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
Sorry to hear...
So go into WIndows Control Panel/Program & Features/Add and Remove program and remove all instances of Microsoft Visual C++ (all versions and year versions). Next use the Microsoft Fixit program (link in my signature - but you have to come back to this posting to see my signature/link) and make sure all C++ information is removed from the listing. With Fixit you need to run it again for each application that needs to be uninstalled.
Now start the installation again using the setup.exe..
But it may fail again and at this point we will need to modify the setup.ini file to get around the C++ issue.
Mark Lancaster
finally is installed, but now it says the license and product key are wrong and cant activate it, what can i do?
Welcome to community..
Its great to hear you got something finally installed but what did you install? Details are necessary...
Sorry I just realized you were already posting what you are trying to install... Without telling us what serial # you have can you tell us what product key you are using..
Mark Lancaster
Thanks, no problem, it was my mistake, i got two emails from you and entered the wrong number, is up and running now, thanks for all your help
