Installation Bug Windows10
marco3RKCB
Observer
Observer
marco3RKCB
Observer
Observer
Following all the instructions here:
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/fus...
I am still unable to get Fusion to run on Windows10.
Thanks for helping!
Marco
natasha.l
Hello @marco3RKCB
You can pull system logs so we can have a closer look as to why the installation is not working.
Also let us know if you have had a recent update applied to your system lately.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
marco3RKCB
Observer
Observer
Natasha
Not sure if you read my solution:
I have found (by chance!) the solution:
right click on the fusion program file, choose <restore previous versions> and select <run application in compatibility mode>, choose <widnows 8> and voilà Fusion would start perfectly.
see attachment.
I could not pull system logs because I was unable to open Fusion.
Anyways, it works now!
Thanks!!
