Announcements
Install Autodesk Material Library 2016 Failed Installation aborted, Result=1603
I have try to install autocad on my computer which is a windows 10 x64 an i just keep getting this error ( Install Autodesk Material Library 2016 Failed Installation aborted, Result=1603) i have tried everything i found here to try to fix it but i still can't fix it. can anyone help. Thank you.
Replies (7)
Otto
Hello ksol862 and welcome to the Autodesk community!
It looks like you’re seeing Error 1603. Error 1603 is a generic error generated by the Microsoft Windows Installer (MSI) when a problem occurred during the installation of your Autodesk product. The following article(s) should help you resolve the problem:
Error 1603 during installation of Autodesk software
Errors during AutoCAD software installation
Here is some general information about installation, licensing and downloading Autodesk software:
AutoCAD 2012 installation fails on machine with NET 4.5
Previous Versions of Autodesk Software
Installation, Activation and Licensing
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Mark.Lancaster
@Anonymous
Welcome to the community...
First download and install the material library from here.  Once that is completed, go to the Autodesk Virtual Agent and follow the download links to your product.  Download all of the parts first (some applications may only have a single part to download) and then go to your download location.  Extract (double click) part 1 (or the single part download) and in a few seconds the extraction will start.   It will then prompt you to extract to C:\Autodesk and once the extraction is finished the installation will start.  Also make sure you have admin rights, UAC is turned off and Anti-Virus temporary disabled prior to installation.
Mark Lancaster
thank you for the links on the information, but unfortunately i was unable to solve my problem with what was there. I will keep searching to find a solution or a way to install it. Thank you for the help.
Thanks for the help, but it did not work. i don't know if I'm doing something wrong somewhere or it just did not work.
I am having the same issue......
2016/12/28:14:42:03 cmaxw DESKTOP-RI1URQ6 === Setup started on DESKTOP-RI1URQ6 by cmaxw ===
2016/12/28:14:42:03 cmaxw DESKTOP-RI1URQ6 Path_Length: 154
2016/12/28:14:42:03 cmaxw DESKTOP-RI1URQ6 Current Directory C:\Autodesk\Inventor_2016_English_Win_64bit_wi_en-us
2016/12/28:14:42:03 cmaxw DESKTOP-RI1URQ6 Launch
2016/12/28:14:42:03 cmaxw DESKTOP-RI1URQ6 CommandLine /PK 797H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/Inventor_2016_English_Win_64bit_wi_en-us_Set...
2016/12/28:14:42:03 cmaxw DESKTOP-RI1URQ6 Current Directory C:\Users\cmaxw\AppData\Local\Temp\_AI8411.tmp
2016/12/28:14:42:56 cmaxw DESKTOP-RI1URQ6 === Setup ended ===
2016/12/28:14:42:06 cmaxw DESKTOP-RI1URQ6 === Setup started on DESKTOP-RI1URQ6 by cmaxw ===
2016/12/28:14:42:06 cmaxw DESKTOP-RI1URQ6 Path_Length: 154
2016/12/28:14:42:06 cmaxw DESKTOP-RI1URQ6 Current Directory C:\Users\cmaxw\AppData\Local\Temp\_AI8411.tmp
2016/12/28:14:42:06 cmaxw DESKTOP-RI1URQ6 Launch
2016/12/28:14:42:07 cmaxw DESKTOP-RI1URQ6 Download Play SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2016/12/28:14:42:08 cmaxw DESKTOP-RI1URQ6 Download Complete SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2016/12/28:14:42:08 cmaxw DESKTOP-RI1URQ6 Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2016/12/28:14:42:44 cmaxw DESKTOP-RI1URQ6 Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2016/12/28:14:42:56 cmaxw DESKTOP-RI1URQ6 PageOpen LaunchDialog
2016/12/28:14:43:01 cmaxw DESKTOP-RI1URQ6 Inventorui== Parameter: Prereq_8 SetupMode:7 InstallState:1 InstallAction:0 Message:
2016/12/28:14:43:01 cmaxw DESKTOP-RI1URQ6 PageOpen LicenseDialog
2016/12/28:14:43:01 cmaxw DESKTOP-RI1URQ6 PageOpen ProductSelectionDialog2
2016/12/28:14:43:04 cmaxw DESKTOP-RI1URQ6 PageOpen FullProgressDialog
2016/12/28:14:43:05 cmaxw DESKTOP-RI1URQ6 Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2016/12/28:14:43:05 cmaxw DESKTOP-RI1URQ6 Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2016/12/28:14:43:05 cmaxw DESKTOP-RI1URQ6 Download Play VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/12/28:14:43:08 cmaxw DESKTOP-RI1URQ6 Download Complete VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/12/28:14:43:08 cmaxw DESKTOP-RI1URQ6 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\cmaxw\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2016/12/28:14:43:17 cmaxw DESKTOP-RI1URQ6 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2016/12/28:14:43:17 cmaxw DESKTOP-RI1URQ6 Download Play VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/12/28:14:43:20 cmaxw DESKTOP-RI1URQ6 Download Complete VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/12/28:14:43:20 cmaxw DESKTOP-RI1URQ6 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\cmaxw\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2016/12/28:14:43:21 cmaxw DESKTOP-RI1URQ6 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2016/12/28:14:43:22 cmaxw DESKTOP-RI1URQ6 Download Play CADM http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CADM_...
2016/12/28:14:43:24 cmaxw DESKTOP-RI1URQ6 Download Complete CADM http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CADM_...
2016/12/28:14:43:24 cmaxw DESKTOP-RI1URQ6 Installing Autodesk® CAD Manager Tools:   INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\"  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2016" SETUP_PACKAGECODE={8CB42675-2000-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="SSE2 Support Check,Microsoft Visual C++ 2012 Redistributable (x86) Update 4,Microsoft Visual C++ 2012 Redistributable (x64) Update 4,;;;;" PACKAGEUPI={885CB096-0DBB-411F-AE76-39C6C0B5929C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/12/28:14:43:29 cmaxw DESKTOP-RI1URQ6 Install Autodesk® CAD Manager Tools Succeeded
2016/12/28:14:43:29 cmaxw DESKTOP-RI1URQ6 Download Play SUCCESSMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SUCCE...
2016/12/28:14:43:30 cmaxw DESKTOP-RI1URQ6 Download Complete SUCCESSMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SUCCE...
2016/12/28:14:43:30 cmaxw DESKTOP-RI1URQ6 PageOpen InstallCompleteDialog
2016/12/28:14:43:32 cmaxw DESKTOP-RI1URQ6 === Setup ended ===
2016/12/28:14:44:01 cmaxw DESKTOP-RI1URQ6 === Setup started on DESKTOP-RI1URQ6 by cmaxw ===
2016/12/28:14:44:01 cmaxw DESKTOP-RI1URQ6 Path_Length: 154
2016/12/28:14:44:01 cmaxw DESKTOP-RI1URQ6 Current Directory C:\Autodesk\Inventor_2016_English_Win_64bit_wi_en-us
2016/12/28:14:44:01 cmaxw DESKTOP-RI1URQ6 Launch
2016/12/28:14:44:01 cmaxw DESKTOP-RI1URQ6 CommandLine /PK 797H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/Inventor_2016_English_Win_64bit_wi_en-us_Set...
2016/12/28:14:44:01 cmaxw DESKTOP-RI1URQ6 Current Directory C:\Users\cmaxw\AppData\Local\Temp\_AI51DB.tmp
2016/12/28:14:44:16 cmaxw DESKTOP-RI1URQ6 === Setup ended ===
2016/12/28:14:44:04 cmaxw DESKTOP-RI1URQ6 === Setup started on DESKTOP-RI1URQ6 by cmaxw ===
2016/12/28:14:44:04 cmaxw DESKTOP-RI1URQ6 Path_Length: 154
2016/12/28:14:44:04 cmaxw DESKTOP-RI1URQ6 Current Directory C:\Users\cmaxw\AppData\Local\Temp\_AI51DB.tmp
2016/12/28:14:44:04 cmaxw DESKTOP-RI1URQ6 Launch
2016/12/28:14:44:04 cmaxw DESKTOP-RI1URQ6 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2016/12/28:14:44:04 cmaxw DESKTOP-RI1URQ6 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2016/12/28:14:44:16 cmaxw DESKTOP-RI1URQ6 PageOpen LaunchDialog
2016/12/28:14:44:23 cmaxw DESKTOP-RI1URQ6 Install CustomCallback Info Invoking custom callback for details: [ACEINVADDIN] CB_FUNC=CBCatalogBrowserMessage CB_SOURCE=C:\Users\cmaxw\AppData\Local\Temp\_AI51DB.tmp\Setup\AcadeUI.dll
2016/12/28:14:44:23 cmaxw DESKTOP-RI1URQ6 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=The manufacturer database is available for download. URLTitle=Learn more URLLink=http://www.autodesk.com/autocadelectrical-content-default-catalog-database-2016
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 PageOpen LicenseDialog
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 PageOpen ProductInfoDialog
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 PageOpen InventorFlavorSelectionDialog
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==DefaultLanguage: en-us
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==InstallName: INVENTOR
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==ProductName: Autodesk Inventor 2016
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==DisplayName: Autodesk® Inventor® 2016
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==DeploymentName:
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupTitle: Autodesk Inventor 2016
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==ConfigTransform:
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==ExeParams:
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==ProductCode: {7F4DD591-2064-0001-0000-7107D70F3DB4}
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==SupportLink:
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==InfotainmentLink:
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==MsiFileName: inventor.msi
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==AdminImageConfigName: Imgx64
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==AdminImageRoot:
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==GetBaseDeploymentName:
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==DeploymentLocation:
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==DocumentLink: http://autodesk.com/inventor-install-2016-enu
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==InstallDeploymentShortcut:
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==ModifyDeploymentShortcut:
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupLockType: 2
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupNetworkType:  1
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==SystemLocale: 4105
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==EvalMsiFilePath: C:\Users\cmaxw\AppData\Local\Temp\_AI51DB.tmp\SetupRes\eval.msi
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2016\EULA
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==InstallLogPath: C:\Users\cmaxw\AppData\Local\Temp\Inventor2016Install.log
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==ConfigFile: C:\Users\cmaxw\AppData\Local\Temp\_AI51DB.tmp\Setup.ini
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupPath: C:\Users\cmaxw\AppData\Local\Temp\_AI51DB.tmp\
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==NetworkLogPath:
2016/12/28:14:45:20 cmaxw DESKTOP-RI1URQ6 Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2016
2016/12/28:14:45:49 cmaxw DESKTOP-RI1URQ6 Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2016/12/28:14:45:49 cmaxw DESKTOP-RI1URQ6 PageOpen ProductSelectionDialog2
2016/12/28:14:45:54 cmaxw DESKTOP-RI1URQ6 PageOpen FullProgressDialog
2016/12/28:14:45:55 cmaxw DESKTOP-RI1URQ6 Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2016/12/28:14:45:55 cmaxw DESKTOP-RI1URQ6 Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2016/12/28:14:45:55 cmaxw DESKTOP-RI1URQ6 Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/12/28:14:45:55 cmaxw DESKTOP-RI1URQ6 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\cmaxw\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2016/12/28:14:45:56 cmaxw DESKTOP-RI1URQ6 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2016/12/28:14:45:56 cmaxw DESKTOP-RI1URQ6 Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/12/28:14:45:56 cmaxw DESKTOP-RI1URQ6 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\cmaxw\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2016/12/28:14:45:56 cmaxw DESKTOP-RI1URQ6 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2016/12/28:14:45:57 cmaxw DESKTOP-RI1URQ6 Download Play CM http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CM.ta...
2016/12/28:14:46:15 cmaxw DESKTOP-RI1URQ6 Download Aborted CM http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CM.ta...
2016/12/28:14:46:15 cmaxw DESKTOP-RI1URQ6 Install Autodesk® Material Library 2016 Failed Download Failed, Installation aborted, Result=1603
2016/12/28:14:46:15 cmaxw DESKTOP-RI1URQ6 PageOpen InstallCompleteDialog
2016/12/28:14:46:46 cmaxw DESKTOP-RI1URQ6 === Setup ended ===
2016/12/28:14:47:04 cmaxw DESKTOP-RI1URQ6 === Setup started on DESKTOP-RI1URQ6 by cmaxw ===
2016/12/28:14:47:04 cmaxw DESKTOP-RI1URQ6 Path_Length: 154
2016/12/28:14:47:04 cmaxw DESKTOP-RI1URQ6 Current Directory C:\Autodesk\Inventor_2016_English_Win_64bit_wi_en-us
2016/12/28:14:47:04 cmaxw DESKTOP-RI1URQ6 Launch
2016/12/28:14:47:04 cmaxw DESKTOP-RI1URQ6 CommandLine /PK 797H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/Inventor_2016_English_Win_64bit_wi_en-us_Set...
2016/12/28:14:47:04 cmaxw DESKTOP-RI1URQ6 Current Directory C:\Users\cmaxw\AppData\Local\Temp\_AI1B9A.tmp
2016/12/28:14:47:18 cmaxw DESKTOP-RI1URQ6 === Setup ended ===
2016/12/28:14:47:05 cmaxw DESKTOP-RI1URQ6 === Setup started on DESKTOP-RI1URQ6 by cmaxw ===
2016/12/28:14:47:05 cmaxw DESKTOP-RI1URQ6 Path_Length: 154
2016/12/28:14:47:05 cmaxw DESKTOP-RI1URQ6 Current Directory C:\Users\cmaxw\AppData\Local\Temp\_AI1B9A.tmp
2016/12/28:14:47:05 cmaxw DESKTOP-RI1URQ6 Launch
2016/12/28:14:47:06 cmaxw DESKTOP-RI1URQ6 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2016/12/28:14:47:06 cmaxw DESKTOP-RI1URQ6 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2016/12/28:14:47:18 cmaxw DESKTOP-RI1URQ6 PageOpen LaunchDialog
2016/12/28:14:47:24 cmaxw DESKTOP-RI1URQ6 Install CustomCallback Info Invoking custom callback for details: [ACEINVADDIN] CB_FUNC=CBCatalogBrowserMessage CB_SOURCE=C:\Users\cmaxw\AppData\Local\Temp\_AI1B9A.tmp\Setup\AcadeUI.dll
2016/12/28:14:47:24 cmaxw DESKTOP-RI1URQ6 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=The manufacturer database is available for download. URLTitle=Learn more URLLink=http://www.autodesk.com/autocadelectrical-content-default-catalog-database-2016
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 PageOpen LicenseDialog
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 PageOpen ProductInfoDialog
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 PageOpen InventorFlavorSelectionDialog
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==DefaultLanguage: en-us
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==InstallName: INVENTOR
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==ProductName: Autodesk Inventor 2016
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==DisplayName: Autodesk® Inventor® 2016
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==DeploymentName:
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupTitle: Autodesk Inventor 2016
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==ConfigTransform:
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==ExeParams:
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==ProductCode: {7F4DD591-2064-0001-0000-7107D70F3DB4}
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==SupportLink:
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==InfotainmentLink:
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==MsiFileName: inventor.msi
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==AdminImageConfigName: Imgx64
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==AdminImageRoot:
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==GetBaseDeploymentName:
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==DeploymentLocation:
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==DocumentLink: http://autodesk.com/inventor-install-2016-enu
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==InstallDeploymentShortcut:
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==ModifyDeploymentShortcut:
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupLockType: 2
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupNetworkType:  1
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==SystemLocale: 4105
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==EvalMsiFilePath: C:\Users\cmaxw\AppData\Local\Temp\_AI1B9A.tmp\SetupRes\eval.msi
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2016\EULA
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==InstallLogPath: C:\Users\cmaxw\AppData\Local\Temp\Inventor2016Install.log
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==ConfigFile: C:\Users\cmaxw\AppData\Local\Temp\_AI1B9A.tmp\Setup.ini
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupPath: C:\Users\cmaxw\AppData\Local\Temp\_AI1B9A.tmp\
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==NetworkLogPath:
2016/12/28:14:47:37 cmaxw DESKTOP-RI1URQ6 Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2016
2016/12/28:14:47:54 cmaxw DESKTOP-RI1URQ6 Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2016/12/28:14:47:54 cmaxw DESKTOP-RI1URQ6 PageOpen ProductInfoDialog
2016/12/28:14:47:54 cmaxw DESKTOP-RI1URQ6 PageOpen LicenseDialog
2016/12/28:14:47:54 cmaxw DESKTOP-RI1URQ6 PageOpen LaunchDialog
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 PageOpen LicenseDialog
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 PageOpen ProductInfoDialog
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 PageOpen InventorFlavorSelectionDialog
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==DefaultLanguage: en-us
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==InstallName: INVENTOR
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==ProductName: Autodesk Inventor 2016
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==DisplayName: Autodesk® Inventor® 2016
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==DeploymentName:
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupTitle: Autodesk Inventor 2016
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==ConfigTransform:
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==ExeParams:
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==ProductCode: {7F4DD591-2064-0001-0000-7107D70F3DB4}
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==SupportLink:
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==InfotainmentLink:
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==MsiFileName: inventor.msi
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==AdminImageConfigName: Imgx64
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==AdminImageRoot:
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==GetBaseDeploymentName:
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==DeploymentLocation:
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==DocumentLink: http://autodesk.com/inventor-install-2016-enu
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==InstallDeploymentShortcut:
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==ModifyDeploymentShortcut:
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupLockType: 2
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupNetworkType:  1
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==SystemLocale: 4105
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==EvalMsiFilePath: C:\Users\cmaxw\AppData\Local\Temp\_AI1B9A.tmp\SetupRes\eval.msi
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2016\EULA
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==InstallLogPath: C:\Users\cmaxw\AppData\Local\Temp\Inventor2016Install.log
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==ConfigFile: C:\Users\cmaxw\AppData\Local\Temp\_AI1B9A.tmp\Setup.ini
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupPath: C:\Users\cmaxw\AppData\Local\Temp\_AI1B9A.tmp\
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==NetworkLogPath:
2016/12/28:14:47:57 cmaxw DESKTOP-RI1URQ6 Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2016
2016/12/28:14:47:59 cmaxw DESKTOP-RI1URQ6 Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2016/12/28:14:47:59 cmaxw DESKTOP-RI1URQ6 PageOpen ProductSelectionDialog2
2016/12/28:14:48:50 cmaxw DESKTOP-RI1URQ6 PageOpen FullProgressDialog
2016/12/28:14:48:50 cmaxw DESKTOP-RI1URQ6 Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2016/12/28:14:48:51 cmaxw DESKTOP-RI1URQ6 Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2016/12/28:14:48:51 cmaxw DESKTOP-RI1URQ6 Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/12/28:14:48:51 cmaxw DESKTOP-RI1URQ6 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\cmaxw\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2016/12/28:14:48:51 cmaxw DESKTOP-RI1URQ6 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2016/12/28:14:48:51 cmaxw DESKTOP-RI1URQ6 Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/12/28:14:48:51 cmaxw DESKTOP-RI1URQ6 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\cmaxw\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2016/12/28:14:48:52 cmaxw DESKTOP-RI1URQ6 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2016/12/28:14:48:52 cmaxw DESKTOP-RI1URQ6 Download Play CM http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CM.ta...
2016/12/28:14:49:07 cmaxw DESKTOP-RI1URQ6 Download Aborted CM http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CM.ta...
2016/12/28:14:49:07 cmaxw DESKTOP-RI1URQ6 Install Autodesk® Material Library 2016 Failed Download Failed, Installation aborted, Result=1603
2016/12/28:14:49:08 cmaxw DESKTOP-RI1URQ6 PageOpen InstallCompleteDialog
2016/12/28:14:56:25 cmaxw DESKTOP-RI1URQ6 === Setup ended ===
2016/12/28:15:10:39 cmaxw DESKTOP-RI1URQ6 === Setup started on DESKTOP-RI1URQ6 by cmaxw ===
2016/12/28:15:10:39 cmaxw DESKTOP-RI1URQ6 Path_Length: 154
2016/12/28:15:10:39 cmaxw DESKTOP-RI1URQ6 Current Directory C:\Autodesk\Inventor_2016_English_Win_64bit_wi_en-us
2016/12/28:15:10:39 cmaxw DESKTOP-RI1URQ6 Launch
2016/12/28:15:10:39 cmaxw DESKTOP-RI1URQ6 CommandLine /PK 797H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/Inventor_2016_English_Win_64bit_wi_en-us_Set...
2016/12/28:15:10:39 cmaxw DESKTOP-RI1URQ6 Current Directory C:\Users\cmaxw\AppData\Local\Temp\_AIB302.tmp
2016/12/28:15:10:53 cmaxw DESKTOP-RI1URQ6 === Setup ended ===
2016/12/28:15:10:40 cmaxw DESKTOP-RI1URQ6 === Setup started on DESKTOP-RI1URQ6 by cmaxw ===
2016/12/28:15:10:40 cmaxw DESKTOP-RI1URQ6 Path_Length: 154
2016/12/28:15:10:40 cmaxw DESKTOP-RI1URQ6 Current Directory C:\Users\cmaxw\AppData\Local\Temp\_AIB302.tmp
2016/12/28:15:10:40 cmaxw DESKTOP-RI1URQ6 Launch
2016/12/28:15:10:41 cmaxw DESKTOP-RI1URQ6 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2016/12/28:15:10:41 cmaxw DESKTOP-RI1URQ6 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2016/12/28:15:10:52 cmaxw DESKTOP-RI1URQ6 PageOpen LaunchDialog
2016/12/28:15:10:56 cmaxw DESKTOP-RI1URQ6 PageOpen LicenseDialog
2016/12/28:15:10:56 cmaxw DESKTOP-RI1URQ6 PageOpen ProductSelectionDialog2
2016/12/28:15:11:02 cmaxw DESKTOP-RI1URQ6 PageOpen LicenseDialog
2016/12/28:15:11:02 cmaxw DESKTOP-RI1URQ6 PageOpen LaunchDialog
2016/12/28:15:11:07 cmaxw DESKTOP-RI1URQ6 Install CustomCallback Info Invoking custom callback for details: [ACEINVADDIN] CB_FUNC=CBCatalogBrowserMessage CB_SOURCE=C:\Users\cmaxw\AppData\Local\Temp\_AIB302.tmp\Setup\AcadeUI.dll
2016/12/28:15:11:07 cmaxw DESKTOP-RI1URQ6 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=The manufacturer database is available for download. URLTitle=Learn more URLLink=http://www.autodesk.com/autocadelectrical-content-default-catalog-database-2016
2016/12/28:15:11:21 cmaxw DESKTOP-RI1URQ6 PageOpen LicenseDialog
2016/12/28:15:11:21 cmaxw DESKTOP-RI1URQ6 PageOpen ProductInfoDialog
2016/12/28:15:11:21 cmaxw DESKTOP-RI1URQ6 PageOpen InventorFlavorSelectionDialog
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==DefaultLanguage: en-us
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==InstallName: INVENTOR
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==ProductName: Autodesk Inventor 2016
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==DisplayName: Autodesk® Inventor® 2016
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==DeploymentName:
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupTitle: Autodesk Inventor 2016
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==ConfigTransform:
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==ExeParams:
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==ProductCode: {7F4DD591-2064-0001-0000-7107D70F3DB4}
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==SupportLink:
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==InfotainmentLink:
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==MsiFileName: inventor.msi
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==AdminImageConfigName: Imgx64
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==AdminImageRoot:
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==GetBaseDeploymentName:
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==DeploymentLocation:
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==DocumentLink: http://autodesk.com/inventor-install-2016-enu
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==InstallDeploymentShortcut:
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==ModifyDeploymentShortcut:
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupLockType: 2
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupNetworkType:  1
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==SystemLocale: 4105
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==EvalMsiFilePath: C:\Users\cmaxw\AppData\Local\Temp\_AIB302.tmp\SetupRes\eval.msi
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2016\EULA
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==InstallLogPath: C:\Users\cmaxw\AppData\Local\Temp\Inventor2016Install.log
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==ConfigFile: C:\Users\cmaxw\AppData\Local\Temp\_AIB302.tmp\Setup.ini
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupPath: C:\Users\cmaxw\AppData\Local\Temp\_AIB302.tmp\
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==NetworkLogPath:
2016/12/28:15:11:22 cmaxw DESKTOP-RI1URQ6 Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2016
2016/12/28:15:11:27 cmaxw DESKTOP-RI1URQ6 Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2016/12/28:15:11:27 cmaxw DESKTOP-RI1URQ6 PageOpen ProductSelectionDialog2
2016/12/28:15:11:44 cmaxw DESKTOP-RI1URQ6 PageOpen FullProgressDialog
2016/12/28:15:11:48 cmaxw DESKTOP-RI1URQ6 Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2016/12/28:15:11:48 cmaxw DESKTOP-RI1URQ6 Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2016/12/28:15:11:48 cmaxw DESKTOP-RI1URQ6 Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/12/28:15:11:48 cmaxw DESKTOP-RI1URQ6 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\cmaxw\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2016/12/28:15:11:49 cmaxw DESKTOP-RI1URQ6 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2016/12/28:15:11:49 cmaxw DESKTOP-RI1URQ6 Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/12/28:15:11:49 cmaxw DESKTOP-RI1URQ6 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\cmaxw\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2016/12/28:15:11:49 cmaxw DESKTOP-RI1URQ6 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2016/12/28:15:11:50 cmaxw DESKTOP-RI1URQ6 Download Play CM http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CM.ta...
2016/12/28:15:12:05 cmaxw DESKTOP-RI1URQ6 Download Aborted CM http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CM.ta...
2016/12/28:15:12:05 cmaxw DESKTOP-RI1URQ6 Install Autodesk® Material Library 2016 Failed Download Failed, Installation aborted, Result=1603
2016/12/28:15:12:06 cmaxw DESKTOP-RI1URQ6 PageOpen InstallCompleteDialog
2016/12/28:15:12:12 cmaxw DESKTOP-RI1URQ6 === Setup ended ===
2016/12/28:15:22:08 cmaxw DESKTOP-RI1URQ6 === Setup started on DESKTOP-RI1URQ6 by cmaxw ===
2016/12/28:15:22:08 cmaxw DESKTOP-RI1URQ6 Path_Length: 154
2016/12/28:15:22:08 cmaxw DESKTOP-RI1URQ6 Current Directory C:\Autodesk\Inventor_2016_English_Win_64bit_wi_en-us
2016/12/28:15:22:08 cmaxw DESKTOP-RI1URQ6 Launch
2016/12/28:15:22:08 cmaxw DESKTOP-RI1URQ6 CommandLine /PK 797H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/Inventor_2016_English_Win_64bit_wi_en-us_Set...
2016/12/28:15:22:08 cmaxw DESKTOP-RI1URQ6 Current Directory C:\Users\cmaxw\AppData\Local\Temp\_AI34A5.tmp
2016/12/28:15:22:22 cmaxw DESKTOP-RI1URQ6 === Setup ended ===
2016/12/28:15:22:09 cmaxw DESKTOP-RI1URQ6 === Setup started on DESKTOP-RI1URQ6 by cmaxw ===
2016/12/28:15:22:09 cmaxw DESKTOP-RI1URQ6 Path_Length: 154
2016/12/28:15:22:09 cmaxw DESKTOP-RI1URQ6 Current Directory C:\Users\cmaxw\AppData\Local\Temp\_AI34A5.tmp
2016/12/28:15:22:09 cmaxw DESKTOP-RI1URQ6 Launch
2016/12/28:15:22:10 cmaxw DESKTOP-RI1URQ6 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2016/12/28:15:22:10 cmaxw DESKTOP-RI1URQ6 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2016/12/28:15:22:22 cmaxw DESKTOP-RI1URQ6 PageOpen LaunchDialog
2016/12/28:15:22:26 cmaxw DESKTOP-RI1URQ6 PageOpen LicenseDialog
2016/12/28:15:22:26 cmaxw DESKTOP-RI1URQ6 PageOpen ProductSelectionDialog2
2016/12/28:15:22:30 cmaxw DESKTOP-RI1URQ6 PageOpen LicenseDialog
2016/12/28:15:22:30 cmaxw DESKTOP-RI1URQ6 PageOpen LaunchDialog
2016/12/28:15:22:35 cmaxw DESKTOP-RI1URQ6 Install CustomCallback Info Invoking custom callback for details: [ACEINVADDIN] CB_FUNC=CBCatalogBrowserMessage CB_SOURCE=C:\Users\cmaxw\AppData\Local\Temp\_AI34A5.tmp\Setup\AcadeUI.dll
2016/12/28:15:22:35 cmaxw DESKTOP-RI1URQ6 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=The manufacturer database is available for download. URLTitle=Learn more URLLink=http://www.autodesk.com/autocadelectrical-content-default-catalog-database-2016
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 PageOpen LicenseDialog
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 PageOpen ProductInfoDialog
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 PageOpen InventorFlavorSelectionDialog
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==DefaultLanguage: en-us
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==InstallName: INVENTOR
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==ProductName: Autodesk Inventor 2016
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==DisplayName: Autodesk® Inventor® 2016
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==DeploymentName:
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupTitle: Autodesk Inventor 2016
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==ConfigTransform:
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==ExeParams:
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==ProductCode: {7F4DD591-2064-0001-0000-7107D70F3DB4}
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==SupportLink:
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==InfotainmentLink:
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==MsiFileName: inventor.msi
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==AdminImageConfigName: Imgx64
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==AdminImageRoot:
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==GetBaseDeploymentName:
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==DeploymentLocation:
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==DocumentLink: http://autodesk.com/inventor-install-2016-enu
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==InstallDeploymentShortcut:
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==ModifyDeploymentShortcut:
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupLockType: 2
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupNetworkType:  1
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==SystemLocale: 4105
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==EvalMsiFilePath: C:\Users\cmaxw\AppData\Local\Temp\_AI34A5.tmp\SetupRes\eval.msi
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2016\EULA
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==InstallLogPath: C:\Users\cmaxw\AppData\Local\Temp\Inventor2016Install.log
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==ConfigFile: C:\Users\cmaxw\AppData\Local\Temp\_AI34A5.tmp\Setup.ini
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupPath: C:\Users\cmaxw\AppData\Local\Temp\_AI34A5.tmp\
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==NetworkLogPath:
2016/12/28:15:22:49 cmaxw DESKTOP-RI1URQ6 Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2016
2016/12/28:15:22:57 cmaxw DESKTOP-RI1URQ6 Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2016/12/28:15:22:57 cmaxw DESKTOP-RI1URQ6 PageOpen ProductSelectionDialog2
2016/12/28:15:23:04 cmaxw DESKTOP-RI1URQ6 PageOpen FullProgressDialog
2016/12/28:15:23:05 cmaxw DESKTOP-RI1URQ6 Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2016/12/28:15:23:05 cmaxw DESKTOP-RI1URQ6 Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2016/12/28:15:23:05 cmaxw DESKTOP-RI1URQ6 Download Play VCREDIST2008SP1X64_6161 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/12/28:15:23:07 cmaxw DESKTOP-RI1URQ6 Download Complete VCREDIST2008SP1X64_6161 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/12/28:15:23:07 cmaxw DESKTOP-RI1URQ6 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q
2016/12/28:15:23:27 cmaxw DESKTOP-RI1URQ6 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Succeeded
2016/12/28:15:23:28 cmaxw DESKTOP-RI1URQ6 Download Play VCREDIST2008SP1X86_6161 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/12/28:15:23:30 cmaxw DESKTOP-RI1URQ6 Download Complete VCREDIST2008SP1X86_6161 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/12/28:15:23:30 cmaxw DESKTOP-RI1URQ6 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x86\VCRedist\2008SP1.6161\vcredist_x86.exe" /q
2016/12/28:15:23:47 cmaxw DESKTOP-RI1URQ6 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161 Succeeded
2016/12/28:15:23:47 cmaxw DESKTOP-RI1URQ6 Download Play VCREDIST2010SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/12/28:15:23:50 cmaxw DESKTOP-RI1URQ6 Download Complete VCREDIST2010SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/12/28:15:23:50 cmaxw DESKTOP-RI1URQ6 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart /l C:\Users\cmaxw\AppData\Local\Temp\vcredist_x64_2010.log
2016/12/28:15:23:58 cmaxw DESKTOP-RI1URQ6 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2016/12/28:15:23:58 cmaxw DESKTOP-RI1URQ6 Download Play VCREDIST2010SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/12/28:15:24:00 cmaxw DESKTOP-RI1URQ6 Download Complete VCREDIST2010SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/12/28:15:24:00 cmaxw DESKTOP-RI1URQ6 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /l C:\Users\cmaxw\AppData\Local\Temp\vcredist_x86_2010.log
2016/12/28:15:24:08 cmaxw DESKTOP-RI1URQ6 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2016/12/28:15:24:08 cmaxw DESKTOP-RI1URQ6 Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/12/28:15:24:08 cmaxw DESKTOP-RI1URQ6 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\cmaxw\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2016/12/28:15:24:11 cmaxw DESKTOP-RI1URQ6 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2016/12/28:15:24:11 cmaxw DESKTOP-RI1URQ6 Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/12/28:15:24:11 cmaxw DESKTOP-RI1URQ6 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\cmaxw\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2016/12/28:15:24:14 cmaxw DESKTOP-RI1URQ6 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2016/12/28:15:24:14 cmaxw DESKTOP-RI1URQ6 Download Play CM http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CM.ta...
2016/12/28:15:24:30 cmaxw DESKTOP-RI1URQ6 Download Aborted CM http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CM.ta...
2016/12/28:15:24:30 cmaxw DESKTOP-RI1URQ6 Install Autodesk® Material Library 2016 Failed Download Failed, Installation aborted, Result=1603
2016/12/28:15:24:31 cmaxw DESKTOP-RI1URQ6 PageOpen InstallCompleteDialog
2016/12/28:15:25:38 cmaxw DESKTOP-RI1URQ6 === Setup ended ===
2016/12/28:15:25:55 cmaxw DESKTOP-RI1URQ6 === Setup started on DESKTOP-RI1URQ6 by cmaxw ===
2016/12/28:15:25:55 cmaxw DESKTOP-RI1URQ6 Path_Length: 154
2016/12/28:15:25:55 cmaxw DESKTOP-RI1URQ6 Current Directory C:\Autodesk\Inventor_2016_English_Win_64bit_wi_en-us
2016/12/28:15:25:55 cmaxw DESKTOP-RI1URQ6 Launch
2016/12/28:15:25:55 cmaxw DESKTOP-RI1URQ6 CommandLine /PK 797H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/Inventor_2016_English_Win_64bit_wi_en-us_Set...
2016/12/28:15:25:55 cmaxw DESKTOP-RI1URQ6 Current Directory C:\Users\cmaxw\AppData\Local\Temp\_AIAB2E.tmp
2016/12/28:15:26:09 cmaxw DESKTOP-RI1URQ6 === Setup ended ===
2016/12/28:15:25:57 cmaxw DESKTOP-RI1URQ6 === Setup started on DESKTOP-RI1URQ6 by cmaxw ===
2016/12/28:15:25:57 cmaxw DESKTOP-RI1URQ6 Path_Length: 154
2016/12/28:15:25:57 cmaxw DESKTOP-RI1URQ6 Current Directory C:\Users\cmaxw\AppData\Local\Temp\_AIAB2E.tmp
2016/12/28:15:25:57 cmaxw DESKTOP-RI1URQ6 Launch
2016/12/28:15:25:57 cmaxw DESKTOP-RI1URQ6 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2016/12/28:15:25:57 cmaxw DESKTOP-RI1URQ6 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2016/12/28:15:26:09 cmaxw DESKTOP-RI1URQ6 PageOpen LaunchDialog
2016/12/28:15:26:14 cmaxw DESKTOP-RI1URQ6 Install CustomCallback Info Invoking custom callback for details: [ACEINVADDIN] CB_FUNC=CBCatalogBrowserMessage CB_SOURCE=C:\Users\cmaxw\AppData\Local\Temp\_AIAB2E.tmp\Setup\AcadeUI.dll
2016/12/28:15:26:14 cmaxw DESKTOP-RI1URQ6 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=The manufacturer database is available for download. URLTitle=Learn more URLLink=http://www.autodesk.com/autocadelectrical-content-default-catalog-database-2016
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 PageOpen LicenseDialog
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 PageOpen ProductInfoDialog
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 PageOpen InventorFlavorSelectionDialog
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==DefaultLanguage: en-us
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==InstallName: INVENTOR
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==ProductName: Autodesk Inventor 2016
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==DisplayName: Autodesk® Inventor® 2016
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==DeploymentName:
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupTitle: Autodesk Inventor 2016
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==ConfigTransform:
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==ExeParams:
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==ProductCode: {7F4DD591-2064-0001-0000-7107D70F3DB4}
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==SupportLink:
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==InfotainmentLink:
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==MsiFileName: inventor.msi
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==AdminImageConfigName: Imgx64
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==AdminImageRoot:
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==GetBaseDeploymentName:
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==DeploymentLocation:
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==DocumentLink: http://autodesk.com/inventor-install-2016-enu
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==InstallDeploymentShortcut:
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==ModifyDeploymentShortcut:
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupLockType: 2
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupNetworkType:  1
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==SystemLocale: 4105
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==EvalMsiFilePath: C:\Users\cmaxw\AppData\Local\Temp\_AIAB2E.tmp\SetupRes\eval.msi
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2016\EULA
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==InstallLogPath: C:\Users\cmaxw\AppData\Local\Temp\Inventor2016Install.log
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==ConfigFile: C:\Users\cmaxw\AppData\Local\Temp\_AIAB2E.tmp\Setup.ini
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupPath: C:\Users\cmaxw\AppData\Local\Temp\_AIAB2E.tmp\
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==NetworkLogPath:
2016/12/28:15:26:28 cmaxw DESKTOP-RI1URQ6 Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2016
2016/12/28:15:26:55 cmaxw DESKTOP-RI1URQ6 Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2016/12/28:15:26:55 cmaxw DESKTOP-RI1URQ6 PageOpen ProductSelectionDialog2
2016/12/28:15:27:21 cmaxw DESKTOP-RI1URQ6 PageOpen FullProgressDialog
2016/12/28:15:27:21 cmaxw DESKTOP-RI1URQ6 Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2016/12/28:15:27:21 cmaxw DESKTOP-RI1URQ6 Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2016/12/28:15:27:21 cmaxw DESKTOP-RI1URQ6 Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/12/28:15:27:21 cmaxw DESKTOP-RI1URQ6 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\cmaxw\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2016/12/28:15:27:22 cmaxw DESKTOP-RI1URQ6 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2016/12/28:15:27:22 cmaxw DESKTOP-RI1URQ6 Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/12/28:15:27:22 cmaxw DESKTOP-RI1URQ6 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\cmaxw\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2016/12/28:15:27:23 cmaxw DESKTOP-RI1URQ6 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2016/12/28:15:27:23 cmaxw DESKTOP-RI1URQ6 Download Play CM http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CM.ta...
2016/12/28:15:27:39 cmaxw DESKTOP-RI1URQ6 Download Aborted CM http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CM.ta...
2016/12/28:15:27:39 cmaxw DESKTOP-RI1URQ6 Install Autodesk® Material Library 2016 Failed Download Failed, Installation aborted, Result=1603
2016/12/28:15:27:39 cmaxw DESKTOP-RI1URQ6 PageOpen InstallCompleteDialog
2016/12/28:15:27:59 cmaxw DESKTOP-RI1URQ6 === Setup ended ===
2016/12/28:15:38:16 cmaxw DESKTOP-RI1URQ6 === Setup started on DESKTOP-RI1URQ6 by cmaxw ===
2016/12/28:15:38:16 cmaxw DESKTOP-RI1URQ6 Path_Length: 154
2016/12/28:15:38:16 cmaxw DESKTOP-RI1URQ6 Current Directory C:\Autodesk\Inventor_2016_English_Win_64bit_wi_en-us
2016/12/28:15:38:16 cmaxw DESKTOP-RI1URQ6 Launch
2016/12/28:15:38:16 cmaxw DESKTOP-RI1URQ6 CommandLine /PK 797H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/Inventor_2016_English_Win_64bit_wi_en-us_Set...
2016/12/28:15:38:16 cmaxw DESKTOP-RI1URQ6 Current Directory C:\Users\cmaxw\AppData\Local\Temp\_AIFD11.tmp
2016/12/28:15:38:30 cmaxw DESKTOP-RI1URQ6 === Setup ended ===
2016/12/28:15:38:18 cmaxw DESKTOP-RI1URQ6 === Setup started on DESKTOP-RI1URQ6 by cmaxw ===
2016/12/28:15:38:18 cmaxw DESKTOP-RI1URQ6 Path_Length: 154
2016/12/28:15:38:18 cmaxw DESKTOP-RI1URQ6 Current Directory C:\Users\cmaxw\AppData\Local\Temp\_AIFD11.tmp
2016/12/28:15:38:18 cmaxw DESKTOP-RI1URQ6 Launch
2016/12/28:15:38:18 cmaxw DESKTOP-RI1URQ6 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2016/12/28:15:38:18 cmaxw DESKTOP-RI1URQ6 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2016/12/28:15:38:30 cmaxw DESKTOP-RI1URQ6 PageOpen LaunchDialog
2016/12/28:15:38:38 cmaxw DESKTOP-RI1URQ6 Inventorui== Parameter: Prereq_8 SetupMode:7 InstallState:1 InstallAction:0 Message:
2016/12/28:15:38:38 cmaxw DESKTOP-RI1URQ6 PageOpen LicenseDialog
2016/12/28:15:38:38 cmaxw DESKTOP-RI1URQ6 PageOpen ProductSelectionDialog2
2016/12/28:15:38:46 cmaxw DESKTOP-RI1URQ6 PageOpen FullProgressDialog
2016/12/28:15:38:46 cmaxw DESKTOP-RI1URQ6 Installing Network License Manager:  ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\"  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2016" SETUP_PACKAGECODE={8CB42675-2000-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={885CB096-0DBB-411F-AE76-39C6C0B5929C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/12/28:15:38:47 cmaxw DESKTOP-RI1URQ6 Install Network License Manager Succeeded
2016/12/28:15:38:48 cmaxw DESKTOP-RI1URQ6 Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2016/12/28:15:38:48 cmaxw DESKTOP-RI1URQ6 Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2016/12/28:15:38:48 cmaxw DESKTOP-RI1URQ6 Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/12/28:15:38:48 cmaxw DESKTOP-RI1URQ6 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\cmaxw\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2016/12/28:15:38:49 cmaxw DESKTOP-RI1URQ6 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2016/12/28:15:38:49 cmaxw DESKTOP-RI1URQ6 Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/12/28:15:38:49 cmaxw DESKTOP-RI1URQ6 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\cmaxw\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2016/12/28:15:38:49 cmaxw DESKTOP-RI1URQ6 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2016/12/28:15:38:49 cmaxw DESKTOP-RI1URQ6 Download Skipped CADM http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CADM_...
2016/12/28:15:38:50 cmaxw DESKTOP-RI1URQ6 Installing Autodesk® CAD Manager Tools:   INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\"  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2016" SETUP_PACKAGECODE={8CB42675-2000-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="SSE2 Support Check,Microsoft Visual C++ 2012 Redistributable (x86) Update 4,Microsoft Visual C++ 2012 Redistributable (x64) Update 4,;;;;" PACKAGEUPI={885CB096-0DBB-411F-AE76-39C6C0B5929C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/12/28:15:38:52 cmaxw DESKTOP-RI1URQ6 Install Autodesk® CAD Manager Tools Succeeded
2016/12/28:15:38:52 cmaxw DESKTOP-RI1URQ6 Download Play SUCCESSMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SUCCE...
2016/12/28:15:38:52 cmaxw DESKTOP-RI1URQ6 Download Complete SUCCESSMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SUCCE...
2016/12/28:15:38:52 cmaxw DESKTOP-RI1URQ6 PageOpen InstallCompleteDialog
2016/12/28:15:39:09 cmaxw DESKTOP-RI1URQ6 === Setup ended ===
2016/12/28:15:40:00 cmaxw DESKTOP-RI1URQ6 === Setup started on DESKTOP-RI1URQ6 by cmaxw ===
2016/12/28:15:40:00 cmaxw DESKTOP-RI1URQ6 Path_Length: 154
2016/12/28:15:40:00 cmaxw DESKTOP-RI1URQ6 Current Directory C:\Autodesk\Inventor_2016_English_Win_64bit_wi_en-us
2016/12/28:15:40:00 cmaxw DESKTOP-RI1URQ6 Launch
2016/12/28:15:40:00 cmaxw DESKTOP-RI1URQ6 CommandLine /PK 797H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/Inventor_2016_English_Win_64bit_wi_en-us_Set...
2016/12/28:15:40:00 cmaxw DESKTOP-RI1URQ6 Current Directory C:\Users\cmaxw\AppData\Local\Temp\_AI9063.tmp
2016/12/28:15:40:14 cmaxw DESKTOP-RI1URQ6 === Setup ended ===
2016/12/28:15:40:02 cmaxw DESKTOP-RI1URQ6 === Setup started on DESKTOP-RI1URQ6 by cmaxw ===
2016/12/28:15:40:02 cmaxw DESKTOP-RI1URQ6 Path_Length: 154
2016/12/28:15:40:02 cmaxw DESKTOP-RI1URQ6 Current Directory C:\Users\cmaxw\AppData\Local\Temp\_AI9063.tmp
2016/12/28:15:40:02 cmaxw DESKTOP-RI1URQ6 Launch
2016/12/28:15:40:02 cmaxw DESKTOP-RI1URQ6 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2016/12/28:15:40:02 cmaxw DESKTOP-RI1URQ6 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2016/12/28:15:40:14 cmaxw DESKTOP-RI1URQ6 PageOpen LaunchDialog
2016/12/28:15:40:20 cmaxw DESKTOP-RI1URQ6 Install CustomCallback Info Invoking custom callback for details: [ACEINVADDIN] CB_FUNC=CBCatalogBrowserMessage CB_SOURCE=C:\Users\cmaxw\AppData\Local\Temp\_AI9063.tmp\Setup\AcadeUI.dll
2016/12/28:15:40:20 cmaxw DESKTOP-RI1URQ6 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=The manufacturer database is available for download. URLTitle=Learn more URLLink=http://www.autodesk.com/autocadelectrical-content-default-catalog-database-2016
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 PageOpen LicenseDialog
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 PageOpen ProductInfoDialog
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 PageOpen InventorFlavorSelectionDialog
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==DefaultLanguage: en-us
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==InstallName: INVENTOR
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==ProductName: Autodesk Inventor 2016
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==DisplayName: Autodesk® Inventor® 2016
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==DeploymentName:
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupTitle: Autodesk Inventor 2016
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==ConfigTransform:
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==ExeParams:
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==ProductCode: {7F4DD591-2064-0001-0000-7107D70F3DB4}
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==SupportLink:
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==InfotainmentLink:
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==MsiFileName: inventor.msi
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==AdminImageConfigName: Imgx64
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==AdminImageRoot:
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==GetBaseDeploymentName:
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==DeploymentLocation:
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==DocumentLink: http://autodesk.com/inventor-install-2016-enu
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==InstallDeploymentShortcut:
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==ModifyDeploymentShortcut:
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupLockType: 2
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupNetworkType:  1
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==SystemLocale: 4105
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==EvalMsiFilePath: C:\Users\cmaxw\AppData\Local\Temp\_AI9063.tmp\SetupRes\eval.msi
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2016\EULA
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==InstallLogPath: C:\Users\cmaxw\AppData\Local\Temp\Inventor2016Install.log
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==ConfigFile: C:\Users\cmaxw\AppData\Local\Temp\_AI9063.tmp\Setup.ini
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==SetupPath: C:\Users\cmaxw\AppData\Local\Temp\_AI9063.tmp\
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==NetworkLogPath:
2016/12/28:15:40:34 cmaxw DESKTOP-RI1URQ6 Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2016
2016/12/28:15:40:41 cmaxw DESKTOP-RI1URQ6 Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2016/12/28:15:40:41 cmaxw DESKTOP-RI1URQ6 PageOpen ProductSelectionDialog2
2016/12/28:15:41:57 cmaxw DESKTOP-RI1URQ6 PageOpen FullProgressDialog
2016/12/28:15:41:58 cmaxw DESKTOP-RI1URQ6 Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2016/12/28:15:41:58 cmaxw DESKTOP-RI1URQ6 Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2016/12/28:15:41:58 cmaxw DESKTOP-RI1URQ6 Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/12/28:15:41:58 cmaxw DESKTOP-RI1URQ6 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\cmaxw\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2016/12/28:15:41:59 cmaxw DESKTOP-RI1URQ6 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2016/12/28:15:41:59 cmaxw DESKTOP-RI1URQ6 Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/12/28:15:41:59 cmaxw DESKTOP-RI1URQ6 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\cmaxw\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2016/12/28:15:41:59 cmaxw DESKTOP-RI1URQ6 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2016/12/28:15:42:00 cmaxw DESKTOP-RI1URQ6 Download Play CM http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CM.ta...
2016/12/28:15:42:15 cmaxw DESKTOP-RI1URQ6 Download Aborted CM http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CM.ta...
2016/12/28:15:42:15 cmaxw DESKTOP-RI1URQ6 Install Autodesk® Material Library 2016 Failed Download Failed, Installation aborted, Result=1603
Mark.Lancaster
@Anonymous
Welcome to the community...
Your installation is simply failing due to the method (web installer) you're using.  This method is unreliable and shouldn't be used.
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
However if the installation does fail using this method, please post your installation log file here so we can review it.  Posting info: Sometimes installation log files contain personal information such as your serial #.  Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Mark Lancaster
natasha.l
Hello @Anonymous,
Welcome to the Community! Smiley Happy As @Mark.Lancaster please try downloading via the Autodesk virtual Agent. I have included a helpful informative video for you.
