Installation & Licensing
Install 2012 on Virtual Machine on Win 7
3 REPLIES 3
advcad
1977 Views, 3 Replies
I've tried to install ACAD 2012 onto an XP PRo virtual drive on a new Windows 7 machine.  It says that everything has been installed but there is no ACAD.exe file to actually start it.  Has anyone installed it successfully like this?
3 REPLIES 3
hashim.mundol
in reply to: advcad
Virual machines are not supported to Run Autocad.
But Installation should have worked fine. please look at the installation logs in %temp% folder to see if there are any issues.
OR
please try to install the software in diagnostics mode as described here
http://usa.autodesk.com/getdoc/id=TS75218
If the issue persisits, please post the all the log files from the %temp% folder (start->run/search->type %temp% ->Enter) as a zip file.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
farfansal
in reply to: advcad
Can the AutoCAD 2012 license be activated/repaired inside a virtual machine? I want to develop applications for AutoCAD using Visual Studio C#.
I tried to use Visual Studio in the past but it messed up a CNC software package (Router-CIM) that I use everyday. So I wanted to have a development virtual machine with AutoCAD and Visual Studio running on it. Would I need an extra license?
hashim.mundol
in reply to: farfansal
Technically yes, again not supported environment.
License it depends how it would be used. if you can use it as second activation then yes
please check it here
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=3970195
5th point
Hashim Mundol
Autodesk, Inc.
Administrator Productivity
