Installation & Licensing
Instalation Failure Revit 2014
7 REPLIES 7
Message 1 of 8
369 Views, 7 Replies
On completing instalation of revit 2014(student edition) I was told that Revit had failed to install. Will provide instalation log file if necessary.
7 REPLIES 7
Message 2 of 8
Otto
Hello devin_m_miller and welcome to the Autodesk community!
It looks like you are having Revit installation issues. Community members with similar questions found the following article(s) useful:
For issues with Revit Server, please see the System Requirements for Revit Server.
If you are installing on Windows 10, please check that your product is compatible.
Software & Downloads
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Performing a Clean Uninstall
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 8
TravisNave
Yes, provide the log.  🙂
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 4 of 8
in reply to: TravisNave
2015/10/21:22:40:48 Devin ARCHITECT === Setup started on ARCHITECT by Devin ===
2015/10/21:22:40:48 Devin ARCHITECT Path_Length: 149
2015/10/21:22:40:48 Devin ARCHITECT Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2015/10/21:22:40:48 Devin ARCHITECT Launch
2015/10/21:22:40:48 Devin ARCHITECT CommandLine /PK 829F1 /SN 900-37825663 /akamai /sid a1b30000008LcapAAC /skipEULA /skipPI /url "http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_e...
2015/10/21:22:40:48 Devin ARCHITECT Current Directory C:\Users\Devin\AppData\Local\Temp\_AIC9DA.tmp
2015/10/21:22:42:18 Devin ARCHITECT === Setup ended ===
2015/10/21:22:40:49 Devin ARCHITECT === Setup started on ARCHITECT by Devin ===
2015/10/21:22:40:49 Devin ARCHITECT Path_Length: 149
2015/10/21:22:40:49 Devin ARCHITECT Current Directory C:\Users\Devin\AppData\Local\Temp\_AIC9DA.tmp
2015/10/21:22:40:49 Devin ARCHITECT Launch
2015/10/21:22:41:38 Devin ARCHITECT Download Play SETUP_CONFIG http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_...
2015/10/21:22:42:18 Devin ARCHITECT Download Complete SETUP_CONFIG http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_...
2015/10/21:22:42:18 Devin ARCHITECT Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Devin\AppData\Local\Temp\_AIC9DA.tmp\Setup\RevitSetup.dll
2015/10/21:22:42:18 Devin ARCHITECT Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/10/21:22:42:18 Devin ARCHITECT PageOpen LaunchDialog
2015/10/21:22:43:36 Devin ARCHITECT PageOpen LicenseDialog
2015/10/21:22:43:36 Devin ARCHITECT PageOpen ProductInfoDialog
2015/10/21:22:43:36 Devin ARCHITECT PageOpen ProductSelectionDialog2
2015/10/21:22:44:16 Devin ARCHITECT PageOpen FullProgressDialog
2015/10/21:22:44:20 Devin ARCHITECT Download Play VCREDIST2005X86 http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDI...
2015/10/21:22:44:24 Devin ARCHITECT Download Complete VCREDIST2005X86 http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDI...
2015/10/21:22:44:24 Devin ARCHITECT Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Devin\AppData\Local\Temp\vcredist_x86_2005.log"" "
2015/10/21:22:44:40 Devin ARCHITECT Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2015/10/21:22:44:41 Devin ARCHITECT Download Play VCREDIST2005X64 http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDI...
2015/10/21:22:44:45 Devin ARCHITECT Download Complete VCREDIST2005X64 http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDI...
2015/10/21:22:44:45 Devin ARCHITECT Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Devin\AppData\Local\Temp\vcredist_x64_2005.log"" "
2015/10/21:22:45:02 Devin ARCHITECT Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2015/10/21:22:45:04 Devin ARCHITECT Download Play KB958314ATLX86 http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB9583...
2015/10/21:22:45:04 Devin ARCHITECT Download Complete KB958314ATLX86 http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB9583...
2015/10/21:22:45:04 Devin ARCHITECT Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/10/21:22:45:08 Devin ARCHITECT Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2015/10/21:22:45:08 Devin ARCHITECT Download Play KB958314MFCX86 http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB9583...
2015/10/21:22:45:13 Devin ARCHITECT Download Complete KB958314MFCX86 http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB9583...
2015/10/21:22:45:13 Devin ARCHITECT Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/10/21:22:45:22 Devin ARCHITECT Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2015/10/21:22:45:25 Devin ARCHITECT Download Play KB958314CRTX86 http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB9583...
2015/10/21:22:45:28 Devin ARCHITECT Download Complete KB958314CRTX86 http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB9583...
2015/10/21:22:45:28 Devin ARCHITECT Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/10/21:22:45:34 Devin ARCHITECT Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2015/10/21:22:45:36 Devin ARCHITECT Download Play KB958314OPENMPX86 http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB9583...
2015/10/21:22:45:36 Devin ARCHITECT Download Complete KB958314OPENMPX86 http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB9583...
2015/10/21:22:45:36 Devin ARCHITECT Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/10/21:22:45:42 Devin ARCHITECT Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2015/10/21:22:45:43 Devin ARCHITECT Download Play KB958314ATLX64 http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB9583...
2015/10/21:22:45:44 Devin ARCHITECT Download Complete KB958314ATLX64 http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB9583...
2015/10/21:22:45:44 Devin ARCHITECT Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/10/21:22:45:48 Devin ARCHITECT Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2015/10/21:22:45:48 Devin ARCHITECT Download Play KB958314MFCX64 http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB9583...
2015/10/21:22:45:58 Devin ARCHITECT Download Complete KB958314MFCX64 http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB9583...
2015/10/21:22:45:58 Devin ARCHITECT Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/10/21:22:46:08 Devin ARCHITECT Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2015/10/21:22:46:09 Devin ARCHITECT Download Play KB958314CRTX64 http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB9583...
2015/10/21:22:46:10 Devin ARCHITECT Download Complete KB958314CRTX64 http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB9583...
2015/10/21:22:46:10 Devin ARCHITECT Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/10/21:22:46:17 Devin ARCHITECT Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2015/10/21:22:46:18 Devin ARCHITECT Download Play KB958314OPENMPX64 http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB9583...
2015/10/21:22:46:19 Devin ARCHITECT Download Complete KB958314OPENMPX64 http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB9583...
2015/10/21:22:46:19 Devin ARCHITECT Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/10/21:22:46:26 Devin ARCHITECT Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2015/10/21:22:46:27 Devin ARCHITECT Download Play VCREDIST2005SP1ATLX86 http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDI...
2015/10/21:22:46:29 Devin ARCHITECT Download Complete VCREDIST2005SP1ATLX86 http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDI...
2015/10/21:22:46:30 Devin ARCHITECT Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Devin\AppData\Local\Temp\vcredist_x86_2005.log"" "
2015/10/21:22:46:51 Devin ARCHITECT Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2015/10/21:22:46:53 Devin ARCHITECT Download Play VCREDIST2005SP1ATLX64 http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDI...
2015/10/21:22:46:56 Devin ARCHITECT Download Complete VCREDIST2005SP1ATLX64 http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDI...
2015/10/21:22:46:56 Devin ARCHITECT Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Devin\AppData\Local\Temp\vcredist_x64_2005.log"" "
2015/10/21:22:47:16 Devin ARCHITECT Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Succeeded
2015/10/21:22:47:19 Devin ARCHITECT Download Play DIRECTX http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECT...
2015/10/21:22:47:25 Devin ARCHITECT Download Complete DIRECTX http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECT...
2015/10/21:22:47:25 Devin ARCHITECT Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2015/10/21:22:47:29 Devin ARCHITECT Install DirectX® Runtime Succeeded
2015/10/21:22:47:30 Devin ARCHITECT Download Play FaroSDK http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/FaroSD...
2015/10/21:22:47:57 Devin ARCHITECT Download Complete FaroSDK http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/FaroSD...
2015/10/21:22:47:57 Devin ARCHITECT Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/10/21:22:48:10 Devin ARCHITECT Install FaroSDK Succeeded
2015/10/21:22:48:11 Devin ARCHITECT Download Play RVT2014 http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT201...
2015/10/21:22:56:31 Devin ARCHITECT Download Complete RVT2014 http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT201...
2015/10/21:22:56:31 Devin ARCHITECT Installing Autodesk® Revit® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\Devin\AppData\Local\Temp\_AIC9DA.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/10/21:23:26:35 Devin ARCHITECT Install Autodesk® Revit® 2014 Succeeded
2015/10/21:23:26:40 Devin ARCHITECT Download Play RVT2014_en-us http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT201...
2015/10/21:23:27:07 Devin ARCHITECT Download Aborted RVT2014_en-us http://efulfillment.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT201...
2015/10/21:23:27:07 Devin ARCHITECT Install Autodesk® Revit® 2014 Language Pack Failed Download Failed, Installation aborted, Result=1603
2015/10/21:23:33:45 Devin ARCHITECT Rollback Autodesk® Revit® 2014 Succeeded
2015/10/21:23:33:51 Devin ARCHITECT Rollback FaroSDK Succeeded
2015/10/21:23:33:51 Devin ARCHITECT Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2015/10/21:23:33:51 Devin ARCHITECT Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1619
2015/10/21:23:33:51 Devin ARCHITECT Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1619
2015/10/21:23:33:56 Devin ARCHITECT Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2015/10/21:23:34:01 Devin ARCHITECT Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2015/10/21:23:34:05 Devin ARCHITECT Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2015/10/21:23:34:09 Devin ARCHITECT Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2015/10/21:23:34:14 Devin ARCHITECT Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2015/10/21:23:34:19 Devin ARCHITECT Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2015/10/21:23:34:24 Devin ARCHITECT Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2015/10/21:23:34:27 Devin ARCHITECT Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2015/10/21:23:34:27 Devin ARCHITECT Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2015/10/21:23:34:27 Devin ARCHITECT Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
Message 5 of 8
TravisNave
The download is failing during install.
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/customer-service/account-management/software-downloads/download-method...
Autodesk Forums:
Message 6 of 8
I am also trying to install on windows 10 at the moment if that changes anything.
Message 7 of 8
TravisNave
It does.  You might consider applying for 2016 version for Windows 10.  2014 will never be supported on that, but 2016 will shortly with the next service pack.
Autodesk Forums:
Message 8 of 8
tried that, same result: Revit 2016, Content Libraries and Medium image library all failed to install
Administrator Productivity
