Installation & Licensing
351 Views, 1 Reply
instalacja inventora
Witam. Mam problem z instalacją. Mianowicie chce zainstalowac wersje studencka inventora, ale kiedy rozpoczyna się cały proces mam tylko pokazane że jest tzw "inicjowanie" i nic dalej się nie robi. Jaka może być tego przyczyna ?
Pozdrawiam
1 REPLY 1
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
This is an English speaking forum and when your info is translated this is what we see
installation of the inventor
Hello. I have a problem with the installation. Namely, I want to install a student version of the inventor, but when the whole process begins I have only shown that there is a so-called "initiation" and nothing else is done. What can be the reason for this?
greetings
Your issue is most likely based on the method you're using to install..   There's a couple of ways to properly download and install your Autodesk product to your machine.  Please review this article and the solution it provides.
Also for the future..  Installation and licensing issue, questions and etc should be posted in the Installation and Licensing forum.  I will have the moderator relocate your posting there to best suit your needs.
https://forums.autodesk.com/t5/installation-licensing/bd-p/24
Mark Lancaster
Administrator Productivity
